Invalid argument error when changing thermostat value
Chester8
Post by Chester8 »
Hi all,
I have been trying the new Easy Scripting app and it's very nice. I have done a few things without problems until I tried to control my thermostat.
Just to simplify things, I wrote this code (when I change the state of a plug, the temperature changes to 20 degrees):
### ZWayVDev_zway_3-0-37 // Plug
vdev("ZWayVDev_zway_8-0-67-1").set(20)
The problem is that when it executes, I get an "Error: Invalid argument" in the events page. I have looked in the server's log file and I can see what follows:
[zway] Node 8:0 CC ThermostatMode: Thermostat Mode 1 is not supported by device (modemask 0x0)
[core] Notification: error (module): Error while executing command: Error: Invalid argument
[core] Error: Invalid argument
    at Error (native)
    at t_vDev.(anonymous function).self.controller.devices.create.handler (automation/modules/ZWave/index.js:5638:62)
    at _.extend.performCommand (automation/classes/VirtualDevice.js:316:25)
    at vDevWrapper.set (automation/modules/EasyScripting/index.js:142:12)
    at script (eval at <anonymous> (automation/modules/EasyScripting/index.js:1:0), <anonymous>:2:32)
    at automation/modules/EasyScripting/index.js:56:4
    at onEvent (automation/modules/EasyScripting/index.js:57:5)
    at EventEmitter.emit (automation/lib/eventemitter2.js:311:33)
    at _.extend.emit (automation/classes/VirtualDevice.js:342:26)
    at automation/classes/VirtualDevice.js:268:10
Althought I get the error, the temperature is changed, but It doesn't seem to be right... ¿Can anyone help me to get rid of this annoying message?
Thanks in advance
Re: Invalid argument error when changing thermostat value
What thermostat is it?
Chester8
Post by Chester8 »
PoltoS wrote:
23 May 2020 11:05
Hi PoltoS, the thermostat is "Secure SRT321 Zwave Stat (Tx)". Do you have any ideas?
ridewithstyle
Post by ridewithstyle »
I too get the "invalid argument" error on the eurotronic spirit-z with the failed secure inclusion when using on/off heat. But I thought the failed inclusion is the more important issue to resolve, hence I didn't put too much thought into it
Chester8
Post by Chester8 »
I'm not 100% sure because I did the inclusion many months ago, but I don't remember any failure with the secure inclusion in my case. What type of error do you get?
ridewithstyle
My Inclusion was still on the 2.x line over a year ago. After the upgrade to the 3.x line I get the "invalid argument" when I try to use the ON/OFF heat
