Fibaro Walli products - CentralScene problem
michap
Post by michap »
including the Fibaro Walli products all related products (switch, dimmer, roller shutter) have a problem while inclusion with "CentralScene".
Devices will be included, but not 100%, with an error message.
Inexpert view you can see the missing "CentralScene" interview, a force interview will not help.
Log for a force interview (not sure can it help):
[2019-10-07 19:53:18.694] [I] [zway] Using security scheme S2 Authenticated
[2019-10-07 19:53:18.694] [I] [zway] Adding job: CentralScene Supported Get
[2019-10-07 19:53:18.697] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get
[2019-10-07 19:53:18.707] [D] [zway] SENDING (cb 0x8c): ( 01 15 00 13 0E 0E 9F 03 B6 00 70 2E 6F A8 50 3F F8 D4 6C DB 25 8C 17 )
[2019-10-07 19:53:18.708] [D] [zway] Secure payload: ( 5B 01 )
[2019-10-07 19:53:18.710] [D] [zway] RECEIVED ACK
[2019-10-07 19:53:18.717] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-10-07 19:53:18.717] [D] [zway] SENT ACK
[2019-10-07 19:53:18.717] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get): Response received - transfered to encapsulated jobs
[2019-10-07 19:53:18.718] [D] [zway] Delivered to Z-Wave stack
[2019-10-07 19:53:18.775] [D] [zway] RECEIVED: ( 01 07 00 13 8C 00 00 07 60 )
[2019-10-07 19:53:18.775] [D] [zway] SENT ACK
[2019-10-07 19:53:18.775] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get): Callback received - transfered to encapsulated jobs
[2019-10-07 19:53:18.775] [I] [zway] Job 0x13 (CentralScene Supported Get): Delivered
[2019-10-07 19:53:18.775] [D] [zway] SendData Response with callback 0x8c received: received by recipient
[2019-10-07 19:53:18.776] [D] [zway] Job 0x13 (CentralScene Supported Get): success
[2019-10-07 19:53:18.776] [I] [zway] Waiting for job reply: CentralScene Supported Get
[2019-10-07 19:53:18.776] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get): Delivered
[2019-10-07 19:53:18.776] [D] [zway] SendData Response with callback 0x8c received: received by recipient
[2019-10-07 19:53:18.777] [D] [zway] SETDATA devices.14.data.lastSendInternal = **********
[2019-10-07 19:53:18.777] [D] [zway] SETDATA devices.14.data.lastSend = 10655880 (0x00a29888)
[2019-10-07 19:53:18.777] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get): success
[2019-10-07 19:53:18.777] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get
[2019-10-07 19:53:18.861] [D] [zway] RECEIVED: ( 01 17 00 04 00 0E 11 9F 03 62 00 2E E5 D3 A1 4A 8E 64 DC 6F 87 AC 47 D1 1A )
[2019-10-07 19:53:18.861] [D] [zway] SENT ACK
[2019-10-07 19:53:18.861] [D] [zway] SETDATA devices.14.data.lastReceived = 0 (0x00000000)
[2019-10-07 19:53:18.862] [I] [zway] Node 14:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 5b 02 02 83 1f ]
[2019-10-07 19:53:18.862] [D] [zway] Received reply on job (CentralScene Supported Get)
[2019-10-07 19:53:18.863] [D] [zway] SETDATA devices.14.instances.0.commandClasses.91.data.maxScenes = 2 (0x00000002)
[2019-10-07 19:53:18.863] [E] [zway] Error returned from zdata_set_integer_array(sceneDH, v1SupportedKeyAttributes, count): Bad arguments (-1)
[2019-10-07 19:53:18.863] [D] [zway] SETDATA devices.14.instances.0.commandClasses.91.data.slowRefreshSupport = True
[2019-10-07 19:53:18.863] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7 = Empty
[2019-10-07 19:53:18.863] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.status = Empty
[2019-10-07 19:53:18.863] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.duration = Empty
[2019-10-07 19:53:18.863] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.moreStatusUpdates = Empty
[2019-10-07 19:53:18.864] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.lastEvent = Empty
[2019-10-07 19:53:18.864] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.status = 255 (0x000000ff)
[2019-10-07 19:53:18.864] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.duration = 0 (0x00000000)
[2019-10-07 19:53:18.864] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.moreStatusUpdates = False
[2019-10-07 19:53:18.864] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.lastEvent = 10655889 (0x00a29891)
[2019-10-07 19:53:18.864] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7 = Empty
[2019-10-07 19:53:18.864] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.lastSession = 7 (0x00000007)
[2019-10-07 19:53:18.864] [I] [zway] Using security scheme S2 Authenticated
[2019-10-07 19:53:18.864] [I] [zway] Adding job: CentralScene Configuration Set
[2019-10-07 19:53:18.864] [C] [zway] Job is already marked as waiting for reply, Supervision overrides it - check encapsulated packet not to be a Get
[2019-10-07 19:53:18.865] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set
[2019-10-07 19:53:18.882] [D] [zway] SENDING (cb 0x8d): ( 01 1A 00 13 0E 13 9F 03 B7 00 00 5E E4 44 B0 D7 B3 3E 4B 5C 3A 00 90 D5 C9 25 8D DD )
[2019-10-07 19:53:18.882] [D] [zway] Secure payload: ( 6C 01 87 03 5B 04 80 )
[2019-10-07 19:53:18.884] [D] [zway] RECEIVED ACK
[2019-10-07 19:53:18.892] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-10-07 19:53:18.892] [D] [zway] SENT ACK
[2019-10-07 19:53:18.892] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set): Response received - transfered to encapsulated jobs
[2019-10-07 19:53:18.892] [D] [zway] Delivered to Z-Wave stack
[2019-10-07 19:53:18.893] [D] [zway] Delivered to Z-Wave stack
[2019-10-07 19:53:18.982] [D] [zway] RECEIVED: ( 01 07 00 13 8D 00 00 09 6F )
[2019-10-07 19:53:18.983] [D] [zway] SENT ACK
[2019-10-07 19:53:18.983] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set): Callback received - transfered to encapsulated jobs
[2019-10-07 19:53:18.983] [I] [zway] Job 0x13 (CentralScene Configuration Set): Delivered
[2019-10-07 19:53:18.983] [D] [zway] SendData Response with callback 0x8d received: received by recipient
[2019-10-07 19:53:18.983] [D] [zway] Job 0x13 (CentralScene Configuration Set): success
[2019-10-07 19:53:18.983] [I] [zway] Waiting for job reply: CentralScene Configuration Set
[2019-10-07 19:53:18.983] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set): Delivered
[2019-10-07 19:53:18.984] [D] [zway] SETDATA devices.14.data.lastSendInternal = **********
[2019-10-07 19:53:18.984] [D] [zway] SETDATA devices.14.data.lastSend = 10655900 (0x00a2989c)
[2019-10-07 19:53:18.984] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set): success
[2019-10-07 19:53:18.984] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set
[2019-10-07 19:53:19.077] [D] [zway] RECEIVED: ( 01 17 00 04 00 0E 11 9F 03 63 00 A5 D5 A9 AB 5E 98 F6 F5 69 28 12 20 80 48 )
[2019-10-07 19:53:19.078] [D] [zway] SENT ACK
[2019-10-07 19:53:19.078] [D] [zway] SETDATA devices.14.data.lastReceived = 0 (0x00000000)
[2019-10-07 19:53:19.079] [I] [zway] Node 14:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 6c 02 07 00 00 ]
[2019-10-07 19:53:19.079] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.status = 0 (0x00000000)
[2019-10-07 19:53:19.079] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.duration = 0 (0x00000000)
[2019-10-07 19:53:19.079] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.moreStatusUpdates = False
[2019-10-07 19:53:19.079] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7.lastEvent = 10655910 (0x00a298a6)
[2019-10-07 19:53:19.079] [D] [zway] SETDATA devices.14.instances.0.commandClasses.108.data.7 = Empty
[2019-10-07 19:53:19.079] [D] [zway] Received reply on job (CentralScene Configuration Set)
[2019-10-07 19:53:19.079] [W] [zway] Node 14:0 CC Supervision: Setter was not supported by the recepient: CentralScene Configuration Set
Michael
Re: Fibaro Walli products - CentralScene problem
Need more logs (from inclusion) to see if CentralScene.data.sceneSupportedKeyAttributesMask was created.
michap
Post by michap »
Sorry for delay, device was busy while testing with other gateways ;)
Attached the log, made a controller reset before and included from /smarthome/ UI.
In Expert UI the missing CentralScene is visible, a force didn't help (see log)
Thanks,
Michael
walli_switch.log.gz
created in v 3.0.0.0
(81.76 KiB) Downloaded 418 times
