Where can I find the documents describing the UART communication with the Razberry?
Thanks in advance,
Mark
UART Commands
Re: UART Commands
It is called Z-Wave Serial API and is described under an NDA.
But trust me, you don't want to use this API - it is too hard to implement on your own. Use Z-Way or other s/w
softdevrpi
Re: UART Commands
Thanks for your response.
I'm personally more of a low level software or hardware kind of guy and I'd prefer a more standardised low level interface to my hardware.
I have programmed serial interfaces to various WiFi chipsets to communicate with various microcontrollers so I can't imagine it would be much more complex..
Is it the same as the SI Labs serial API, or are you using a different firmware?
https://www.silabs.com/documents/login/ ... -Guide.pdf
Thanks in advance,
Mark
Thanks in advance,
Mark
Re: UART Commands
Yes, this API. But trust me, first 10% will be very easy, but next 20% of work will take half a year
