Qubino Smart Plug - weird voltage/amperage readings
CorC
Post by CorC »
Dear,
I've two Qubino Smart Plug's, which have been working fine for several weeks, until a week ago one of the devices suddenly failed.
I've re-included the failed device, and it has been working fine, except for some of the sensor values, it reports very weird values.
I've performed a factory reset of the device, and re-included it again, however it keeps reporting weird values on the voltage/amperage/watt sensors, the meter (kWH) report seems accurate though.
Could this have something to do with the z-way software, is there anything I can do to debug / make sure it's a hardware problem before returning it to the supplier?
Kind Regards,
Cor
enbemokel
Re: Qubino Smart Plug - weird voltage/amperage readings
Post by enbemokel »
Hi, had something similiar with devices that I bought 2nd hand. I had to Reset them in the
Expert - Control - Meters section. (I assume that your screenshot is from this page also)
Seems that these devices hold the values, which i didn´t expect, or there is some wrong
interpretation in z-way.
Best regards
Nico
Worth to check the log, but I would opt for device issue.
CorC
Post by CorC »
I've reset the meter, somehow that only resets the actual meter, not the sensor values, it's the sensor that's being problematic, and I can't find a reset option software wise for the sensors. Thats why I did a factory reset on the device itself, didn't help either.
Hereby the logs, from what I make up here, the device actually reports these "weird" values itself ?
[2020-10-16 13:49:52.366] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:52.368] [I] [zway] Adding job: Meter Get (v2/3)
[2020-10-16 13:49:52.370] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:52.372] [I] [zway] Adding job: Meter Get (v2/3)
[2020-10-16 13:49:52.374] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:52.376] [I] [zway] Adding job: Meter Get (v2/3)
[2020-10-16 13:49:52.378] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:52.380] [I] [zway] Adding job: Meter Get (v2/3)
[2020-10-16 13:49:52.384] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:52.396] [D] [zway] SENDING (cb 0xa3): ( 01 16 00 13 32 0F 9F 03 81 00 17 F7 E5 A8 25 54 C6 F5 67 7A 87 25 A3 29 )
[2020-10-16 13:49:52.398] [D] [zway] Secure payload: ( 32 01 00 )
[2020-10-16 13:49:52.403] [D] [zway] RECEIVED ACK
[2020-10-16 13:49:52.407] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-16 13:49:52.407] [D] [zway] SENT ACK
[2020-10-16 13:49:52.407] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Response received - transfered to encapsulated jobs
[2020-10-16 13:49:52.408] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:52.602] [D] [zway] RECEIVED: ( 01 18 00 13 A3 00 00 12 01 C1 7F 7F 7F 7F 01 01 03 23 00 00 00 01 01 00 00 A5 )
[2020-10-16 13:49:52.603] [D] [zway] SENT ACK
[2020-10-16 13:49:52.605] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Callback received - transfered to encapsulated jobs
[2020-10-16 13:49:52.607] [I] [zway] Job 0x13 (Meter Get (v2/3)): Delivered
[2020-10-16 13:49:52.608] [D] [zway] SendData Response with callback 0xa3 received: received by recipient
[2020-10-16 13:49:52.610] [D] [zway] Job 0x13 (Meter Get (v2/3)): success
[2020-10-16 13:49:52.612] [I] [zway] Waiting for job reply: Meter Get (v2/3)
[2020-10-16 13:49:52.613] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Delivered
[2020-10-16 13:49:52.615] [D] [zway] SendData Response with callback 0xa3 received: received by recipient
[2020-10-16 13:49:52.617] [D] [zway] SETDATA devices.50.data.lastSendInternal = **********
[2020-10-16 13:49:52.619] [D] [zway] SETDATA devices.50.data.lastSend = 17765531 (0x010f149b)
[2020-10-16 13:49:52.621] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): success
[2020-10-16 13:49:52.622] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:52.756] [D] [zway] RECEIVED: ( 01 20 00 04 00 32 16 9F 03 B6 00 AD 22 65 D8 F3 74 24 2E FC 94 9E 75 86 EF 63 99 1D AB BF 00 01 23 51 )
[2020-10-16 13:49:52.758] [D] [zway] SENT ACK
[2020-10-16 13:49:52.761] [D] [zway] SETDATA devices.50.data.lastReceived = 0 (0x00000000)
[2020-10-16 13:49:52.763] [I] [zway] Node 50:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 32 02 21 24 00 00 0b c3 00 00 ]
[2020-10-16 13:49:52.765] [D] [zway] Received reply on job (Meter Get (v2/3))
[2020-10-16 13:49:52.768] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0.val = 301.100006
[2020-10-16 13:49:52.770] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0.delta = 0 (0x00000000)
[2020-10-16 13:49:52.772] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2020-10-16 13:49:52.774] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0 = Empty
[2020-10-16 13:49:52.778] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:52.786] [I] [core] HK: updated ZWayVDev_zway_50-0-50-0
[2020-10-16 13:49:52.797] [D] [zway] SENDING (cb 0xa4): ( 01 16 00 13 32 0F 9F 03 82 00 A9 6E 32 2E 2B 6A AA 3B 93 EA 9B 25 A4 B1 )
[2020-10-16 13:49:52.799] [D] [zway] Secure payload: ( 32 01 10 )
[2020-10-16 13:49:52.804] [D] [zway] RECEIVED ACK
[2020-10-16 13:49:52.808] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-16 13:49:52.808] [D] [zway] SENT ACK
[2020-10-16 13:49:52.809] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Response received - transfered to encapsulated jobs
[2020-10-16 13:49:52.809] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:52.940] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:52.942] [I] [zway] Adding job: Meter Get (v2/3)
[2020-10-16 13:49:52.944] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:52.946] [I] [zway] Adding job: Meter Get (v2/3)
[2020-10-16 13:49:52.948] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:52.950] [D] [zway] Job 0x13 (Meter Get (v2/3)): removing duplicate
[2020-10-16 13:49:52.952] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:52.954] [D] [zway] Job 0x13 (Meter Get (v2/3)): removing duplicate
[2020-10-16 13:49:52.970] [I] [core] [BaseModule-14] Set lastLevel to 301.1000064 for ZWayVDev_zway_50-0-50-0 (was 300.7000064)
[2020-10-16 13:49:53.064] [D] [zway] RECEIVED: ( 01 18 00 13 A4 00 00 19 01 C1 7F 7F 7F 7F 01 01 03 23 00 00 00 01 01 00 00 A9 )
[2020-10-16 13:49:53.064] [D] [zway] SENT ACK
[2020-10-16 13:49:53.065] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Callback received - transfered to encapsulated jobs
[2020-10-16 13:49:53.065] [I] [zway] Job 0x13 (Meter Get (v2/3)): Delivered
[2020-10-16 13:49:53.065] [D] [zway] SendData Response with callback 0xa4 received: received by recipient
[2020-10-16 13:49:53.065] [D] [zway] Job 0x13 (Meter Get (v2/3)): success
[2020-10-16 13:49:53.065] [I] [zway] Waiting for job reply: Meter Get (v2/3)
[2020-10-16 13:49:53.066] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Delivered
[2020-10-16 13:49:53.072] [D] [zway] SendData Response with callback 0xa4 received: received by recipient
[2020-10-16 13:49:53.074] [D] [zway] SETDATA devices.50.data.lastSendInternal = **********
[2020-10-16 13:49:53.076] [D] [zway] SETDATA devices.50.data.lastSend = 17765573 (0x010f14c5)
[2020-10-16 13:49:53.077] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): success
[2020-10-16 13:49:53.079] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:53.226] [D] [zway] RECEIVED: ( 01 20 00 04 00 32 16 9F 03 B7 00 88 BB E1 20 D1 68 2F DC 4C 75 32 BE 66 6B A5 DC 11 56 BF 00 01 23 77 )
[2020-10-16 13:49:53.228] [D] [zway] SENT ACK
[2020-10-16 13:49:53.230] [D] [zway] SETDATA devices.50.data.lastReceived = 0 (0x00000000)
[2020-10-16 13:49:53.235] [I] [zway] Node 50:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 32 02 21 34 00 00 71 ed 00 00 ]
[2020-10-16 13:49:53.237] [D] [zway] Received reply on job (Meter Get (v2/3))
[2020-10-16 13:49:53.240] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2.val = 2916.500000
[2020-10-16 13:49:53.242] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-10-16 13:49:53.244] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-10-16 13:49:53.246] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2 = Empty
[2020-10-16 13:49:53.252] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:53.267] [D] [zway] SENDING (cb 0xa5): ( 01 16 00 13 32 0F 9F 03 83 00 EE 19 B6 EE E8 B7 2A E3 6A 62 4B 25 A5 22 )
[2020-10-16 13:49:53.269] [D] [zway] Secure payload: ( 32 01 00 )
[2020-10-16 13:49:53.274] [D] [zway] RECEIVED ACK
[2020-10-16 13:49:53.278] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-16 13:49:53.278] [D] [zway] SENT ACK
[2020-10-16 13:49:53.279] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Response received - transfered to encapsulated jobs
[2020-10-16 13:49:53.279] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:53.316] [I] [core] HK: updated ZWayVDev_zway_50-0-50-2
[2020-10-16 13:49:53.466] [I] [core] [BaseModule-14] Set lastLevel to 2916.5000704 for ZWayVDev_zway_50-0-50-2 (was 2902.4999424)
[2020-10-16 13:49:53.538] [D] [zway] RECEIVED: ( 01 18 00 13 A5 00 00 19 01 C1 7F 7F 7F 7F 01 01 03 23 00 00 00 01 01 00 00 A8 )
[2020-10-16 13:49:53.539] [D] [zway] SENT ACK
[2020-10-16 13:49:53.539] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Callback received - transfered to encapsulated jobs
[2020-10-16 13:49:53.539] [I] [zway] Job 0x13 (Meter Get (v2/3)): Delivered
[2020-10-16 13:49:53.540] [D] [zway] SendData Response with callback 0xa5 received: received by recipient
[2020-10-16 13:49:53.540] [D] [zway] Job 0x13 (Meter Get (v2/3)): success
[2020-10-16 13:49:53.540] [I] [zway] Waiting for job reply: Meter Get (v2/3)
[2020-10-16 13:49:53.540] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Delivered
[2020-10-16 13:49:53.547] [D] [zway] SendData Response with callback 0xa5 received: received by recipient
[2020-10-16 13:49:53.549] [D] [zway] SETDATA devices.50.data.lastSendInternal = **********
[2020-10-16 13:49:53.550] [D] [zway] SETDATA devices.50.data.lastSend = 17765616 (0x010f14f0)
[2020-10-16 13:49:53.552] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): success
[2020-10-16 13:49:53.554] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:53.697] [D] [zway] RECEIVED: ( 01 20 00 04 00 32 16 9F 03 B8 00 10 C7 AA 33 64 D4 11 A8 84 59 D6 B6 3F 45 70 33 98 33 BF 00 01 23 2E )
[2020-10-16 13:49:53.697] [D] [zway] SENT ACK
[2020-10-16 13:49:53.698] [D] [zway] SETDATA devices.50.data.lastReceived = 0 (0x00000000)
[2020-10-16 13:49:53.701] [I] [zway] Node 50:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 32 02 21 24 00 00 0b c3 00 00 ]
[2020-10-16 13:49:53.707] [D] [zway] Received reply on job (Meter Get (v2/3))
[2020-10-16 13:49:53.709] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0.val = 301.100006
[2020-10-16 13:49:53.711] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0.delta = 0 (0x00000000)
[2020-10-16 13:49:53.712] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2020-10-16 13:49:53.714] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0 = Empty
[2020-10-16 13:49:53.719] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:53.723] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:53.725] [I] [zway] Adding job: Meter Get (v2/3)
[2020-10-16 13:49:53.727] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:53.728] [I] [zway] Adding job: Meter Get (v2/3)
[2020-10-16 13:49:53.731] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:53.732] [D] [zway] Job 0x13 (Meter Get (v2/3)): removing duplicate
[2020-10-16 13:49:53.735] [I] [zway] Using security scheme S2 Authenticated
[2020-10-16 13:49:53.736] [D] [zway] Job 0x13 (Meter Get (v2/3)): removing duplicate
[2020-10-16 13:49:53.740] [D] [zway] SENDING (cb 0xa6): ( 01 16 00 13 32 0F 9F 03 84 00 C0 38 C9 71 9B 4C FE 05 34 AD E8 25 A6 41 )
[2020-10-16 13:49:53.741] [D] [zway] Secure payload: ( 32 01 10 )
[2020-10-16 13:49:53.746] [D] [zway] RECEIVED ACK
[2020-10-16 13:49:53.750] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-16 13:49:53.751] [D] [zway] SENT ACK
[2020-10-16 13:49:53.753] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Response received - transfered to encapsulated jobs
[2020-10-16 13:49:53.754] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:53.757] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:53.782] [I] [core] HK: updated ZWayVDev_zway_50-0-50-0
[2020-10-16 13:49:54.005] [D] [zway] RECEIVED: ( 01 18 00 13 A6 00 00 19 01 BF 7F 7F 7F 7F 01 01 03 23 00 00 00 01 01 00 00 D5 )
[2020-10-16 13:49:54.007] [D] [zway] SENT ACK
[2020-10-16 13:49:54.008] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Callback received - transfered to encapsulated jobs
[2020-10-16 13:49:54.011] [I] [zway] Job 0x13 (Meter Get (v2/3)): Delivered
[2020-10-16 13:49:54.013] [D] [zway] SendData Response with callback 0xa6 received: received by recipient
[2020-10-16 13:49:54.014] [D] [zway] Job 0x13 (Meter Get (v2/3)): success
[2020-10-16 13:49:54.016] [I] [zway] Waiting for job reply: Meter Get (v2/3)
[2020-10-16 13:49:54.018] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Delivered
[2020-10-16 13:49:54.020] [D] [zway] SendData Response with callback 0xa6 received: received by recipient
[2020-10-16 13:49:54.022] [D] [zway] SETDATA devices.50.data.lastSendInternal = **********
[2020-10-16 13:49:54.024] [D] [zway] SETDATA devices.50.data.lastSend = 17765657 (0x010f1519)
[2020-10-16 13:49:54.026] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): success
[2020-10-16 13:49:54.028] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:54.180] [D] [zway] RECEIVED: ( 01 20 00 04 00 32 16 9F 03 B9 00 31 5C 5D E9 7D 20 17 84 B0 1F 7A AC A8 34 79 E2 E4 0B BF 00 01 23 C1 )
[2020-10-16 13:49:54.182] [D] [zway] SENT ACK
[2020-10-16 13:49:54.184] [D] [zway] SETDATA devices.50.data.lastReceived = 0 (0x00000000)
[2020-10-16 13:49:54.190] [I] [zway] Node 50:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 32 02 21 34 00 00 71 df 00 00 ]
[2020-10-16 13:49:54.192] [D] [zway] Received reply on job (Meter Get (v2/3))
[2020-10-16 13:49:54.194] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2.val = 2915.100098
[2020-10-16 13:49:54.196] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-10-16 13:49:54.198] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-10-16 13:49:54.201] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2 = Empty
[2020-10-16 13:49:54.211] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:54.214] [I] [core] HK: updated ZWayVDev_zway_50-0-50-2
[2020-10-16 13:49:54.224] [D] [zway] SENDING (cb 0xa7): ( 01 16 00 13 32 0F 9F 03 85 00 48 AF 24 FC 4E CF 4D F6 5F 6D 84 25 A7 EF )
[2020-10-16 13:49:54.225] [D] [zway] Secure payload: ( 32 01 00 )
[2020-10-16 13:49:54.230] [D] [zway] RECEIVED ACK
[2020-10-16 13:49:54.234] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-16 13:49:54.235] [D] [zway] SENT ACK
[2020-10-16 13:49:54.235] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Response received - transfered to encapsulated jobs
[2020-10-16 13:49:54.235] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:54.236] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:54.413] [I] [core] [BaseModule-14] Set lastLevel to 2915.1000576 for ZWayVDev_zway_50-0-50-2 (was 2916.5000704)
[2020-10-16 13:49:54.484] [D] [zway] RECEIVED: ( 01 18 00 13 A7 00 00 19 01 C1 7F 7F 7F 7F 01 01 03 23 00 00 00 01 01 00 00 AA )
[2020-10-16 13:49:54.484] [D] [zway] SENT ACK
[2020-10-16 13:49:54.485] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Callback received - transfered to encapsulated jobs
[2020-10-16 13:49:54.485] [I] [zway] Job 0x13 (Meter Get (v2/3)): Delivered
[2020-10-16 13:49:54.485] [D] [zway] SendData Response with callback 0xa7 received: received by recipient
[2020-10-16 13:49:54.485] [D] [zway] Job 0x13 (Meter Get (v2/3)): success
[2020-10-16 13:49:54.485] [I] [zway] Waiting for job reply: Meter Get (v2/3)
[2020-10-16 13:49:54.486] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Delivered
[2020-10-16 13:49:54.487] [D] [zway] SendData Response with callback 0xa7 received: received by recipient
[2020-10-16 13:49:54.490] [D] [zway] SETDATA devices.50.data.lastSendInternal = **********
[2020-10-16 13:49:54.500] [D] [zway] SETDATA devices.50.data.lastSend = 17765701 (0x010f1545)
[2020-10-16 13:49:54.501] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): success
[2020-10-16 13:49:54.506] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:54.649] [D] [zway] RECEIVED: ( 01 20 00 04 00 32 16 9F 03 BA 00 22 B6 B1 EB 45 B6 F8 56 A8 F8 6A 8A 9A 3D 8A D5 2E 44 BF 00 01 23 F5 )
[2020-10-16 13:49:54.649] [D] [zway] SENT ACK
[2020-10-16 13:49:54.650] [D] [zway] SETDATA devices.50.data.lastReceived = 0 (0x00000000)
[2020-10-16 13:49:54.653] [I] [zway] Node 50:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 32 02 21 24 00 00 0b c3 00 00 ]
[2020-10-16 13:49:54.656] [D] [zway] Received reply on job (Meter Get (v2/3))
[2020-10-16 13:49:54.658] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0.val = 301.100006
[2020-10-16 13:49:54.659] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0.delta = 0 (0x00000000)
[2020-10-16 13:49:54.661] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2020-10-16 13:49:54.663] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.0 = Empty
[2020-10-16 13:49:54.671] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:54.684] [D] [zway] SENDING (cb 0xa8): ( 01 16 00 13 32 0F 9F 03 86 00 14 F8 9C CD F0 42 0F 09 1F 09 A9 25 A8 E6 )
[2020-10-16 13:49:54.686] [D] [zway] Secure payload: ( 32 01 10 )
[2020-10-16 13:49:54.691] [D] [zway] RECEIVED ACK
[2020-10-16 13:49:54.695] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-16 13:49:54.695] [D] [zway] SENT ACK
[2020-10-16 13:49:54.696] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Response received - transfered to encapsulated jobs
[2020-10-16 13:49:54.696] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:54.725] [I] [core] HK: updated ZWayVDev_zway_50-0-50-0
[2020-10-16 13:49:54.955] [D] [zway] RECEIVED: ( 01 18 00 13 A8 00 00 1A 01 C1 7F 7F 7F 7F 01 01 03 23 00 00 00 01 01 00 00 A6 )
[2020-10-16 13:49:54.957] [D] [zway] SENT ACK
[2020-10-16 13:49:54.959] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Callback received - transfered to encapsulated jobs
[2020-10-16 13:49:54.961] [I] [zway] Job 0x13 (Meter Get (v2/3)): Delivered
[2020-10-16 13:49:54.963] [D] [zway] SendData Response with callback 0xa8 received: received by recipient
[2020-10-16 13:49:54.964] [D] [zway] Job 0x13 (Meter Get (v2/3)): success
[2020-10-16 13:49:54.966] [I] [zway] Waiting for job reply: Meter Get (v2/3)
[2020-10-16 13:49:54.967] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Delivered
[2020-10-16 13:49:54.970] [D] [zway] SendData Response with callback 0xa8 received: received by recipient
[2020-10-16 13:49:54.972] [D] [zway] SETDATA devices.50.data.lastSendInternal = **********
[2020-10-16 13:49:54.974] [D] [zway] SETDATA devices.50.data.lastSend = 17765744 (0x010f1570)
[2020-10-16 13:49:54.976] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): success
[2020-10-16 13:49:54.977] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:55.113] [D] [zway] RECEIVED: ( 01 20 00 04 00 32 16 9F 03 BB 00 35 8E E2 E5 76 20 78 7A 7F 5F A0 B0 85 EB 59 C8 52 34 BF 00 01 23 04 )
[2020-10-16 13:49:55.115] [D] [zway] SENT ACK
[2020-10-16 13:49:55.117] [D] [zway] SETDATA devices.50.data.lastReceived = 0 (0x00000000)
[2020-10-16 13:49:55.120] [I] [zway] Node 50:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 32 02 21 34 00 00 71 cb 00 00 ]
[2020-10-16 13:49:55.122] [D] [zway] Received reply on job (Meter Get (v2/3))
[2020-10-16 13:49:55.125] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2.val = 2913.100098
[2020-10-16 13:49:55.127] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-10-16 13:49:55.129] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-10-16 13:49:55.131] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.2 = Empty
[2020-10-16 13:49:55.136] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:55.144] [I] [core] HK: updated ZWayVDev_zway_50-0-50-2
[2020-10-16 13:49:55.152] [D] [zway] SENDING (cb 0xa9): ( 01 16 00 13 32 0F 9F 03 87 00 E3 1F C6 FC DD 32 55 E7 7B 46 D9 25 A9 2F )
[2020-10-16 13:49:55.154] [D] [zway] Secure payload: ( 32 01 20 )
[2020-10-16 13:49:55.159] [D] [zway] RECEIVED ACK
[2020-10-16 13:49:55.163] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-16 13:49:55.163] [D] [zway] SENT ACK
[2020-10-16 13:49:55.164] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Response received - transfered to encapsulated jobs
[2020-10-16 13:49:55.164] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:55.230] [D] [zway] Job 0x3b: deleted from queue
[2020-10-16 13:49:55.325] [I] [core] [BaseModule-14] Set lastLevel to 2913.1001856 for ZWayVDev_zway_50-0-50-2 (was 2915.1000576)
[2020-10-16 13:49:55.428] [D] [zway] RECEIVED: ( 01 18 00 13 A9 00 00 1A 01 BF 7F 7F 7F 7F 01 01 03 23 00 00 00 01 01 00 00 D9 )
[2020-10-16 13:49:55.429] [D] [zway] SENT ACK
[2020-10-16 13:49:55.431] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Callback received - transfered to encapsulated jobs
[2020-10-16 13:49:55.433] [I] [zway] Job 0x13 (Meter Get (v2/3)): Delivered
[2020-10-16 13:49:55.436] [D] [zway] SendData Response with callback 0xa9 received: received by recipient
[2020-10-16 13:49:55.444] [D] [zway] Job 0x13 (Meter Get (v2/3)): success
[2020-10-16 13:49:55.446] [I] [zway] Waiting for job reply: Meter Get (v2/3)
[2020-10-16 13:49:55.448] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Delivered
[2020-10-16 13:49:55.452] [D] [zway] SendData Response with callback 0xa9 received: received by recipient
[2020-10-16 13:49:55.456] [D] [zway] SETDATA devices.50.data.lastSendInternal = **********
[2020-10-16 13:49:55.458] [D] [zway] SETDATA devices.50.data.lastSend = 17765786 (0x010f159a)
[2020-10-16 13:49:55.462] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): success
[2020-10-16 13:49:55.463] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:55.583] [D] [zway] RECEIVED: ( 01 20 00 04 00 32 16 9F 03 BC 00 0F 41 E5 E0 C7 8D E6 B2 C3 35 C5 80 76 EC 36 E0 98 9C BF 00 01 23 EC )
[2020-10-16 13:49:55.585] [D] [zway] SENT ACK
[2020-10-16 13:49:55.587] [D] [zway] SETDATA devices.50.data.lastReceived = 0 (0x00000000)
[2020-10-16 13:49:55.593] [I] [zway] Node 50:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 32 02 a1 04 00 00 19 a3 00 00 ]
[2020-10-16 13:49:55.595] [D] [zway] Received reply on job (Meter Get (v2/3))
[2020-10-16 13:49:55.598] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.4.val = 6563.000000
[2020-10-16 13:49:55.600] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.4.delta = 0 (0x00000000)
[2020-10-16 13:49:55.602] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.4.ratetype = 1 (0x00000001)
[2020-10-16 13:49:55.604] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.4 = Empty
[2020-10-16 13:49:55.613] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:55.626] [D] [zway] SENDING (cb 0xaa): ( 01 16 00 13 32 0F 9F 03 88 00 92 B9 40 2B 3B 00 E6 7A 41 86 5D 25 AA 21 )
[2020-10-16 13:49:55.627] [D] [zway] Secure payload: ( 32 01 28 )
[2020-10-16 13:49:55.635] [D] [zway] RECEIVED ACK
[2020-10-16 13:49:55.636] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-16 13:49:55.638] [D] [zway] SENT ACK
[2020-10-16 13:49:55.640] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Response received - transfered to encapsulated jobs
[2020-10-16 13:49:55.641] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:55.643] [D] [zway] Delivered to Z-Wave stack
[2020-10-16 13:49:55.669] [I] [core] HK: updated ZWayVDev_zway_50-0-50-4
[2020-10-16 13:49:55.816] [I] [core] [BaseModule-14] Set lastLevel to 6562.9999104 for ZWayVDev_zway_50-0-50-4 (was 6643.0001152)
[2020-10-16 13:49:55.892] [D] [zway] RECEIVED: ( 01 18 00 13 AA 00 00 1A 01 BF 7F 7F 7F 7F 01 01 03 23 00 00 00 01 01 00 00 DA )
[2020-10-16 13:49:55.893] [D] [zway] SENT ACK
[2020-10-16 13:49:55.893] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Callback received - transfered to encapsulated jobs
[2020-10-16 13:49:55.894] [I] [zway] Job 0x13 (Meter Get (v2/3)): Delivered
[2020-10-16 13:49:55.894] [D] [zway] SendData Response with callback 0xaa received: received by recipient
[2020-10-16 13:49:55.894] [D] [zway] Job 0x13 (Meter Get (v2/3)): success
[2020-10-16 13:49:55.894] [I] [zway] Waiting for job reply: Meter Get (v2/3)
[2020-10-16 13:49:55.894] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): Delivered
[2020-10-16 13:49:55.898] [D] [zway] SendData Response with callback 0xaa received: received by recipient
[2020-10-16 13:49:55.904] [D] [zway] SETDATA devices.50.data.lastSendInternal = **********
[2020-10-16 13:49:55.906] [D] [zway] SETDATA devices.50.data.lastSend = 17765828 (0x010f15c4)
[2020-10-16 13:49:55.907] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)): success
[2020-10-16 13:49:55.909] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), Meter Get (v2/3)
[2020-10-16 13:49:56.054] [D] [zway] RECEIVED: ( 01 20 00 04 00 32 16 9F 03 BD 00 89 A5 1A 59 48 04 92 EA E7 0C F1 C4 B8 94 D4 B3 5C BB BF 00 01 23 6A )
[2020-10-16 13:49:56.056] [D] [zway] SENT ACK
[2020-10-16 13:49:56.058] [D] [zway] SETDATA devices.50.data.lastReceived = 0 (0x00000000)
[2020-10-16 13:49:56.061] [I] [zway] Node 50:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 32 02 a1 6c 00 00 1b e7 00 00 ]
[2020-10-16 13:49:56.063] [D] [zway] Received reply on job (Meter Get (v2/3))
[2020-10-16 13:49:56.065] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.5.val = 7.143000
[2020-10-16 13:49:56.067] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.5.delta = 0 (0x00000000)
[2020-10-16 13:49:56.069] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.5.ratetype = 1 (0x00000001)
[2020-10-16 13:49:56.071] [D] [zway] SETDATA devices.50.instances.0.commandClasses.50.data.5 = Empty
[2020-10-16 13:49:56.122] [I] [core] HK: updated ZWayVDev_zway_50-0-50-5
Looks like. You can send it to Goap for investigation.
