basic c++ class
bastibart
basic c++ class
Post by bastibart »
Hello guys
This will not compile
class classXX {
public:
  classXX() {;}
void setup() {
  classXX x1;
Any ideas why ?
Arduino IDE is 1.8.5
Z-Uno firmware is 2.1.4
The compiler output is:
C:\Users\SEBAST~1\AppData\Local\Temp\arduino_build_196148/sketch_dec17a.ino
--- USING a list of libraries from:
C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\2.1.4\libraries
D:\WPD\03_Haustechnik\04_Smarthome\Arduino\libraries
*** Collecting prototypes...
Preprocessing file: Custom.c with SDCPP...
Preprocessing file: sketch_dec17a.cpp with SDCPP...
Compiling sketch_dec17a_sdcpp_.cpp ...
Compiling sketch_dec17a_sdcpp_.cpp ...Compiling file "LLCore_arduino.c" by means of SDCC...
sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "LLCore_arduino.c"
sdcc: Generating code...
sdcc: Calling assembler...
sdcc: sdas8051.exe -plosgffw "LLCore_arduino.rel" "LLCore_arduino".asm
Compiling file "Print_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "Print_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Print_ucxx.rel" "Print_ucxx".asm
Compiling file "Stream_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "Stream_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Stream_ucxx.rel" "Stream_ucxx".asm
Compiling file "HardwareSerial_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "HardwareSerial_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HardwareSerial_ucxx.rel" "HardwareSerial_ucxx".asm
Compiling file "HLCore_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "HLCore_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HLCore_ucxx.rel" "HLCore_ucxx".asm
Compiling file "sketch_dec17a_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Sebastian\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70/zuno_toolchain/sdcc/\bin\..\include" "sketch_dec17a_ucxx.c"
sketch_dec17a_ucxx.c:500: syntax error: token -> '}' ; column 1
Error. SDCC returned: 1
exit status 1
Fehler beim Kompilieren für das Board Z-Wave>ME Z-Uno.
havivi
Re: basic c++ class
Post by havivi »
I just hit the exact same thing! Anyone?
bastibart
Re: basic c++ class
Post by bastibart »
I found that the compiler is not a c++ compiler.
The prepropcessor converts everything into plain C and often fails at it.
