Backup/restore and remove nodes
Garga
Post by Garga »
For a client I need to split 1 Jeedom to 3 others (Z-wave distance limit), so I bought 3 UZB1 for 3 Raspberries.
I succeeded create a primary controller from the existing Jeedom to one of my Raspberry (the existing Jeedom is now secondary)
Now I want to backup/copy the UZB1 from this Raspberry to the 2 others and delete the nodes not managed by the controller on each but when I loaded Z-way with the usb key, I see only the controller and not all my modules !!!!??? My modules is Eurotronic Spiritz (flirs) and Aeotec Multisensor 6.
The backup doesn't copy the modules not listed.
Why the modules is not presents? Is it a license problem?
Thanx a lot !
Re: Backup/restore and remove nodes
Don't do that. They will all have one home id and all this will not work good. Either do this using one network with one controller and few repeaters. Or different networks and connect controllers via LAN
