RaZberry + Danfos Z-Wave
vachah
Post by vachah »
Hello, I'm not able to find how to get working "automation" with RaZberry and Danfos Z-Wave valve.
I finished upgrading my Raspberry with RaZberry hat and already intalled the defined SW.
The web server is running on IP 10.20.0.12:8083 and is working fine. I already connected RaZberry with Danfoss Living Connect Z.
I'm also able to remotelly set the concrete temperature. Also I set the time schedule using "Heating control" component. The control is set to "time-controlled".
I can't find any other parameter to be set any more.
But after all - the system is not working automatically. It only react if I go to web interface and manually change the temperature. And second - if I manually increase temperature it is lower down in definned time. But it never goes up.
Any recommendation for me?
Thanks a lot!
Re: RaZberry + Danfos Z-Wave
We will check this app
