Docker Script/ Container
chrisgla
Post by chrisgla »
Seen multiple threads about Z-Way on Docker and there are multiple containers, but can't see any that have all the persistence links clear or a build script.
Does anyone have a build script or recent container (x86) with persistence?
PerH
Re: Docker Script/ Container
Post by PerH »
I'm learning Docker right now, and want to learn how to make an image. If someone could tell me which folders needs to be persistent, i could try an make one? Thinking of an ubuntu docker with 3.1.3.
PerH
Post by PerH »
EDIT: got the solution from @poltos. this image works fine, and is published on dockerhub.
So, I made the docker, but i'm struggling with transferring my system to it.
I tried to copy the /config/ folder to the docker volume, but that doesn't contain info about logon details or room configuration. Can someone help me with getting all necessary info in to run it in the docker?
dockerfile:
#version of container: 0.1.0
FROM ubuntu:20.04
ENV TZ=Europe/Oslo
#add repository and update the container
#Installation of nesesary package/software for this containers...
RUN DEBIAN_FRONTEND="noninteractive" apt-get update && DEBIAN_FRONTEND="noninteractive" apt-get install -y -q wget \
                                          libarchive13 \
                                          libxml2 \
                                          sharutils \
                                          tzdata \
                                          gawk \
                                          libc-ares2 \
                                          libavahi-compat-libdnssd-dev \
                                          libwebsockets15 \
                                          libcurl4 \
                                          && apt --fix-broken install && wget https://storage.z-wave.me/z-way-server/z-way-3.1.3_amd64.deb && dpkg -i z-way-*.deb
CMD ["/bin/bash"]
ENV LD_LIBRARY_PATH=/opt/z-way-server/libs
ENV PATH=/opt/z-way-server:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
VOLUME ["/opt/z-way-server/config/zddl"]
VOLUME ["/opt/z-way-server/automation/storage"]
# to allow access from outside of the container  to the container service
# at that ports need to allow access from firewall if need to access it outside of the server.
EXPOSE 8083
WORKDIR /opt/z-way-server
# Use baseimage-docker's init system.
CMD ["z-way-server"]
docker compose:
version: "3.9"
services:
  Z-Way:
    container_name: Z-Way
    restart: always
    image: perhu/z-way-server-3-1-3:latest
    networks:
      HAnett:
        ipv4_address: 192.168.0.2
    ports:
      - "8083:8083"
    volumes:
      - type: volume
        source: Z-Way-zddl
        target: /opt/z-way-server/config/zddl
      - type: volume
        source: Z-Way-storage
        target: /opt/z-way-server/automation/storage
    devices:
      - "/dev/serial/by-id/usb-0658_0200-if00:/dev/serial/by-id/usb-0658_0200-if00" #your device here
    environment:
      - ZWAY_VERSION=3.1.3
networks:					#I set up a network for the dockers to communicate, with static IPs
    HAnett:
        driver: bridge
        ipam:
            config:
                - subnet: 192.168.0.0/16
                  gateway: 192.168.0.254
volumes:
  Z-Way-zddl:
  Z-Way-storage:
should be
VOLUME ["/opt/z-way-server/config/zddx"]
Do you think it is worth to make a deb package with Docker? How would you like to see this if we integrate it?
SweetGenius
Post by SweetGenius »
I would love to see a downloadable Docker Image compatible with Docker running on Synology NAS or complete instructions with a docker run command or different versions of docker compose file.
PerH
Post by PerH »
Sorry, haven't looked into this forum in a while. (which means z-way works well! ;-) )
you are offcourse right about zddx, and i did fix it in my own files.. its just replacing the "l" with an "x" in the files.
I have all my automation components in docker now, and i find it so much easier to maintain! A lot of the HA SW providers are offering official dockers now, so i think taht would be a great addition for z-way.
The one i have works great now, but mabye an alpine build would be better? Mainly thinking of image size, which is fairly large with ubuntu, and size matters on some more bare-bone platforms.
adding my updated dockerfile and compose, as i've added timezone bind. I also changed to docker-compose version 3.7 in hope that the synology users can use it:
dockerfile:
FROM ubuntu:20.04
ENV TZ=Europe/Oslo
                                          libarchive13 \
                                          libxml2 \
                                          sharutils \
                                          tzdata \
                                          gawk \
                                          libc-ares2 \
                                          libwebsockets15 \
                                          libcurl4 \
CMD ["/bin/bash"]
EXPOSE 8083
docker-compose:
version: "3.7"
services:
  Z-Way:
    container_name: Z-Way #or what you want to call it
    restart: always
    networks:
      HAnett:  #or whatever you internal docker network is called
        ipv4_address: 192.168.0.2  #this volume gets this IP in the internal network
    ports:
      - "8083:8083" #UI port
    volumes:
      - type: bind    #timezone sync
        source: /etc/localtime
        target: /etc/localtime
      - type: volume
        source: Z-Way-zddx #Device info storage (i think)
        target: /opt/z-way-server/config/zddx
      - type: volume
        source: Z-Way-storage #application settings
    devices:
    environment:
    logging:
        driver: "json-file"
        options:
            max-file: "5"
            max-size: 10m
    HAnett:
        driver: bridge
        ipam:
            config:
                - subnet: 192.168.0.0/16 #subnet of choice
                  gateway: 192.168.0.254 #gateway ip (this can be used to reach ser2net devices on host)
volumes:
  Z-Way-zddx:
  Z-Way-storage:
PerH
Post by PerH »
@PoltoS: Is information about plugins and settings stored elsewhere than the folders i've set to be persistent in the docker?
@SweetGenious here has some issues with the RemoteAccess app, and it works a bit differently in the docker for some reason..
And it seems like time-zone changes are not working inside the docker. Does Z-way just run a root command to change it? If so, there might be some permission issues to handle in my docker..
sofakng
Post by sofakng »
I'm also wondering about this.
What folder(s) does Z-Way store it's persistent data/configuration data?
Are the two folders mentioned above the only two?
sofakng wrote:
16 Jun 2021 20:46
Correct.
But there are few more folders with downloaded content: /opt/z-way-server/automation/userModules and /opt/z-way-server/htdocs/smarthome/user/
