GoControl Thermostat & CO Sensor
randy54
Post by randy54 » 13 Jul 2019 23:19
These are the products I am referring to:
Thermostat: https://www.z-wave.com/shop-z-wave-smar ... thermostat
CO/Smoke sensor: https://www.amazon.com/First-Alert-Dete ... B00KMHXFAI
Does anyone have any experience controlling and gathering feedback from these with a Z-uno and/or the Z-way HTTP API?
I want to be able to control these with source code uploaded onto my Z-uno. The thermostat can establish a direct line to the Z-uno but the CO sensor cannot. How should I go about trying to get each of the devices to listen to the Z-uno's source code between the channels concept, association concept, and the HTTP API?
Re: GoControl Thermostat & CO Sensor
Post by PoltoS » 18 Jul 2019 23:46
Z-Uno can listen for reports. Then you can send information to the thermostat. Unfortunatelly only Basic Set can be sent from Z-Uno to the thermostat. But with Z-Uno you can even send any command, so you can construct your Thermostat command "manually". But I've not really understood how do you want to link them all
