LCD - java.lang.NullPointerException
cmpts_cmp
Post by cmpts_cmp »
Hi all,
Complete newbie but I'm using the Z-Uno connected to my Windows 10 PC.
I can program the ZUNO no issue, but when I use the LiquidCrystal library (#include <LiquidCrystal.h>) I get the following error when compiling, not even uploaded yet.
I've done the Burn Bootloader, and general "getting started" tasks, and all went well, but all seems to point to thie LCD library:
--- USING a list of libraries from:
      C:\Users\<USER>\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\2.1.5\libraries
      C:\Users\<USER>\Documents\Arduino\libraries
   *** Collecting prototypes...
Preprocessing file: Custom.c with SDCPP...
Preprocessing file: Blink.cpp with SDCPP...
compilation terminated.
Preprocessor failed!uCxx returned error code:1
exit status 1
processing.app.debug.RunnerException
   at cc.arduino.Compiler.lambda$callArduinoBuilder$3(Compiler.java:309)
   at processing.app.debug.MessageSiphon.run(MessageSiphon.java:96)
   at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NullPointerException
   at cc.arduino.Compiler.message(Compiler.java:525)
   at cc.arduino.i18n.I18NAwareMessageConsumer.message(I18NAwareMessageConsumer.java:80)
   at cc.arduino.MessageConsumerOutputStream.flush(MessageConsumerOutputStream.java:71)
   at cc.arduino.MessageConsumerOutputStream.write(MessageConsumerOutputStream.java:54)
   at java.io.OutputStream.write(OutputStream.java:75)
   at cc.arduino.Compiler.lambda$callArduinoBuilder$3(Compiler.java:307)
   ... 2 more
TIA!
Re: LCD - java.lang.NullPointerException
I fear this library might require quite some adoption.
cmpts_cmp
Post by cmpts_cmp »
Thanks. I think you're right. I'll see if it's possible to "swap" what's used in the sketch and use the ZUNO specific library.
