MxInfo tool collection
piet66
Post by piet66 » 03 Mar 2019 12:09
here the latest version of my tools. I wrote them for me to have more comfortable possibilities for analysis. If you may, you can use them too as there are.
Extract the contents of the zip-file into folder z-way-server/htdocs/smarthome/user. If you have a prior version installed, delete it first, because filenames have changed. In case of lack of space, you can remove what you don't need.
Start with: http://<your ip>:8083/smarthome/user/MxInfo/ in your browser and tap on the html-files. Although they are stand-alone-tools, some of them need to be logged in first as administrator via smarthome UI.
Of course I cannot develop universal software, if I know only my own configuration. If it doesn't run on your configuration, I would need yours for analysis.
Latest changes:
- added cases for some configuration specialities.
- made it run on Edge (was developed for Firefox)
- made it run for unknown browser languages (default: English)
Most important changes 2019-07-13:
- added CronDelays.html: to check for delays in z-way application >= 1 minute (in combination with special Cron/index.js contained in sysmodules_changed (2.3.7 + 2.3.8)
- enhanced Dependencies.html: classification of devices (orphaned, missing, failed...)
- enhanced: CronTasks.html
- enhanced: Routes.html
MxInfo_2019-07-13.zip
(357.58 KiB) Downloaded 13 times
Raspbian GNU/Linux 9 (stretch)
Z-Way version v2.3.8 from 2018-10-10 00:47:52 +0300 (build 854d8c466afa676694043ff7a9d17febb3bb01d6)
Re: MxInfo tool collection
Post by PoltoS » 03 Mar 2019 12:21
Nice tool. May be it is worth to make it as an app. The app will do nothing but add those files under module htdocs
piet66
Post by piet66 » 13 Jul 2019 12:41
Uploaded version 2019-07-13 of MxInfo tools.
Post by PoltoS » 14 Jul 2019 13:55
May be you can publish it on developers.z-wave.me ?
piet66
Post by piet66 » 18 Jul 2019 19:36
Can you give some hints how to add the files under module htdocs by app?
Post by PoltoS » 18 Jul 2019 23:34
Static files can be hosted in the module htdocs and can be accessed via http://IP:8083/ZAutomation/api/v1/modul ... <file_name>
piet66
Post by piet66 » 19 Jul 2019 11:52
I think the correct link must be http://IP:8083/ZAutomation/api/v1/load/ ... file name>
But it doesn't work as I want, cause libraries from subfolders are not loaded.
