Firmware upgrade brick?
MrRusch
Post by MrRusch »
I listened to recorded webinar today, used the token to find upgrade and proceeded assuming that my device ZMEERAZ2 Rev.2.1 would be fine as I purchased it relatively recently.
However, after upgrading firmware the device seems to be completely dead.
z-way-server.log (attached) shows the process seemingly succeeding, ordering a soft reset and terminating the z-wave binding,
[2020-05-19 21:45:39.722] [I] [zway] Removing job: Soft reset
[2020-05-19 21:45:39.733] [D] [zway] Worker thread exit point
[2020-05-19 21:45:39.734] [D] [zway] Worker thread successfully finished
[2020-05-19 21:45:39.734] [I] [core] Terminating Z-Wave binding
..only to realize it cant find it again,
[2020-05-19 21:45:41.873] [C] [zway] data access without a lock
[2020-05-19 21:45:41.873] [E] [zway] Node 15:0 CC Security: No controller device found
[2020-05-19 21:45:42.003] [I] [core] Trying to restart Z-Wave binding (zway) in 10 seconds
..ending finally with,
[2020-05-19 21:46:34.996] [D] [zway] Opened device: /dev/ttyAMA0
[2020-05-19 21:46:34.996] [D] [zway] Worker thread successfully created
[2020-05-19 21:46:34.996] [D] [zway] Worker thread entry point
[2020-05-19 21:46:34.996] [I] [zway] Adding job: Get controller info and supported function classes
[2020-05-19 21:46:35.006] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2020-05-19 21:46:35.208] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2020-05-19 21:46:35.208] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2020-05-19 21:46:35.410] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2020-05-19 21:46:35.410] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2020-05-19 21:46:35.612] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2020-05-19 21:46:35.612] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2020-05-19 21:46:35.612] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2020-05-19 21:46:35.612] [C] [zway] Get Serial API Capabilities returned zero.
[2020-05-19 21:46:35.613] [I] [zway] Removing job: Get controller info and supported function classes
[2020-05-19 21:46:35.623] [D] [zway] Worker thread exit point
[2020-05-19 21:46:35.623] [D] [zway] Worker thread successfully finished
[2020-05-19 21:46:35.634] [I] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2020-05-19 21:46:35.649] [I] [core] Error: Bad data - communication failed
[2020-05-19 21:46:35.651] [I] [core] Tried 5 times without success. Stopping tries.
[2020-05-19 21:46:35.656] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
ZMESerialUpdater just keeps ticking away with (-->) apparently unable to open the port.
I have done multiple complete power cycles of RPI and am stuck.
Any ideas?
upgrade.rar
(272.45 KiB) Downloaded 2 times
MrRusch
Re: Firmware upgrade brick?
Post by MrRusch »
This seems to be a perfect duplicate,
https://forum.z-wave.me/viewtopic.php?f ... ro.#p84723
My leds seem pretty strong, not sure what it used to look like.
micky1500
Post by micky1500 »
Think you answered your own question.
I'm sure Serguei said the blue ones were suspect in the Webinar (bad manufacture batch - fails upgrade).
https://forum.z-wave.me/viewtopic.php?f ... lue#p81821
Maybe Poltos will give some advice.
Raspi 4(Buster), Zwave Version 3.0.6 x It's not my fault... I am not z-way team, just a user of a great system.
Correct, blue boards are affected by this issue. If both LEDs lid faintly, it is dead. Please swap it in your shop for free.
MrRusch
Post by MrRusch »
OK, will do.
