Why does the wire library disregard the restart option
petemilligan
Post by petemilligan »
All,
Having worked with a rather fussy I2C component. I need to use a restart, rather than a stop.
I've looked at the wire.c library supplied, but whilst the stop param is supplied, it doesn't seem to be used. Any theories behind this?
uint8_t TwoWire::endTransmission(uint8_t stop)
    // We already stopped I2C
    if(state == STATE_TRANSMITION_STOPPED)
        return sucess_code;
    // We have to send one byte if user dind't do it...
    if(state == STATE_TRANSMITION_INIT)
        p_driver->start();
        if(!p_driver->write(txAddress))
            sucess_code |= NACK_ON_ADDRESS;
    // We have open connection for reading bytes
    // Some devices will have bad inner state if we don't say "NACK"
    // at the end.
    if((state == STATE_TRANSMITION_READMODE) && (sucess_code == 0) && available_bytes)
        // Send NACK
        p_driver->read(0x00);
    // Send stop sequence
		p_driver->stop();
		state = STATE_TRANSMITION_STOPPED;
    return sucess_code;
Thanks,
Pete
p0lyg0n1
Re: Why does the wire library disregard the restart option
Post by p0lyg0n1 »
There is no difference between stop&start sequence and restart() in this realization of I2C. This realization is fully synchronous and does the start/stop sequence when you call appropriate function. Please try it with your device this way:call
endTransmission() and then start the transmission once more using beginTransmissio(...) or requestFrom(...).
petemilligan
I really need a restart like this: (this is standard Arduino Wire library)
petemilligan
I get a restart with Z-Uno like this:
The device is an MMA8452Q XYZ. The 1st example works fine, I cannot get the Z-Uno to replicate using the supplied libraries. Please help.
Thanks,
Pete
petemilligan
Messy but working. Bit banged a restart & then told Wire library that we're in a STOPPED state;
  Wire.beginTransmission(0x1D);
  Wire.write(0X0D); //WHO_AM_I
  //Wire.endTransmission(false);
        digitalWrite(10, HIGH); //sda
        delayMicroseconds(5);
        digitalWrite(9, HIGH); //scl
        digitalWrite(10, LOW); //sda
        digitalWrite(9, LOW); //scl
        Wire.stateStop(); // temporary workaround to enable requestFrom to write txAddress
 Wire.requestFrom(0x1D, 1);
 if (Wire.available()) {
      byte c = Wire.read();
  Wire.endTransmission();
Function in Wire.cpp;
void TwoWire::stateStop(void)
Results in correct communication.
Perhaps this helps to diagnose the problem when communicating with these devices.
Pete
