Update to 3.0 aborted
Froschkoenig
Post by Froschkoenig »
I tried to update to Z-Way 3.0 on a Raspberry Pi 3 Model B. After update to Strech, I followed the instructions for the update Z-Way. However, when I confirm the last step with "Y" the system just prompts "Abort" without any further comment.
Any ideas?
pi@raspberrypi:~ $ sudo apt-get install z-way-full
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
webif z-way-server zbw
The following NEW packages will be installed:
webif z-way-full z-way-server zbw
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 21.5 MB of archives.
After this operation, 1,434 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Abort.
pi@raspberrypi:~ $
Re: Update to 3.0 aborted
Looks like a generic Debian problem. Make sure you are not out of space. Try verbose mode of apt
Froschkoenig
I used apt only instead of apt-get and it worked...
