OpenZwave и razberry
livindead
Post by livindead »
Добрый день.
Пробую запустить новую плату, прошу помощи ((
Не запускается razberry плата через openzwave и nodejs.
Пишет сообщение
Initialising OpenZWave 1.6.1030 binary addon for Node.JS.
	OpenZWave Security API is ENABLED
	ZWave device db    : /usr/local/etc/openzwave
	User settings path : /home/pi/workflow/ozwt2/node_modules/openzwave-shared/build/Release/../../
	Option Overrides : --ConsoleOutput true
connecting to /dev/ttyAMA0
2020-02-09 07:08:08.246 Always, OpenZwave Version 1.6-1030-g0d6f2b7d Starting Up
2020-02-09 07:08:08.270 Info, Loading Localization File /usr/local/etc/openzwave/Localization.xml
2020-02-09 07:08:08.275 Info, Loaded /usr/local/etc/openzwave/Localization.xml With Revision 8
2020-02-09 07:08:08.278 Always, Using Language Localization
2020-02-09 07:08:08.286 Info, Loading NotificationCCTypes File /usr/local/etc/openzwave/NotificationCCTypes.xml
2020-02-09 07:08:08.288 Info, Loaded /usr/local/etc/openzwave/NotificationCCTypes.xml With Revision 9
2020-02-09 07:08:08.293 Info, Loading SensorMultiLevelCCTypes File /usr/local/etc/openzwave/SensorMultiLevelCCTypes.xml
2020-02-09 07:08:08.293 Info, Loaded /usr/local/etc/openzwave/SensorMultiLevelCCTypes.xml With Revision 3
2020-02-09 07:08:08.295 Info, Setting Up Provided Network Key for Secure Communications
2020-02-09 07:08:08.295 Warning, Failed - Network Key Not Set
2020-02-09 07:08:08.334 Info, Manufacturer_Specific.xml file Revision is 74
2020-02-09 07:08:09.215 Info, Product name collision: FGR223 Roller Shutter Controller 3 type 303 id 1000 manufacturerid 10f, collides with FGRM223 Roller Shutter Controller 3, type 303 id 1000 manufacturerid 10f
2020-02-09 07:08:09.768 Info, Product name collision: ED2.0 Meter Adapter type 0 id 0 manufacturerid 128, collides with ED2.0 Meter Adapter, type 0 id 0 manufacturerid 128
2020-02-09 07:08:09.768 Info, Product name collision: ED2.0 Display type 128 id 0 manufacturerid 128, collides with ED2.0 Display, type 128 id 0 manufacturerid 128
2020-02-09 07:08:10.042 Info, Product name collision: GR105 Auto Valve type 202 id 511 manufacturerid 152, collides with GR105 Auto Valve, type 202 id 511 manufacturerid 152
2020-02-09 07:08:10.042 Info, Product name collision: GR105n Auto Valve type 3 id 512 manufacturerid 152, collides with GR105n Auto Valve, type 3 id 512 manufacturerid 152
2020-02-09 07:08:10.043 Info, Product name collision: ZSE02 Motion Sensor type 500 id 3 manufacturerid 152, collides with ZSE02 Motion Sensor, type 500 id 3 manufacturerid 152
2020-02-09 07:08:10.082 Info, Product name collision: ZWN-BPC Ceiling Mounted PIR Motion Sensor type 601 id 901 manufacturerid 11a, collides with ZWN-BPC Ceiling Mounted PIR Motion Sensor, type 601 id 901 manufacturerid 11a
2020-02-09 07:08:10.082 Info, Product name collision: ZWN-SC7 7-Button Scene Controller type 801 id b03 manufacturerid 11a, collides with ZWN-SC7 7-Button Scene Controller, type 801 id b03 manufacturerid 11a
2020-02-09 07:08:10.082 Info, Product name collision: ZW15S 15A On/Off Switch type 101 id 102 manufacturerid 11a, collides with ZW15S 15A On/Off Switch, type 101 id 102 manufacturerid 11a
2020-02-09 07:08:10.082 Info, Product name collision: ZW20R 20A TR Duplex Receptacle type 101 id 603 manufacturerid 11a, collides with ZW20R 20A TR Duplex Receptacle, type 101 id 603 manufacturerid 11a
2020-02-09 07:08:10.082 Info, Product name collision: ZWN-RSM1 PLUS-Smart Single Relay Switch Module type 111 id 605 manufacturerid 11a, collides with ZWN-RSM1 PLUS—Smart Single Relay Switch Module, type 111 id 605 manufacturerid 11a
2020-02-09 07:08:10.082 Info, Product name collision: ZW20RM 20A TR Smart Meter Duplex Receptacle type 111 id 101 manufacturerid 11a, collides with ZW20RM 20A TR Smart Meter Duplex Receptacle, type 111 id 101 manufacturerid 11a
2020-02-09 07:08:10.082 Info, Product name collision: ZW500D 500W In-Wall Preset Dimmer Switch type 102 id 201 manufacturerid 11a, collides with ZW500D 500W In-Wall Preset Dimmer Switch, type 102 id 201 manufacturerid 11a
2020-02-09 07:08:10.082 Info, Product name collision: ZW15RM Plus 15A TR Smart Meter Duplex Receptacle type 111 id 105 manufacturerid 11a, collides with ZW15RM Plus 15A TR Smart Meter Duplex Receptacle, type 111 id 105 manufacturerid 11a
2020-02-09 07:08:10.196 Info, Queuing Lookup on mfs.db.openzwave.com for Node 0
2020-02-09 07:08:10.197 Info,   Opening controller /dev/ttyAMA0
2020-02-09 07:08:10.197 Info, Starting DNSThread
2020-02-09 07:08:10.198 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-02-09 07:08:10.198 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-02-09 07:08:10.199 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-02-09 07:08:10.199 Info, Timer: thread starting
2020-02-09 07:08:10.199 Detail, Timer: waiting with timeout -1 ms
2020-02-09 07:08:10.199 Info, LookupTxT Checking mfs.db.openzwave.com
2020-02-09 07:08:10.199 Info, mgr,     Added driver for controller /dev/ttyAMA0
ONNECTED ****
Openzwave version: 1.6.1030
m2020-02-09 07:08:10.213 Info, Lookup for mfs.db.openzwave.com returned 74
2020-02-09 07:08:10.223 Info, ManufacturerSpecificDB Initialized
2020-02-09 07:08:10.223 Detail, Notification: ManufacturerSpecificDB Ready
2020-02-09 07:08:10.224 Detail,
2020-02-09 07:08:10.224 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-02-09 07:08:10.224 Info, contrlr, Encrypted Flag is 0
2020-02-09 07:08:10.224 Detail, contrlr, Notification: DriverFailed: /dev/ttyAMA0
ailed to start driver
Порт dev/ttyAMA0
board: rasberry pi 3
os: rasberry
Что может быть не так ?
Как можно проверить плату напрямую ?
Если в списке ls -al /dev/tty* есть порт это значит плата определяеться или нет ?
Re: OpenZwave и razberry
Установите Z-Way по инструкции на сайте. Он и порт настроит, и попробуете его заодно.
livindead
Post by livindead »
PoltoS wrote:
09 Feb 2020 11:05
Выполнение этого скрипта частично помогло, спасибо.
Вопрос , я как понял после установки порты уже проброшены раз я могу через Интернет используя сервис find.z-way.me , верно ?
Но почему я могу только к АПИ через локалку подключиться (http://192.168.1.107:8083/ZAutomation/api/v1/devices) , если я смотрю внешний ip через http://myip.ru/ и по нему пытаюсь подключиться то не получаеться. Где посмотреть ip по которому работает сервис ? Может я что то не понимаю, как это сервис работает без проброски портов в роутере и динамическим ip ?
UPD Или мне надо в отдельной ветке форума писать ?
По внешнему конечно не получится. Мы же не открываем одну большую дыру к вам в дом.
Рекомендую мануал на сайте почитать
Используйте find.z-wave.me для доступа вне дома
