Telegram Bot
marco
Telegram Bot
Post by marco »
Hi all,
I use raspberry platform with razberry.
I usually spend some time to check new stuff so I've tested also Telegram bot too. I tested it with v2.3.7, v2.3.8 and now with v3.0.0 release. Every time, I have the same results:
"something went wrong",
"Cannot instantiate module: Zway-Telegram-Bot: TypeError: undefined is not a function".
Well, let me try to recap.
At first, I found this interesting project
https://github.com/CopyCat73/Zway-Telegram-Bot
so I cloned it in /opt/z-way-server/automation/modules and I've prepared bot on telegram as per instructions and as usual.
Rebooted z-way server I was able to see the new app between LocalApps but when I tried to instantiate it pushing on save button, the error appeared.
So I googled searching for a solution.
These posts
https://github.com/maros/Zway-InfluxDbStats/issues/2
https://github.com/maros/Zway-BaseModul ... /README.md
pushed me, as described referring to BaseModule, to edit and modify the index.js and module.json files directly.
Same results.
Just to attempt, I tried also this
https://github.com/CopyCat73/Zway-Teleg ... e7f33d2b28
Of course, the same results.
Now I'm here to ask if anyone of you have an idea to make the bot working. Do you have?
Thanks,
Marco
Marco
Re: Telegram Bot
The easiest is to look in the log to see the line where the problem occurs. The error happens because something is called, but not defined.
like some.thing(...), where thing is not defined.
marco
Re: Telegram Bot
Post by marco »
Thanks Poltos for your quick reply.
This is what log reports (I already checked at it).
[2019-08-01 08:37:21.458] [core] Notification: error (core): Cannot instantiate module: Zway-Telegram-Bot: TypeError: undefined is not a function
[2019-08-01 08:37:21.469] [core] TypeError: undefined is not a function
at AutomationController.instantiateModule (automation/classes/AutomationController.js:465:14)
at AutomationController.createInstance (automation/classes/AutomationController.js:936:17)
at ZAutomationAPIWebRequest._.extend.createInstance (automation/ZAutomationAPIProvider.js:1333:31)
at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:263:35)
As we can see it refers to external resources from Telegram module and I don't think there is something to correct in them.
Actually, I can only proceed by attempts on the module files...
Marco
Re: Telegram Bot
Ah, obvious. This means the file name do not match the class name (in the file itself).
In fact looks they match, but it is not allowed to name JavaScript classes with hyphen.
Name it ZwayTelegramBot instead of Zway-Telegram-Bot. Please rename the older and all metions in index.js and module.json.
Re: Telegram Bot
Correction - just rename the folder to TelegramBot instead of Zway-Telegram-Bot. Inside everythin is okey
marco
Re: Telegram Bot
Post by marco »
Correct. Thak you Poltos.
I've just checked and it works for me. Then I can send notifications to my telegram chat from my zway system with the relevant bot.
Now, I'm going to look for sending commands from chat to system...
Hope that CopyCat will upload the module for everybody
Marco
