Analog inputs, maximum voltage ?
fredfit
Post by fredfit »
Hi all,
I cannot find any info about the maximum voltage that the Z-Uno can accept on its Analog inputs when powered at 5V.
Can someone please advise ?
Thanks !
Re: Analog inputs, maximum voltage ?
Z-Uno itself should never be connected to voltage bigger than Vcc +10%. This means 3.6 V is the maximum.
Anyway, if your reference bus GND/Vcc, everything above Vcc gives max value in ADC
petergebruers
Post by petergebruers »
BTW never inject current into a pin, I mean when you have no power to your Z-Uno then, for example, do not connect an input to a 3V battery without limiting current. The best thing that can happen is this... Your source connected to that pin powers up the Z-Uno (which might lead you to believe a Z-Uno can work without power- LOL) and worst case it destroys the Z-Uno. Use a buffer or a resistor to limit current (eg 330 ohm for general experimenting).
fredfit
Post by fredfit »
Thank you !
