Use as device in Home Assistant?
Kronos
Post by Kronos »
I included my razberry (that sits on top of a raspberry 3+) in my Home Assistant (aotec controller on a separate raspberry running rasbian) as a secondary/slave controller.... but what I really would like to do to is to use my razberry to control stuff. Is it somehow possible - through home assistant- to have the razberry do any actions? Like setting an output pin high? Or what are my options?
Re: Use as device in Home Assistant?
In theory yes - Z-Uno can trap Basic Set commands from other devices and then you can handle them
Kronos
Post by Kronos »
No one? Anyone that knows if the razberry has any form of output? That can be manipulated/controlled by Home assistant
Kronos
Post by Kronos »
PoltoS wrote:
16 May 2020 19:47
Sorry. Overlooked your reply...hmm... but how? I want the razberry to perform actions on the raspberry.
Look in logs when the Basic Set us received. You will see the data holder that is changed. Then use .bind to trap this event. Watch our webinar this Friday to know more
