zunoSendReport in the Setup routine
aleconakad
Post by aleconakad »
I want in my sketch to revert the relays defined in channel 1 to 3 to the default state after a restart event. I do it like this:
void setup() {
relais1_state = 0;
relais2_state = 0;
relais3_state = 0;
zunoSendReport (1);
zunoSendReport (2);
zunoSendReport (3);
void loop() {
byte relais1_getter() {
  if (relais1_state) {
    return ZUNO_SWITCHED_ON;
  } else {
    return ZUNO_SWITCHED_OFF;
byte relais2_getter() {
  if (relais2_state ) {
  } else {
byte relais3_getter() {
  if (relais3_state ) {
  } else {
is this allowed? does it have any side effects? will the Z-Wave stack be fully initialized before running code from the setup() routine?
thanks
Re: zunoSendReport in the Setup routine
No! As stated in the documentation, setup () bus only for hardware initialization.
Define a variable book firstBoot = True and in the loop:
if (firstBoot) { firstBoot = false; zunoSendReport(....); ... }
