Only get values from one channel (have two channels)
splitfile
Post by splitfile »
I'm trying to get the Zuno to work as a sensor with two channels. The sensor reports back power values. Watts and KWh (Kilo watt hours).
The problem is that I seem to only get values on one channel.
Maybe I'm not setting the channels up correctly? I read something about some issue if you have two channels with the same type?
All help appreciated :-)
#define DEBUG       1
// LED pin number
#define LED_PIN     13
// button pin number
#define BTN_PIN     18
// channel number
#define ZUNO_CHANNEL_NUMBER_ONE   1
#define ZUNO_CHANNEL_NUMBER_TWO   2
// Number of blinks per kWh of your meter
#define PULSE_FACTOR 1000
// Pulses per watt hour
float ppwh = ((float)PULSE_FACTOR)/1000;
// The value to report back to controller
//unsigned int kWh;
// Counting the light pulse
volatile uint32_t pulseCount = 0;
volatile uint32_t lastBlink = 0;
volatile uint32_t watt = 0;
volatile uint32_t watt_dummy = 0;
// next macro sets up the Z-Uno channels
// you can read more on http://z-uno.z-wave.me/Reference/ZUNO_SENSOR_BINARY/
ZUNO_SETUP_CHANNELS(
      // CHANNEL 1
      ZUNO_METER(ZUNO_METER_TYPE_ELECTRIC,
                 METER_RESET_ENABLE,
                 ZUNO_METER_ELECTRIC_SCALE_KWH,
                 METER_SIZE_FOUR_BYTES,
                 METER_PRECISION_ZERO_DECIMALS,
                 get_kwh,
                 reset_kwh
      // CHANNEL 2
                 METER_RESET_ENABLE,
                 ZUNO_METER_ELECTRIC_SCALE_WATTS,
                 get_watt,
                 reset_watt
// Set the interrupt callback function
ZUNO_SETUP_ISR_INT0(onPulse);
void setup()
  // Enable interrupt. Triggered when light pulse is detected
  zunoExtIntMode(ZUNO_EXT_INT0, RISING);
void loop()
#ifdef DEBUG
  Serial.println("Sending on channel 1");
#endif
  zunoSendReport(ZUNO_CHANNEL_NUMBER_ONE); // send report over the Z-Wave to the controller
#ifdef DEBUG
  Serial.println("Sending on channel 2");
#endif
  zunoSendReport(ZUNO_CHANNEL_NUMBER_TWO); // send report over the Z-Wave to the controller
  delay(35000); //sleep 35s
// function, which returns the previously saved button state
// this function runs only once the controller asks
uint32_t get_kwh()
#ifdef DEBUG
  Serial.print("get_kwh called, returned ");
  Serial.println(watt, DEC);
#endif
  // just return the pulseCount as a debug value
  return pulseCount;
void reset_kwh()
  Serial.println("reset_kwh() called");
void onPulse()
  #ifdef DEBUG
    Serial.println("onPulse! - Light pulse detected");
  #endif
  uint32_t newBlink = millis();
  uint32_t interval = newBlink - lastBlink;
  #ifdef DEBUG
    Serial.print("newBlink(");
    Serial.print(newBlink, DEC);
    Serial.print(") - lastblink(");
    Serial.print(lastBlink, DEC);
    Serial.print(") = interval(");
    Serial.print(interval, DEC);
    Serial.println(")");
  #endif
   watt = (3600000.0 / interval) / ppwh;
   lastBlink = newBlink;
  pulseCount++;
#ifdef DEBUG
  Serial.print("Count:");
  Serial.println(pulseCount, DEC);
  Serial.print("onPulse! - watt:");
  Serial.println(watt, 3);
#endif
uint32_t get_watt()
  watt_dummy++;
  #ifdef DEBUG
    Serial.print("get_watt called, returned ");
    Serial.println(watt_dummy, DEC);
  #endif
  return watt_dummy;
void reset_watt()
Re: Only get values from one channel (have two channels)
What is your controller?
rkv
Post by rkv »
There are no problems. Code works fine with Razberry.
splitfile
Post by splitfile »
Hi guys,
Thanks for your response!
I'm using Domoticz and a "Aeotec by Aeon Labs Z-Stick" -USB controller.
I think I got it to work setting up the channels like this:
  ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_POWER,
                         SENSOR_MULTILEVEL_SCALE_WATT,
                         SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS,
                         get_watt),
             METER_RESET_ENABLE,
             METER_PRECISION_TWO_DECIMALS,
             get_kwh,
             reset_kwh)
Did you do it in another way?
Best regards!
Looks like a Domoticz bug that they do not recognize meters in channels without a special template. You "hacked" it by making one as sensor. Good job!
