Old ZMEEUZB1 firmware update
FlangeMonkey
Post by FlangeMonkey »
Hi Guys,
I'm looking to do a firmware update on my ZMEEUZB1, which was purchased back in 2017. Its the manual process and I cannot determine the current version. I'm executing ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyACM0 and get the following output:
/ZMESerialUpdater/x64# ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyACM0
                                        Z-WAVE Serial API Tool
                                             Version:LWE0.9
                                             by Z-WAVE>ME
Device ready in:8.63519310951 seconds
          FULL INFO
Openning port                            ..............................                            OK
        Error  0 returned ff for ACK
        Error  1 returned ff for ACK
        Error  2 returned ff for ACK
        Error  3 Unknown exception:list index out of range
Any Idea's?
Thanks,
FlangeMonkey
Re: Old ZMEEUZB1 firmware update
I ended up turning up a Pi and testing it. I can now pull the info.
FlangeMonkey
I've managed to get up to version 5.7, I cannot seem to understand what updates are needed to get further up. I'm looking at the below link and there doesn't appear to be a path. If I look at "all" there appears to be a path, but I'm seeing references to 2 bootloaders and 2/3CH and different countries.
https://service.z-wave.me/expertui/uzb- ... tml?hw=277
Can someone please confirm I have this right:
From 5.5 to 5.6 (Done)
  • bootloader_UZB_from_05_05_to_7278_2MB.bin
  • firmware_UZB_from_05_05_to_05_06.bin
To 5.7 (Done)
  • bootloader_UZB_from_05_06_to_7278_2MB.bin
  • UPD_FIRMWARE_UZB500_from_05_06_to_05_07.bin
From 5.7 to 5.7/40196
  • do I need "UPD_BOOTLOADER_UZB_ZME_05_07_04000001_9d04.bin", "bootloader_UZB_from_05_07_to_7278_2MB.bin" or nether because I'm on 7278.
  • I'm in the EU do I need "UPD_FIRMWARE_UZB500_3CH_X_from05_07_to_UZB500_05_07.bin"? It appears to change from 3CH to what I already have?
From 5.7/40196 to 5.27/40196
  • bootloader_UZB_from_05_07_to_7278_2MB.bin < again do I need this?
  • UPD_FIRMWARE_UZB_STATIC_2ch_ZME_05_07_04000001_ZME_05_1b_04000001.bin
From 5.27 to 5.36
  • UPD_FIRMWARE_UZB_STATIC_2ch_ZME_05_1b_04000001_ZME_05_24_04000001.bin
I feel I only need "UPD_FIRMWARE_UZB_STATIC_2ch_ZME_05_07_04000001_ZME_05_1b_04000001.bin" and then "UPD_FIRMWARE_UZB_STATIC_2ch_ZME_05_1b_04000001_ZME_05_24_04000001.bin"?
Thanks,
rafale77
Post by rafale77 »
Yes you need to move to boot loader 40196 to go further.
FlangeMonkey
Thanks for the reply, can you please clarify? When you say 40196 and bootloader do you mean, the bootloader I already have "bootloader_UZB_from_05_06_to_7278_2MB.bin" or this one "UPD_BOOTLOADER_UZB_ZME_05_07_04000001_9d04.bin" due to the matching 04000001?
Thanks,
edit: 9d04 is 40196 in decimal, so I need bootloader: UPD_BOOTLOADER_UZB_ZME_05_07_04000001_9d04.bin??????
rafale77
Post by rafale77 »
Correct!
This crazy map can help you. Or break your mind ;)
https://service.z-wave.me/expertui/uzb- ... ith_hidden
