"missing" Battery Devices after reinstallation
Jarry
Post by Jarry »
Hi together,
last night my SD Card in my Raspi 2 died.
After reinstallation (and upgrade to a Pi3 and v3.0.0) the system can not communicate with my battery powered devices (Fibaro smoke sensor, Aeotec wallmote and nodon Wallswitch).
I had the chance to use an older backup, and all devices were found in general, but all with generic names like "BatteryDevice _10"
Even the mains-operated devices had the same problem, but with a "force Interview" everything went fine. Even a battery operated Danfoss Radiator Valve Thermostat went fine.
But no chance with the other battery devices. Maybe a complete exclusion/inclusion cycle will help, but this is only the last option, because of all scenes, and groups needs to be adjusted afterwards.
Any ideas?
best regards
Jarry
Re: "missing" Battery Devices after reinstallation
This means you lost all data if smart home. Please restore the backup from smarthome
Jarry
Post by Jarry »
i already restored it from the backup,
but this was the outcome. all details about all devices were lost. for the mains powered devices, i had the chances to "relearn" all details, but most of the battery powered devices, will not "talk" to the base, even when they are awake
nakasa
Post by nakasa »
Jarry wrote: ↑
13 Oct 2019 20:58
Hi buddy, I guess the data backup was not completed before this breakdown. Sadly there is no chance to get back most probably.
Regards,
Nasaka Smith
