Error when compiling custom class
TheRafal
Post by TheRafal »
Hi, i've build some customs classes for my project but i've a problem when compiling the sketch. All have the same error... This classes work on a standard Arduino MEGA.
The error is : Alarme_ucxx.c:584: syntax error: token -> '}' ; column 1
Alarme is my custom Class.
Here is the code in Alarm_uccss.c where error is.
//class Alarme DECLARATION
typedef struct cxx__class__Alarme_s
}cxx__class__Alarme;
and the Alarm.h file, i removed all lines, but error still here !
#pragma once
// Alarme.h
#include "Arduino.h"
class Alarme {
and the Alarme.cpp, empty too but error always here
#include "Alarme.h"
Alarme::Alarme()
Any idea of why i've this error ? I don't really understand... I rewrote three times the code without copy past without succsess
TheRafal
Re: Error when compiling custom class
Post by TheRafal »
So i try with different way to get my scketch work and i didn't use custom classes. Now i've another error. When compiling, the z-uno programmer make some error. Now, with Adafruti sensor libraries, it add double ; at the end of some functions... Why ? don't know, they are not in the original files but in the output files... Very frutrating to work with Z-uno...
p0lyg0n1
Post by p0lyg0n1 »
1. Add any field to class. For example int a. Your class has no fields. microC++ doesn’t support classes without fields.
2. Please post a code (about double). We will help you. You have to rewrite library a little to make it work with Z-Uno. You can look to libraries folder of Z-Uno cores to see already ported libraries. Use the same principles.
TheRafal
Post by TheRafal »
Hi Poly, before post here with the code a gave you, i've a full class with various field inside. I remove it one by one to test each time but error still here...
For the adafruit sensor, finally i didn't use it because i don't have time for this. It's to use with the MMA8451 and it's library... with the good datarate it seem to work properly
