Problem with Adafruit_AMG88xx.h library
Miklux
Post by Miklux »
Hi all,
I'm trying to compile a little sketch with my ZUno device.
I want to use the Adafruit_AMG88xx.h library but it gives me an error.
The sketch is this one:
#include <Adafruit_AMG88xx.h>
#include <Wire.h>
#define MAP_TO_ZEROCHANNEL 0x80
ZUNO_SETUP_PRODUCT_ID(0xAB, 0xCD);
ZUNO_ENABLE(WITH_CC_SENSOR_MULTILEVEL);
ZUNO_DYNAMIC_CHANNELS(3);
byte nIngressi;
byte nUscite;
byte nPresenze;
void setup() {
  Serial.begin(115200);
  nIngressi = 0;
  nUscite = 0;
  nPresenze = 0;
  ZUNO_START_CONFIG();
  ZUNO_SET_ZWCHANNEL(1| MAP_TO_ZEROCHANNEL); // <- this channel will be provided via 1 & 0 channels
  ZUNO_ADD_CHANNEL(ZUNO_SENSOR_MULTILEVEL_CHANNEL_NUMBER, ZUNO_SENSOR_MULTILEVEL_TYPE_GENERAL_PURPOSE_VALUE, SENSOR_MULTILEVEL_PROPERTIES_COMBINER( SENSOR_MULTILEVEL_SCALE_LOCAL, SENSOR_MULTILEVEL_SIZE_ONE_BYTE, SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS));
  ZUNO_SET_ZWCHANNEL(2);
  ZUNO_SET_ZWCHANNEL(3);
  ZUNO_COMMIT_CONFIG();
void loop() {
  byte selection=0;
  if (Serial.available() > 0) {
    // read the incoming byte:
    selection = Serial.read();
    switch(selection) {
    case '0':
      nIngressi++;
      g_channels_data[0].bParam = nIngressi;
      break;
    case '1':
      nUscite++;
      g_channels_data[1].bParam = nUscite;
      break;
    default:
      break;
    nPresenze=nIngressi-nUscite;
    if(nPresenze<0) nPresenze=0;
    g_channels_data[2].bParam = nPresenze;
    Serial.println(nPresenze);
  //delay(30000);
All is ok if I compile without the Adafruit_AMG88xx library , but with it i receive this:
Arduino:1.8.12 (Windows 10), Scheda:"Z-Wave>ME Z-Uno, Europe, Disabled, Disabled, Disabled, Disabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Michele\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Michele\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Michele\Documents\Arduino\libraries -fqbn=Z-Uno:zw8051:zuno:Frequency=Eu,Security=Off,MuliCommand=Off,LogOutput=Off,NVMClean=Off -ide-version=10812 -build-path C:\Users\Michele\AppData\Local\Temp\arduino_build_539636 -warnings=none -build-cache C:\Users\Michele\AppData\Local\Temp\arduino_cache_77333 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.zuno_toolchain.path=C:\Users\Michele\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.80 -prefs=runtime.tools.zuno_toolchain-00.08.80.path=C:\Users\Michele\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.80 -verbose C:\Users\Michele\Documents\Arduino\zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519\zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519\zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Michele\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Michele\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Michele\Documents\Arduino\libraries -fqbn=Z-Uno:zw8051:zuno:Frequency=Eu,Security=Off,MuliCommand=Off,LogOutput=Off,NVMClean=Off -ide-version=10812 -build-path C:\Users\Michele\AppData\Local\Temp\arduino_build_539636 -warnings=none -build-cache C:\Users\Michele\AppData\Local\Temp\arduino_cache_77333 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.zuno_toolchain.path=C:\Users\Michele\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.80 -prefs=runtime.tools.zuno_toolchain-00.08.80.path=C:\Users\Michele\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.80 -verbose C:\Users\Michele\Documents\Arduino\zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519\zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519\zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519.ino
Using board 'zuno' from platform in folder: C:\Users\Michele\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\2.1.5
Using core 'zuno' from platform in folder: C:\Users\Michele\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\2.1.5
Detecting libraries used...
"C:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\Z-Uno\\tools\\zuno_toolchain\\00.08.80/zuno_toolchain/compiler" arduino_preproc "C:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_539636\\sketch\\zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519.ino.cpp" -r "C:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\Z-Uno\\hardware\\zw8051\\2.1.5"
Found 1.8.x project structure (File:zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519.ino.cpp). Converting it...
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_539636\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sto compilando lo sketch...
"C:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\Z-Uno\\tools\\zuno_toolchain\\00.08.80/zuno_toolchain/compiler" build "C:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_539636/zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519.ino" -r "C:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\Z-Uno\\hardware\\zw8051\\2.1.5" -i1_8 -idv 10812
	C:\Users\Michele\AppData\Local\Temp\arduino_build_539636/zWave_SD_IR_ARRAY_COUNTER_NO_STRING_280519.ino
	 --- USING a list of libraries from:
		C:\Users\Michele\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\2.1.5\libraries
	*** Collecting prototypes...
Preprocessing file: C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\Custom.c with SDCPP...
Preprocessing file: C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\Print.cpp with SDCPP...
Compiling C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\Print_sdcpp_.cpp ...
Preprocessing file: C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\Stream.cpp with SDCPP...
Compiling C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\Stream_sdcpp_.cpp ...
Preprocessing file: C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\HardwareSerial.cpp with SDCPP...
Compiling C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\HardwareSerial_sdcpp_.cpp ...
Preprocessing file: C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\HLCore.cpp with SDCPP...
Compiling C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\HLCore_sdcpp_.cpp ...
Preprocessing file: C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\Wire.cpp with SDCPP...
Compiling C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\Wire_sdcpp_.cpp ...
Preprocessing file: C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\Adafruit_AMG88xx.cpp with SDCPP...
In file included from C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\Adafruit_AMG88xx.cpp:1:
C:\Users\Michele\AppData\Local\Temp\arduino_build_539636\/Adafruit_AMG88xx.h:7:23: fatal error: WProgram.h: No such file or directory
compilation terminated.
Preprocessor failed!uCxx returned error code:1
exit status 1
Errore durante la compilazione per la scheda Z-Wave>ME Z-Uno.
Please, can you help me?
Thanks in aadvance
Mik
p0lyg0n1
Re: Problem with Adafruit_AMG88xx.h library
Post by p0lyg0n1 »
The main problem is that Adafruit library was written for AVR microprocessors. Z-Uno uses power efficient, but very old factory standard i8051 core. To get library to work with Z-Uno you have to port library according to Z-Uno limitations in stack and inner compiler limitations. Z-Uno has only 120-140 bytes of stack, its compiler couldn't use references, big local variables, C++ templates & etc.
To port library you have to understand the main principles of device (AMG88), you have to understand all the the Adafruit code. It's not just place it to your folder & recompile. Sometimes it's easier to rewrite library yourself than port it. You can compare some already ported libraries to understand main techniques of stack usage reduction: see our GitHub: https://github.com/Z-Wave-Me/Z-Uno-Core ... /libraries
Good luck!
Yours,
Alex.
Miklux
Post by Miklux »
Sorry for the late answer,
thank you, I resolved creating my own library. :mrgreen:
Great job!
