Lots of nofication messages
larekm
Post by larekm »
Hi!
When I open a door with a sensative door sensor I get lots of notifications, see below. I can solve the problem temporarily by excluding, including the device but it will come back after 2-3 weeks. Regards Lars
SmartHome UI - Notification
The following notification appeared in Your Z-Way System:
Cannot create vDev based on: 117-0-113: TypeError: Cannot read property 'forEach' of null
Best Regards
Z-Wave.Me
From /var/log/z-way-server.log
[2020-10-08 21:01:56.589] [D] [zway] Sending the queue for node 100 into sleep
[2020-10-08 21:01:56.589] [zway] Removing job: Wakeup Sleep
[2020-10-08 21:02:10.343] [D] [zway] RECEIVED: ( 01 10 00 04 00 75 0A 71 05 00 00 00 FF 06 16 00 00 0F )
[2020-10-08 21:02:10.343] [D] [zway] SENT ACK
[2020-10-08 21:02:10.344] [D] [zway] SETDATA devices.117.data.lastReceived = 0 (0x00000000)
[2020-10-08 21:02:10.344] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2020-10-08 21:02:10.344] [D] [zway] ( zero-length buffer )
[2020-10-08 21:02:10.344] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6.event = 22 (0x00000016)
[2020-10-08 21:02:10.346] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6.eventString = "Window/door is open"
[2020-10-08 21:02:10.346] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2020-10-08 21:02:10.346] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6 = Empty
[2020-10-08 21:02:10.580] [core] Notification: error (core): Cannot create vDev based on: 117-0-113: TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.583] [core] TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.586] [core] Notification: error (core): Cannot create vDev based on: 117-0-113: TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.587] [core] TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.589] [core] Notification: error (core): Cannot create vDev based on: 117-0-113: TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.590] [core] TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.592] [core] Notification: error (core): Cannot create vDev based on: 117-0-113: TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.592] [core] TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.594] [core] [MotionTrigger-19] Handle sensor update from ZWayVDev_zway_117-0-113-6-Door-A
[2020-10-08 21:02:10.595] [I] [core] [MotionTrigger-19] Handle change to on from ZWayVDev_zway_117-0-113-6-Door-A
[2020-10-08 21:02:10.597] [I] [core] [MotionTrigger-19] Device Ytterdörr, garage is off
[2020-10-08 21:02:10.598] [I] [core] [MotionTrigger-19] Device Ytterdörr. entre is on
[2020-10-08 21:02:10.598] [I] [core] [MotionTrigger-19] Device Entre rörelse is off
[2020-10-08 21:02:10.599] [I] [core] [MotionTrigger-19] Device Ytterbelysning, baksida garage is on
[2020-10-08 21:02:10.599] [I] [core] [MotionTrigger-19] Device Ytterbelysning, entre is on
[2020-10-08 21:02:10.600] [I] [core] [MotionTrigger-19] Calculating precondition
[2020-10-08 21:02:10.602] [I] [core] [MotionTrigger-19] Time does not match
[2020-10-08 21:02:10.602] [I] [core] [MotionTrigger-19] Triggered motion sensor (preconditions: false, lights: true, triggered: false)
[2020-10-08 21:02:10.603] [I] [core] Notification: device-info (device-OnOff): {"dev":"Ytterdörr. entre","l":"on","location":4}
[2020-10-08 21:02:10.625] [I] [core] Notification: error (core): Cannot create vDev based on: 117-0-113: TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.626] [I] [core] TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:10.647] [I] [core] [BaseModule-20] Set lastLevel to on for ZWayVDev_zway_117-0-113-6-Door-A (was off)
[2020-10-08 21:02:11.664] [D] [zway] RECEIVED: ( 01 10 00 04 00 75 0A 71 05 00 00 00 FF 06 17 00 00 0E )
[2020-10-08 21:02:11.664] [D] [zway] SENT ACK
[2020-10-08 21:02:11.665] [D] [zway] SETDATA devices.117.data.lastReceived = 0 (0x00000000)
[2020-10-08 21:02:11.665] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2020-10-08 21:02:11.665] [D] [zway] ( zero-length buffer )
[2020-10-08 21:02:11.665] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6.event = 23 (0x00000017)
[2020-10-08 21:02:11.667] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6.eventString = "Window/door is closed"
[2020-10-08 21:02:11.667] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2020-10-08 21:02:11.667] [D] [zway] SETDATA devices.117.instances.0.commandClasses.113.data.6 = Empty
[2020-10-08 21:02:11.682] [I] [core] Notification: error (core): Cannot create vDev based on: 117-0-113: TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:11.683] [I] [core] TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:11.687] [I] [core] Notification: error (core): Cannot create vDev based on: 117-0-113: TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:11.687] [I] [core] TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:11.691] [I] [core] Notification: error (core): Cannot create vDev based on: 117-0-113: TypeError: Cannot read property 'forEach' of null
[2020-10-08 21:02:11.692] [I] [core] TypeError: Cannot read property 'forEach' of null
larekm
Re: Lots of nofication messages
Post by larekm »
I have firmware version v3.1.1
If you can provide us access while the issue is till here, we will try to hunt it.
