DynamicDS18B20.sample ino error
10der
Post by 10der »
Build options changed, rebuilding all
POINTER:5
!! too many values to unpack
	C:\Users\olegd\AppData\Local\Temp\build4753144882472535281.tmp/DynamicDS18B20.cpp
Preprocessing file: Custom.c with SDCPP...
Traceback (most recent call last):
  File "uCxx.py", line 7842, in compileArduinoSketch
  File "uCxx.py", line 6697, in makeZWaveTemplate
ValueError: too many values to unpack
In file included from Stream.cpp:26:
/Arduino.h:16:25: fatal error: Custom_defs.h: No such file or directory
compilation terminated.
Preprocessor failed!uCxx returned error code:1
Error compiling.
Re: DynamicDS18B20.sample ino error
Is it with examples from Z-Uno?
wiredways
Post by wiredways »
Getting a similar error just trying to compile the example sketch included with the z-uno install. Any thoughts on the cause?
Arduino: 1.8.13 (Mac OS X), Board: "Z-Wave>ME Z-Uno, USA, Disabled, Disabled, Disabled, Disabled"
DynamicDS18B20.ino
--- USING a list of libraries from:
/Users/Brian/Library/Arduino15/packages/Z-Uno/hardware/zw8051/2.1.6/libraries
/Users/Brian/Documents/Arduino/libraries
*** Collecting prototypes...
File "/private/tmp/zuno-packager/build/zuno_toolchain-00.08.82-macosx/build/compiler/out00-PYZ.pyz/uCxx", line 7881, in compileArduinoSketch
File "/private/tmp/zuno-packager/build/zuno_toolchain-00.08.82-macosx/build/compiler/out00-PYZ.pyz/uCxx", line 6735, in makeZWaveTemplate
Print_sdcpp_.cpp:543:17:warning:& has lower precedence than ==; == will be evaluated first
exit status 1
Error compiling for board Z-Wave>ME Z-Uno.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
