Z-UNO and Digital door lock inclusion
mamhoo
Post by mamhoo »
Hi all,
I try to start inclusion to add my z-uno and "yale" digital door lock with z-wave module.
I already set both z-uno and razberry to Korea (KR) frequency.
But it's not work.
In vendors list, doesn't have z-wave.me and "yale" z-wave module.
I will show you the z-way-server log in this code below.
[2019-08-27 14:52:26.916] [I] [zway] Removing job: Add/re-include node to network
[2019-08-27 14:52:26.916] [I] [zway] Adding job: Add/re-include node to network
[2019-08-27 14:52:26.925] [D] [zway] SENDING (cb 0x00): ( 01 05 00 4A 05 00 B5 )
[2019-08-27 14:52:26.926] [D] [zway] RECEIVED ACK
[2019-08-27 14:52:26.926] [I] [zway] Job 0x4a (Add/re-include node to network): Stop done
[2019-08-27 14:52:26.926] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2019-08-27 14:52:26.926] [I] [zway] Removing job: Add/re-include node to network
[2019-08-27 14:52:26.926] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2019-08-27 14:52:47.065] [D] [zway] Job 0x4a: deleted from queue
[2019-08-27 14:52:47.075] [D] [zway] Job 0x4a: deleted from queue
[2019-08-27 14:56:22.204] [D] [zway] SETDATA controller.data.secureInclusion = False
[2019-08-27 14:58:19.809] [D] [zway] SETDATA controller.data.secureInclusion = False
[2019-08-27 14:58:25.079] [D] [zway] SETDATA controller.data.smartStart.includingDSK = byte[0]
[2019-08-27 14:58:25.079] [D] [zway]   ( zero-length buffer )
[2019-08-27 14:58:25.080] [I] [zway] Adding job: Add/re-include node to network
[2019-08-27 14:58:25.083] [D] [zway] SENDING (cb 0x08): ( 01 05 00 4A C1 08 79 )
[2019-08-27 14:58:25.085] [D] [zway] RECEIVED ACK
[2019-08-27 14:58:25.086] [D] [zway] RECEIVED: ( 01 07 00 4A 08 01 00 00 BB )
[2019-08-27 14:58:25.087] [D] [zway] SENT ACK
[2019-08-27 14:58:25.087] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2019-08-27 14:58:25.087] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2019-08-27 14:58:25.087] [I] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2019-08-27 14:58:25.087] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
[2019-08-27 14:59:01.635] [I] [zway] Removing job: Add/re-include node to network
[2019-08-27 14:59:01.635] [I] [zway] Adding job: Add/re-include node to network
[2019-08-27 14:59:01.646] [D] [zway] SENDING (cb 0x00): ( 01 05 00 4A 05 00 B5 )
[2019-08-27 14:59:01.649] [D] [zway] RECEIVED ACK
[2019-08-27 14:59:01.649] [I] [zway] Job 0x4a (Add/re-include node to network): Stop done
[2019-08-27 14:59:01.649] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2019-08-27 14:59:01.649] [I] [zway] Removing job: Add/re-include node to network
[2019-08-27 14:59:01.649] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
SDK Version: 6.51.06
Serial API Version: 05.04
Software Version: v3.0.0
Re: Z-UNO and Digital door lock inclusion
For KR you need 3rd channels version of RaZberry - make sure to upgrade the firmware. Z-Uno will ask you to switch to 3ch via bootloader upgrade.
mamhoo
Post by mamhoo »
Hello PaltoS.
I try to update RaZberry firmware from 5.04 to 5.22
After update firmware, the frequency changed from KR/JP to EU/RU/IN/CN.
Can I change the frequency back to KR ?
Please advice.
You need to switch to 3ch firmware. Not all firmwares has it.
5.27 should. Enter token all to see more firmwares
mamhoo
Post by mamhoo »
Thanks for information.
Then how to find that token ?
"all" is the token ;)
mamhoo
Post by mamhoo »
Hi PaltoS, I try to fill all in access token then pass go but nothing shown.
expertUI >>Network >> Controller Info >> Update Firmware >> Fill 'all' at Access Token
Please advice or Can you please send me 5.27 firmware with KR frequency to my email (I will pm you my email) ?
I need to know your firmware. So remote access will do the job
mamhoo
Post by mamhoo »
Okay, I will PM you the username and password for remote access
I just restarted your Z-Wave module (Reset API in the Expert UI and then restart the Z-Wave Binding) and now you see the upgrade to KR.
The problem was that after previous update you had to reboot the Z-Wave module - this is required by the chip after upgrades from old versions.
