Interviews start disappearing
ridewithstyle
Post by ridewithstyle »
Hi there,
since the upgrade to 3.0 some of my devices start losing interviews. I have multiple Eurotronic Spirit Plus and Komforthaus SpiritPlus (7 to be exact)
1.
One of them suddenly "lost" the security interview and fail to do a new interview cycle
Can't find anything special in the log once I try it
[2020-02-02 15:48:31.617] [D] [zway] SETDATA devices.58.data.lastReceived = 0 (0x00000000)
[2020-02-02 15:48:31.617] [I] [zway] Node 58:0 CC Security: sending Nonce Report
[2020-02-02 15:48:31.617] [D] [zway] SETDATA devices.58.data.isAwake = True
[2020-02-02 15:48:31.617] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2020-02-02 15:48:31.618] [I] [zway] Removing job: Wakeup Sleep
[2020-02-02 15:48:31.618] [W] [zway] Can not detect if this is a request or set/report - don't expect a reply
[2020-02-02 15:48:31.618] [I] [zway] Adding job: Nonce Report
[2020-02-02 15:48:31.619] [D] [zway] SENDING (cb 0xb4): ( 01 11 00 13 3A 0A 98 80 E4 17 EE 85 F2 77 D8 37 05 B4 96 )
[2020-02-02 15:48:31.622] [D] [zway] RECEIVED ACK
[2020-02-02 15:48:31.625] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-02-02 15:48:31.625] [D] [zway] SENT ACK
[2020-02-02 15:48:31.625] [D] [zway] Delivered to Z-Wave stack
[2020-02-02 15:48:31.856] [I] [core] [BaseModule-21] Set lastLevel to 10.37 for Astronomy_153_altitude (was 10.49)
[2020-02-02 15:48:31.960] [D] [zway] RECEIVED: ( 01 07 00 13 B4 00 00 21 7E )
[2020-02-02 15:48:31.960] [D] [zway] SENT ACK
[2020-02-02 15:48:31.961] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2020-02-02 15:48:31.961] [D] [zway] SendData Response with callback 0xb4 received: received by recipient
[2020-02-02 15:48:31.961] [D] [zway] SETDATA devices.58.data.lastSendInternal = **********
[2020-02-02 15:48:31.961] [D] [zway] SETDATA devices.58.data.lastSend = 51048 (0x0000c768)
[2020-02-02 15:48:31.961] [D] [zway] Job 0x13 (Nonce Report): success
[2020-02-02 15:48:31.961] [I] [zway] Removing job: Nonce Report
[2020-02-02 15:48:32.060] [I] [core] [BaseModule-21] Set lastLevel to 227.76 for Astronomy_153_azimuth (was 227.55)
[2020-02-02 15:48:32.149] [D] [zway] RECEIVED: ( 01 1C 00 04 00 3A 16 98 81 54 B5 58 EB 60 8D CE 2E 00 E5 E4 E4 F3 67 0E AB 65 1E 82 C7 67 )
[2020-02-02 15:48:32.149] [D] [zway] SENT ACK
[2020-02-02 15:48:32.150] [D] [zway] SETDATA devices.58.data.lastReceived = 0 (0x00000000)
[2020-02-02 15:48:32.150] [I] [zway] Node 58:0 CC Security: Received a secure message
[2020-02-02 15:48:32.150] [D] [zway] SETDATA devices.58.instances.0.commandClasses.152.data.firstPart = **********
[2020-02-02 15:48:32.150] [I] [zway] Node 58:0 CC Security: passing decrypted packet to application level: [ 84 07 ]
[2020-02-02 15:48:32.150] [I] [zway] Node 58:0 CC Wakeup: Wakeup notification
[2020-02-02 15:48:32.150] [D] [zway] SETDATA devices.58.instances.0.commandClasses.132.data.lastWakeup = 1580654912 (0x5e36e140)
[2020-02-02 15:48:32.150] [D] [zway] SETDATA devices.58.data.lastSendInternal = **********
[2020-02-02 15:48:32.151] [D] [zway] SETDATA devices.58.data.lastNonceGet = 50066 (0x0000c392)
[2020-02-02 15:48:32.151] [D] [zway] Running wakeup handler for node 58
[2020-02-02 15:48:32.151] [D] [zway] SETDATA devices.58.instances.0.commandClasses.132.data.lastSleep = 1580654912 (0x5e36e140)
[2020-02-02 15:48:32.151] [I] [zway] Node 58:0 CC Wakeup: Send node to sleep
[2020-02-02 15:48:32.151] [I] [zway] Using security scheme S0
[2020-02-02 15:48:32.151] [I] [zway] Adding job: Wakeup Sleep
[2020-02-02 15:48:32.151] [I] [zway] Node 58:0 CC Security: sending Nonce Get
[2020-02-02 15:48:32.151] [D] [zway] SETDATA devices.58.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2020-02-02 15:48:32.152] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2020-02-02 15:48:32.152] [I] [zway] Removing job: Wakeup Sleep
[2020-02-02 15:48:32.152] [I] [zway] Adding job: Nonce Get
[2020-02-02 15:48:32.152] [D] [zway] SETDATA devices.58.instances.0.commandClasses.132.data.lastSleep = 1580654912 (0x5e36e140)
[2020-02-02 15:48:32.152] [I] [zway] Node 58:0 CC Wakeup: Send node to sleep
[2020-02-02 15:48:32.152] [I] [zway] Using security scheme S0
[2020-02-02 15:48:32.152] [I] [zway] Adding job: Wakeup Sleep
[2020-02-02 15:48:32.152] [D] [zway] SETDATA devices.58.data.lastNonceGet = 51066 (0x0000c77a)
[2020-02-02 15:48:32.170] [D] [zway] SENDING (cb 0xb5): ( 01 09 00 13 3A 02 98 40 05 B5 B5 )
[2020-02-02 15:48:32.172] [D] [zway] RECEIVED ACK
[2020-02-02 15:48:32.175] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-02-02 15:48:32.176] [D] [zway] SENT ACK
[2020-02-02 15:48:32.176] [D] [zway] Delivered to Z-Wave stack
[2020-02-02 15:48:32.482] [D] [zway] RECEIVED: ( 01 07 00 13 B5 00 00 1E 40 )
[2020-02-02 15:48:32.482] [D] [zway] SENT ACK
[2020-02-02 15:48:32.482] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2020-02-02 15:48:32.482] [D] [zway] SendData Response with callback 0xb5 received: received by recipient
[2020-02-02 15:48:32.482] [D] [zway] SETDATA devices.58.data.lastSendInternal = **********
[2020-02-02 15:48:32.483] [D] [zway] SETDATA devices.58.data.lastSend = 51098 (0x0000c79a)
[2020-02-02 15:48:32.483] [D] [zway] Job 0x13 (Nonce Get): success
[2020-02-02 15:48:32.483] [D] [zway] SETDATA devices.58.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2020-02-02 15:48:32.483] [D] [zway] SETDATA devices.58.data.lastNonceGet = 51098 (0x0000c79a)
[2020-02-02 15:48:32.483] [I] [zway] Waiting for job reply: Nonce Get
[2020-02-02 15:48:32.636] [D] [zway] RECEIVED: ( 01 10 00 04 00 3A 0A 98 80 C3 8B 04 BA 33 F0 B7 7B 3A )
[2020-02-02 15:48:32.637] [D] [zway] SENT ACK
[2020-02-02 15:48:32.637] [D] [zway] SETDATA devices.58.data.lastReceived = 0 (0x00000000)
[2020-02-02 15:48:32.637] [D] [zway] Received reply on job (Nonce Get)
[2020-02-02 15:48:32.637] [D] [zway] SETDATA devices.58.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2020-02-02 15:48:32.637] [D] [zway] SETDATA devices.58.data.lastNonceGet = 51113 (0x0000c7a9)
[2020-02-02 15:48:32.637] [I] [zway] Node 58:0 CC Security: received Nonce Report
[2020-02-02 15:48:32.637] [D] [zway] SETDATA devices.58.instances.0.commandClasses.152.data.rNonce = **********
[2020-02-02 15:48:32.637] [I] [zway] Node 58:0 CC Security: Sending a secure message
[2020-02-02 15:48:32.638] [I] [zway] Node 58:0 CC Security: sending encrypted packet: Wakeup Sleep
[2020-02-02 15:48:32.638] [D] [zway] SETDATA devices.58.instances.0.commandClasses.152.data.toFollow = False
[2020-02-02 15:48:32.638] [D] [zway] SETDATA devices.58.data.lastNonceGet = Empty
[2020-02-02 15:48:32.638] [I] [zway] Adding job: Security, Wakeup Sleep
[2020-02-02 15:48:32.638] [D] [zway] SENDING (cb 0xb6): ( 01 1D 00 13 3A 16 98 81 D6 A9 0D 30 3C 84 C7 E2 EA F5 EE C3 CC AB 45 93 4A 05 B8 9B 05 B6 47 )
[2020-02-02 15:48:32.639] [D] [zway] Secure payload: ( 84 08 )
[2020-02-02 15:48:32.646] [D] [zway] RECEIVED ACK
[2020-02-02 15:48:32.646] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-02-02 15:48:32.646] [D] [zway] SENT ACK
[2020-02-02 15:48:32.646] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Response received - transfered to encapsulated jobs
[2020-02-02 15:48:32.646] [D] [zway] Delivered to Z-Wave stack
[2020-02-02 15:48:33.016] [D] [zway] RECEIVED: ( 01 07 00 13 B6 00 00 24 79 )
[2020-02-02 15:48:33.017] [D] [zway] SENT ACK
[2020-02-02 15:48:33.017] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Callback received - transfered to encapsulated jobs
[2020-02-02 15:48:33.017] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2020-02-02 15:48:33.017] [D] [zway] SendData Response with callback 0xb6 received: received by recipient
[2020-02-02 15:48:33.017] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2020-02-02 15:48:33.017] [D] [zway] SETDATA devices.58.data.isAwake = False
[2020-02-02 15:48:33.017] [D] [zway] Sending the queue for node 58 into sleep
[2020-02-02 15:48:33.017] [I] [zway] Removing job: Wakeup Sleep
[2020-02-02 15:48:33.017] [I] [zway] Job 0x13 (Security, Wakeup Sleep): Delivered
[2020-02-02 15:48:33.018] [D] [zway] SendData Response with callback 0xb6 received: received by recipient
[2020-02-02 15:48:33.018] [D] [zway] SETDATA devices.58.data.lastSendInternal = **********
[2020-02-02 15:48:33.018] [D] [zway] SETDATA devices.58.data.lastSend = 51150 (0x0000c7ce)
[2020-02-02 15:48:33.018] [D] [zway] Job 0x13 (Security, Wakeup Sleep): success
[2020-02-02 15:48:33.018] [I] [zway] Removing job: Security, Wakeup Sleep
[2020-02-02 15:48:34.685] [D] [zway] Job 0x13: deleted from queue
[2020-02-02 15:48:35.735] [D] [zway] RECEIVED: ( 01 08 00 04 00 38 02 98 40 11 )
[2020-02-02 15:48:35.735] [D] [zway] SENT ACK
[2020-02-02 15:48:35.735] [D] [zway] SETDATA devices.56.data.lastReceived = 0 (0x00000000)
[2020-02-02 15:48:35.736] [I] [zway] Node 56:0 CC Security: sending Nonce Report
[2020-02-02 15:48:35.736] [W] [zway] Can not detect if this is a request or set/report - don't expect a reply
[2020-02-02 15:48:35.736] [I] [zway] Adding job: Nonce Report
[2020-02-02 15:48:35.736] [D] [zway] SENDING (cb 0xb7): ( 01 11 00 13 38 0A 98 80 7B A1 DE F4 8B B4 DE B2 05 B7 C6 )
[2020-02-02 15:48:35.745] [D] [zway] RECEIVED ACK
[2020-02-02 15:48:35.745] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-02-02 15:48:35.745] [D] [zway] SENT ACK
[2020-02-02 15:48:35.745] [D] [zway] Delivered to Z-Wave stack
[2020-02-02 15:48:35.862] [D] [zway] RECEIVED: ( 01 07 00 13 B7 00 00 0C 50 )
[2020-02-02 15:48:35.862] [D] [zway] SENT ACK
[2020-02-02 15:48:35.862] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2020-02-02 15:48:35.862] [D] [zway] SendData Response with callback 0xb7 received: received by recipient
[2020-02-02 15:48:35.862] [D] [zway] SETDATA devices.56.data.lastSendInternal = **********
[2020-02-02 15:48:35.863] [D] [zway] SETDATA devices.56.data.lastSend = 51421 (0x0000c8dd)
[2020-02-02 15:48:35.863] [D] [zway] Job 0x13 (Nonce Report): success
[2020-02-02 15:48:35.863] [I] [zway] Removing job: Nonce Report
[2020-02-02 15:48:36.010] [D] [zway] RECEIVED: ( 01 20 00 04 00 38 1A 98 81 0B C3 0D 38 70 C4 82 97 D4 3A A1 10 18 E7 69 7B 42 08 E8 19 C7 46 0C 00 38 )
[2020-02-02 15:48:36.010] [D] [zway] SENT ACK
[2020-02-02 15:48:36.011] [D] [zway] SETDATA devices.56.data.lastReceived = 0 (0x00000000)
[2020-02-02 15:48:36.011] [I] [zway] Node 56:0 CC Security: Received a secure message
[2020-02-02 15:48:36.011] [D] [zway] SETDATA devices.56.instances.0.commandClasses.152.data.firstPart = **********
[2020-02-02 15:48:36.011] [I] [zway] Node 56:0 CC Security: passing decrypted packet to application level: [ 31 05 01 42 07 9a ]
[2020-02-02 15:48:36.011] [D] [zway] SETDATA devices.56.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2020-02-02 15:48:36.013] [D] [zway] SETDATA devices.56.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2020-02-02 15:48:36.013] [D] [zway] SETDATA devices.56.instances.0.commandClasses.49.data.1.val = 19.459999
[2020-02-02 15:48:36.013] [D] [zway] SETDATA devices.56.instances.0.commandClasses.49.data.1 = Empty
One of them completes security and all except "Firmware Update"
unable to update data: devices[56].instances[0].commandClasses[122].Interview()
I did a full factory reset of one of the spirits and included it in S2 unauthenticated and still the Security Interview and the S2 Interview do not show "OK"
Am I missing something here? Do I have to take additional steps?
Best Regards,
rws
Re: Interviews start disappearing
We need full inclusion log to analyze
ridewithstyle
Hello PoltoS,
just to ensure that there is no hardware error, I bought another new Eurotronic Spirit for comparison.
First I removed the logfile and restarted the razberry and tried to renew the interview of one of my failing thermostats, as you can see in the logs.
Then I included the brand new spirit plus from eurotronic, same issue.
Please dig in, let me know if I can help to debug.
Best Regards,
rws
zway-log.zip.7z
(255.89 KiB) Downloaded 946 times
ridewithstyle
Hi PoltoS,
could you find anything?
Best Regards,
rws
Sorry, I'm out if work now. Please send it to me by mail and I check when back to work
ridewithstyle
Sorry, I somehow missed your reply. Did you get the chance to take a look at the uploaded inclusion log from me? The behaviour didn't change with 3.0.5, still the same issues with disappearing interviews.
Any way I can help debug?
Best Regards,
rws
I suppose your mail is in a huge list of mails from last months. Can you resend it please and refresh the question?
ridewithstyle
The full inclusion log is four posts up attached to my post from Feb 9th. I never sent an email, I don't even have your email, you profile doesn't show any.
After the inclusion I also manually triggered the interviews, it's also in the logs.
TL;DR: after the upgrade to 3.0, my interviews of my thermostats disappeared one after another and I couldn't redo them, they don't finish. I even bought a brand new eurotronic spirit-z and the same happened.
ridewithstyle
issue persists with 3.0.6
equathza
Post by equathza »
The log entries, a few I think are interesting:
[2020-02-09 15:29:08.916] [I] [zway] Node 88:0 CC AssociationGroupInformation: Association CC interview is not complete - can not proceed with interview
[2020-02-09 15:28:41.808] [D] [zway] Security S2 inclusion timeout event
[2020-02-09 15:28:41.812] [W] [zway] Node 88:0 CC SecurityS2: Security S2 key negociation with node 88 failed, KEX fail reason: Unknown Security S2 KEX failure reason (0)
[2020-02-09 15:50:23.874] [I] [zway] Node 88:0 CC SecurityS2 Interview abandoned due to many retries
A basic question:
Did you exclude the problematic device first? (Even brand new out of box)
> Please try to exclude your device first, and then (re)include your device.
Further more, I see your chip is running an older (5.04) firmware version, check if you can upgrade your controller firmware from the expertUI.
> Create a back-up of your controller before you start! > Under Network > Controller Info you can find the upgrade button.
> Folow the instruction of the firmware upgrade carefully. i.e. sometimes the update procedure need a power off for completion!
When the upgrade firmware button doesn't show you any firmware available, please report back! I don't want you to mess around with trial and error, as you may damage you device.
-> A fellow Z-way user running a network of 50+ devices
