Climate Control
Arek
Climate Control
Post by Arek »
1. Possibility to define Frost temperature (like it is for comfort and saving temp.) because right now it is not possible to use this function with Eurotronic Spirit TRV
2. Extend scale of temperature set to 28C (right now max. is 27)
Thank You
kosinus33
Re: Climate Control
Post by kosinus33 »
Same question here.
Re: Climate Control
1) You can use the API to do it via the Expert UI and Code Device app. Here is an example: https://help.z-wave.me/en/knowledge_bas ... rt-home-ui
2) The scale was updated to 35°C.
Kepex
Re: Climate Control
Post by Kepex »
1. Please add the ability to define a custom "Frost" temperature value for the mini split system, similar to how "Comfort" and "Saving" temperatures can be configured. Currently, the frost protection temperature is fixed and cannot be changed, which limits flexibility in energy-saving strategies or specific use cases involving mini split installations.
2. Currently, the maximum temperature that can be set on the mini split device is 27°C. It would be beneficial to extend this range to at least 28°C, as some users may require higher temperature settings to accommodate specific room conditions or climate zones where mini splits are commonly used.
