Problem executing the example in eedomus Controlling iRobot Roomba from Z-Wave
jalvarezprz
Post by jalvarezprz »
Hello:
I have the eedomus domotic system installed and I have tried to run the example https://z-uno.z-wave.me/projects/contro ... ve-network, but I had a problem.
According to the original program, two devices should be created: 1) ZUNO_SWITCH_BINARY () and ZUNO_SENSOR_MULTILEVEL (). But in eedomus only one device is created: the ZUNO_SWITCH_BINARY ().
I have tested with each of the macros separately and the device that corresponds to each macro is created correctly.
Anyone know what might be happening?
Thanks in advance, Joaquin
Re: Problem executing the example in eedomus Controlling iRobot Roomba from Z-Wave
This is an eedomus problem. Please contact them
jalvarezprz
Good morning, PoltoS:
Thank you very much for your quick response. I have already imagined that problem was with eedomus. I have seen that eedomus, sometimes, does not integrate all the functionalities of the devices (in this case of ZUNO).
PoltoS, considering that the question is deeply technical, I kindly wanted to ask you if you could help me by telling me what should I say to the eedomus engineers to transmit this problem to them? Another possibility is that you are the one who gets in direct contact with eedomus, since a conversation between engineers with a deep level in eedomus and ZUNO will be much more effective.
On the other hand, I want to congratulate you on the ZUNO product, I think it is great and very versatile. I have been working with it for a few days and I see with a lot of possibilities.
Thanks for using Z-Uno!
You can link us with their support. But I would still ask you to initiate the inquery as when a request comes from a customers companies are usually reacting better.
