2.1.5 - failing to load sketch
Cyberax
Post by Cyberax »
Hi!
Since upgrading a board to 2.1.5 I'm consistently getting CRC errors while uploading a sketch. Only about 5% of uploads work, if that. Tried with various security levels, frequences, multi-command settings. Tried recovery mode - same result.
I tried different USB cables and for some of my cables the board is not even registering as a USB serial device (it gets power, though).
Errors look like this:
Openning port                            ..............................
Openning port                            ..............................                            OK
RAW Info:
 AA AA BB BB 01 15 01 10
 00 01 02 0F 7B 5E B5 79
 02 7F C6 62 83 7F FF 7F
 FC 01 15 02 0F 4C A3 01
 03 16 12 FF FF FF FF FF
 FF FF FF FF FF FF FF FF
 FF FF FF 0F 11 06 0A 0B
 16 01 F3 00 02 1E
                     FIRMWARE DATA
	REVISION:02.15
	Z-WAVE FREQUENCY:US
	ORIGINAL FW. CRC32: 7B 5E B5 79
	MAXIMUM CODE SIZE: 30 KB
	CURRENT  FW. CRC16: 4C A3
	RADIO CHANNELS: 02
                     HARDWARE DATA
	CALIBRATION
		MAIN:03 TX: 16 12
	DEVICE PUBLIC KEY:
		HEX: 8D AC 75 87 8C 1E D4 9D 27 6A 61 EE D1 EC 8D D6 1A EF 70 C6 DA C5 AE 3F 84 26 96 36 93 9E C7 26
		DEC: 36268-30087-35870-54429-10090-25070-53740-36310-06895-28870-56005-44607-33830-38454-37790-50982
                     PRODUCTION DATA
	YOUR ZUNO S/N: 0F 11 06 0A 0B 16 01 00 02
	PRODUCTION TIME:
		WEEK:15 YEAR:2017
	WORKSTATION:
		NUMBER:1 SEQUENCE:2838
	HARDWARE:
		CHIP:1546 REVISION:2
Writing NVM data                         [>                                                 ] (0%)
Writing NVM data                         [=================================================>] (99%)
Writing NVM data                         ..............................                            OK
          Sketch crc16:5ff9 size:118d (4.39 kB)
Pushing sketch                           ..............................
Error  0	 Can't upload sketch! Something went wrong. Bad CRC16 :'( .
Reseting chip                            ..............................
Reseting chip                            ..............................                            OK
Closing port                             ..............................
Closing port                             ..............................                            OK
ELAPSED:1.18378901482s
Re: 2.1.5 - failing to load sketch
Hello!
We have solved this - please remote the package from Arduino IDE, remove the z-uno files in staging folder and install the package again. Should solve the problem!
asivanes
Post by asivanes »
I cannot upload the MotionSensor Sketch or any other .
How can I remove the Z-Uno packages in Arduino and reload this as suggested in the earlier forum
Thank You
The reply is retty old. Please get the new version in Board Manager and do burn the bootloader. What is the error you are seeing?
