Failure including Aeotec Door/Window sensor Gen 5
peotidbit
Post by peotidbit »
Controller Info
Role in Network
Node Id: 1
Home Id: 0xc2633b1b
Primary Role: Yes
Primary Capability: Yes
SUC/SIS in network: 1 (SIS)
Hardware
Vendor: RaZberry by Z-Wave.Me
Vendors Product ID: 1024 / 2
Z-Wave Chip: ZW0500
Firmware
SDK Version: 6.51.06
Serial API Version: 05.04
Capabillities:
UUID: e590a2d01ba8af882bc17518ed0f6235
Subvendor: 0x0000
Nodes limit: Unlimited
Capabillities: SlM
Software Information
Version number: v2.3.8-rc4
Compile-ID: ce993868a517f5717ecdbedd5f536c4a5c245eac
Compile-Date: 2018-07-02 18:52:03 +0300
UI
UI version 1.3.3
Built date 30-06-2018 03:48:42
uzb
2016-09-09 5.4 Update bootloader to 8aaa
2017-01-27 5.4 5.7 Update firmware from 5.04 to 5.07
z-way-server.log
exclude device - Aeotec Door/Window sensor Gen 5 ZW120-C 868.42 MHz (EU)
[2019-07-19 19:20:10.534] [zway] Adding job: Remove node from network
[2019-07-19 19:20:10.537] [D] [zway] SENDING (cb 0x02): ( 01 05 00 4B C1 02 72 )
[2019-07-19 19:20:10.538] [D] [zway] RECEIVED ACK
[2019-07-19 19:20:10.547] [D] [zway] RECEIVED: ( 01 07 00 4B 02 01 00 00 B0 )
[2019-07-19 19:20:10.547] [D] [zway] SENT ACK
[2019-07-19 19:20:10.547] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2019-07-19 19:20:10.547] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2019-07-19 19:20:10.547] [zway] Job 0x4b (Remove node from network): Ready to remove - push button on the device to be removed
[2019-07-19 19:20:10.547] [D] [zway] SETDATA controller.data.controllerState = 5 (0x00000005)
[2019-07-19 19:20:14.541] [D] [zway] RECEIVED: ( 01 07 00 4B 02 02 00 00 B3 )
[2019-07-19 19:20:14.541] [D] [zway] SENT ACK
[2019-07-19 19:20:14.541] [zway] Job 0x4b (Remove node from network): Node found: #0
[2019-07-19 19:20:14.541] [D] [zway] SETDATA controller.data.controllerState = 6 (0x00000006)
[2019-07-19 19:20:14.541] [D] [zway] SETDATA controller.data.lastExcludedDevice = 0 (0x00000000)
[2019-07-19 19:20:15.643] [D] [zway] RECEIVED: ( 01 18 00 4B 02 03 00 11 04 07 01 5E 86 72 85 59 73 71 84 30 80 70 7A EF 5A 41 )
[2019-07-19 19:20:15.643] [D] [zway] SENT ACK
[2019-07-19 19:20:15.644] [zway] Job 0x4b (Remove node from network): Removing slave: #0
[2019-07-19 19:20:15.644] [D] [zway] SETDATA controller.data.controllerState = 7 (0x00000007)
[2019-07-19 19:20:15.644] [D] [zway] SETDATA controller.data.lastExcludedDevice = 0 (0x00000000)
[2019-07-19 19:20:15.653] [D] [zway] RECEIVED: ( 01 18 00 4B 02 06 00 11 04 07 01 5E 86 72 85 59 73 71 84 30 80 70 7A EF 5A 44 )
[2019-07-19 19:20:15.653] [D] [zway] SENT ACK
[2019-07-19 19:20:15.653] [zway] Job 0x4b (Remove node from network): Done
[2019-07-19 19:20:15.653] [D] [zway] Job 0x4b (Remove node from network): success
[2019-07-19 19:20:15.654] [zway] Removing job: Remove node from network
[2019-07-19 19:20:15.654] [zway] Adding job: Remove node from network
[2019-07-19 19:20:15.654] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2019-07-19 19:20:15.654] [D] [zway] SENDING (cb 0x00): ( 01 05 00 4B 05 00 B4 )
[2019-07-19 19:20:15.663] [D] [zway] RECEIVED ACK
[2019-07-19 19:20:15.663] [zway] Job 0x4b (Remove node from network): Stop done
[2019-07-19 19:20:15.663] [D] [zway] Job 0x4b (Remove node from network): success
[2019-07-19 19:20:15.663] [zway] Removing job: Remove node from network
[2019-07-19 19:20:15.663] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2019-07-19 19:20:35.800] [D] [zway] Job 0x4b: deleted from queue
[2019-07-19 19:20:35.801] [D] [zway] Job 0x4b: deleted from queue
include device
[2019-07-19 19:22:06.438] [zway] Adding job: Add/re-include node to network
[2019-07-19 19:22:06.447] [D] [zway] SENDING (cb 0x03): ( 01 05 00 4A C1 03 72 )
[2019-07-19 19:22:06.448] [D] [zway] RECEIVED ACK
[2019-07-19 19:22:06.457] [D] [zway] RECEIVED: ( 01 07 00 4A 03 01 00 00 B0 )
[2019-07-19 19:22:06.457] [D] [zway] SENT ACK
[2019-07-19 19:22:06.457] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2019-07-19 19:22:06.457] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2019-07-19 19:22:06.458] [I] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2019-07-19 19:22:06.458] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
stop
[2019-07-19 19:26:09.759] [I] [zway] Removing job: Add/re-include node to network
[2019-07-19 19:26:09.760] [I] [zway] Adding job: Add/re-include node to network
[2019-07-19 19:26:09.762] [D] [zway] SENDING (cb 0x00): ( 01 05 00 4A 05 00 B5 )
[2019-07-19 19:26:09.763] [D] [zway] RECEIVED ACK
[2019-07-19 19:26:09.763] [I] [zway] Job 0x4a (Add/re-include node to network): Stop done
[2019-07-19 19:26:09.763] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2019-07-19 19:26:09.764] [I] [zway] Removing job: Add/re-include node to network
[2019-07-19 19:26:09.764] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2019-07-19 19:26:29.898] [D] [zway] Job 0x4a: deleted from queue
[2019-07-19 19:26:29.912] [D] [zway] Job 0x4a: deleted from queue
[2019-07-19 19:27:12.649] [I] [zway] Saving configuration data to config/zddx/c2633b1b-DevicesData.xml
[2019-07-19 20:27:12.665] [I] [zway] Saving configuration data to config/zddx/c2633b1b-DevicesData.xml
[2019-07-19 21:27:12.667] [I] [zway] Saving configuration data to config/zddx/c2633b1b-DevicesData.xml
Re: Failure including Aeotec Door/Window sensor Gen 5
You are not asking for anything, but I would assume you have to correctly triple click on the door sensor
peotidbit
Post by peotidbit »
This sensor have an action button to click only once. Excluding works with one click, but including fails. Any ideas?
Excluding works on simple click because the NIF is sent. But inclusion usually requires triple click
peotidbit
Post by peotidbit »
I've tried tripple click as well, but still with failure. Anything I can do to get more info?
Please read the manual about how to click to add to the network. Use this sequence to first remove and then add to the network
peotidbit
Post by peotidbit »
Please specify which manual. I've done this before with an older version of z-way. Now I have updated to the latest.
This is not in Z-Way, but in the device. Please check the manual of the device.
peotidbit
Post by peotidbit »
I'm following the device manual. Steps 5 and 6. See attachement.
aeontec-ZW120-C-manual (1).jpg (43.4 KiB) Viewed 9176 times
In that case follow the reset procedure mentioned in the sensor manual
