Select Device Description: unique id for description
piet66
Post by piet66 »
A little nuisance at selecting device description: for some devices there exist several descriptions with same or similar name and different contents. In such cases it's difficult to find the right one. You must look through all descriptions and it's not clear which you have already checked and which not.
And for the next device of the same type you have the same difficulty again, because you can't remember, which was the right one.
Best solution would be to add the version number. But I don't know whether it's possible.
Proposal: add a unique id to the description names (running number or checksum). Then you can see. what you already have checked and discarded and you can remember this entry for other devices.
Raspbian GNU/Linux 10 (buster)
RaZberry by Z-Wave.Me ZW0500 6.82.01 05.39/35498 1024/2
Z-Way version v3.2.3 from 2022-04-06 04:56:23 +0300
Re: Select Device Description: unique id for description
noted
cbnidk
Post by cbnidk »
Hi
Select Device Description is not up to date any more I am missing the
Fibaro
Univeral Binary Sensor FGBS-001
Fibaro
Double Relay Switch FGS-222
this 2 divice is not in the Select Device Description in ver. 3.0.3
can this be fix?
and is it somthing I can do by my self?
Claus
You can do those files yourself, but in fact they don't affect anything but Config parameters description and a nice picture in expert ui
