An unexpected error occurred during loading data. Try to reload the page.
simplenotezy
Post by simplenotezy »
I have troubles getting started. I am getting error:
Please check <br>1.) if the controller is plugged in correctly, <br>2.) that in the app 'Z-Wave Network Access' the right port is entered <br>(UZB: '/dev/ttyACM0', RaZberry shield: '/dev/ttyAMA0', UZB-Windows: '\\.\COM3', Z-Stick: '/dev/ttyUSB0', embedded boxes: '/dev/ttyS0' or '/dev/ttyS1') <br>3.) the app is aktiv. If not you could activate it under Menu &gt; Apps &gt; Active or add a new one under Menu &gt; Apps &gt; Local. <br>The Setting 'Expert View' needs to be active under Menu &gt; My Settings
A few notes:
- My port is set to /dev/ttyACM0 (I am running a Z-Stick). But your guide says `/dev/ttyUSB0`. But if I run `MinOZW /dev/ttyACM0` I get:
pi@homebridge:~ $ MinOZW /dev/ttyACM0
Starting MinOZW with OpenZWave Version 1.6-1392-gb0afd4c6
2020-10-19 14:32:33.537 Error, Cannot find a path to the configuration files at ../../../config/, Using /usr/local/etc/openzwave/ instead...
2020-10-19 14:32:33.540 Info, Reading /usr/local/etc/openzwave/options.xml for Options
2020-10-19 14:32:33.540 Warning, Failed to Parse options.xml: Failed to open file
2020-10-19 14:32:33.540 Info, Options:
2020-10-19 14:32:33.540 Info, 	appendlogfile: false
2020-10-19 14:32:33.540 Info, 	associate: true
2020-10-19 14:32:33.540 Info, 	assumeawake: true
2020-10-19 14:32:33.540 Info, 	autoupdateconfigfile: true
2020-10-19 14:32:33.540 Info, 	configpath: /usr/local/etc/openzwave/
2020-10-19 14:32:33.540 Info, 	consoleoutput: true
2020-10-19 14:32:33.540 Info, 	customsecuredcc: 0x62,0x4c,0x63
2020-10-19 14:32:33.540 Info, 	drivermaxattempts: 5
2020-10-19 14:32:33.540 Info, 	dumptrigger: 4
2020-10-19 14:32:33.540 Info, 	dumptriggerlevel: 1
2020-10-19 14:32:33.540 Info, 	enablesis: true
2020-10-19 14:32:33.540 Info, 	enforcesecurereception: true
2020-10-19 14:32:33.540 Info, 	exclude:
2020-10-19 14:32:33.540 Info, 	include:
2020-10-19 14:32:33.540 Info, 	includeinstancelabel: true
2020-10-19 14:32:33.540 Info, 	interface:
2020-10-19 14:32:33.540 Info, 	intervalbetweenpolls: true
2020-10-19 14:32:33.540 Info, 	language:
2020-10-19 14:32:33.540 Info, 	logfilename: OZW_Log.txt
2020-10-19 14:32:33.540 Info, 	logging: true
2020-10-19 14:32:33.540 Info, 	networkkey:
2020-10-19 14:32:33.540 Info, 	notifyondriverunload: false
2020-10-19 14:32:33.541 Info, 	notifytransactions: false
2020-10-19 14:32:33.541 Info, 	performreturnroutes: false
2020-10-19 14:32:33.541 Info, 	pollinterval: 500
2020-10-19 14:32:33.541 Info, 	queueloglevel: 9
2020-10-19 14:32:33.541 Info, 	refreshallusercodes: false
2020-10-19 14:32:33.541 Info, 	reloadafterupdate: AWAKE
2020-10-19 14:32:33.541 Info, 	retrytimeout: 10000
2020-10-19 14:32:33.541 Info, 	saveconfiguration: true
2020-10-19 14:32:33.541 Info, 	saveloglevel: 8
2020-10-19 14:32:33.541 Info, 	securitystrategy: SUPPORTED
2020-10-19 14:32:33.541 Info, 	suppressvaluerefresh: false
2020-10-19 14:32:33.541 Info, 	userpath:
2020-10-19 14:32:33.541 Info, 	validatevaluechanges: true
2020-10-19 14:32:33.542 Always, OpenZwave Version 1.6-1392-gb0afd4c6 Starting Up
2020-10-19 14:32:33.573 Info, Loading Localization File /usr/local/etc/openzwave/Localization.xml
2020-10-19 14:32:33.577 Info, Loaded /usr/local/etc/openzwave/Localization.xml With Revision 12
2020-10-19 14:32:33.580 Always, Using Language Localization
2020-10-19 14:32:33.591 Info, Loading NotificationCCTypes File /usr/local/etc/openzwave/NotificationCCTypes.xml
2020-10-19 14:32:33.591 Info, Loaded /usr/local/etc/openzwave/NotificationCCTypes.xml With Revision 11
2020-10-19 14:32:33.597 Info, Loading SensorMultiLevelCCTypes File /usr/local/etc/openzwave/SensorMultiLevelCCTypes.xml
2020-10-19 14:32:33.598 Info, Loaded /usr/local/etc/openzwave/SensorMultiLevelCCTypes.xml With Revision 4
2020-10-19 14:32:33.599 Info, Setting Up Provided Network Key for Secure Communications
2020-10-19 14:32:33.599 Warning, Failed - Network Key Not Set
2020-10-19 14:32:33.641 Info, Manufacturer_Specific.xml file Revision is 122
2020-10-19 14:32:35.446 Info, Product name collision: SmartCode 910 type 1 id 1 manufacturerid 90, collides with Touchpad Electronic Deadbolt, type 1 id 1 manufacturerid 90
2020-10-19 14:32:36.519 Info, Queuing Lookup on mfs.db.openzwave.com for Node 0
2020-10-19 14:32:36.520 Info,   Opening controller /dev/ttyACM0
2020-10-19 14:32:36.521 Info, Starting DNSThread
2020-10-19 14:32:36.521 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2020-10-19 14:32:36.521 Info, Timer: thread starting
2020-10-19 14:32:36.522 Detail, Timer: waiting with timeout -1 ms
2020-10-19 14:32:36.522 Info, LookupTxT Checking mfs.db.openzwave.com
2020-10-19 14:32:36.522 Info, mgr,     Added driver for controller /dev/ttyACM0
2020-10-19 14:32:36.522 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2020-10-19 14:32:36.522 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-10-19 14:32:36.549 Info, Lookup for mfs.db.openzwave.com returned 122
2020-10-19 14:32:38.411 Info, ManufacturerSpecificDB Initialized
2020-10-19 14:32:38.412 Detail, Notification: ManufacturerSpecificDB Ready
2020-10-19 14:32:38.412 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-10-19 14:32:38.413 Info, contrlr, Encrypted Flag is 0
2020-10-19 14:32:38.415 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2020-10-19 14:32:38.415 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-10-19 14:32:38.416 Info, contrlr,     Static Controller library, version Z-Wave 4.54
2020-10-19 14:32:38.416 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-10-19 14:32:38.416 Detail, contrlr,   Expected reply was received
2020-10-19 14:32:38.417 Detail, contrlr,   Message transaction complete
2020-10-19 14:32:38.417 Detail, contrlr, Removing current message
2020-10-19 14:32:38.417 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-10-19 14:32:38.417 Info, contrlr, Encrypted Flag is 0
2020-10-19 14:32:38.419 Detail, contrlr,   Received: 0x01, 0x08, 0x01, 0x20, 0xd6, 0xcb, 0xdf, 0xe1, 0x01, 0xf4
2020-10-19 14:32:38.420 Detail,
2020-10-19 14:32:38.421 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xd6cbdfe1.  Our node ID = 1
2020-10-19 14:32:38.421 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-10-19 14:32:38.422 Detail, contrlr,   Expected reply was received
2020-10-19 14:32:38.422 Detail, contrlr,   Message transaction complete
2020-10-19 14:32:38.422 Detail, contrlr, Removing current message
2020-10-19 14:32:38.423 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-10-19 14:32:38.423 Info, contrlr, Encrypted Flag is 0
2020-10-19 14:32:38.424 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2020-10-19 14:32:38.425 Detail,
2020-10-19 14:32:38.425 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-10-19 14:32:38.425 Info, contrlr,     There is no SUC ID Server (SIS) in this network.
2020-10-19 14:32:38.425 Info, contrlr,     The PC controller is a primary controller.
2020-10-19 14:32:38.426 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-10-19 14:32:38.426 Detail, contrlr,   Expected reply was received
2020-10-19 14:32:38.426 Detail, contrlr,   Message transaction complete
2020-10-19 14:32:38.426 Detail, contrlr, Removing current message
2020-10-19 14:32:38.427 Detail,
2020-10-19 14:32:38.427 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-10-19 14:32:38.427 Info, contrlr, Encrypted Flag is 0
2020-10-19 14:32:38.428 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2020-10-19 14:32:38.429 Detail,
2020-10-19 14:32:38.429 Info, contrlr, Received reply to GET_SUC_NODE_ID.  Node ID = 0
2020-10-19 14:32:38.429 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2020-10-19 14:32:38.429 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-10-19 14:32:38.430 Detail, contrlr,   Expected reply was received
2020-10-19 14:32:38.430 Detail, contrlr,   Message transaction complete
2020-10-19 14:32:38.430 Detail, contrlr, Removing current message
2020-10-19 14:32:38.430 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-10-19 14:32:38.431 Info, contrlr, Encrypted Flag is 0
2020-10-19 14:32:38.435 Detail, contrlr,   Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x01, 0x00, 0x86, 0x01, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfb
2020-10-19 14:32:38.435 Info, contrlr,  Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2020-10-19 14:32:38.435 Info, contrlr,     Serial API Version:   1.1
2020-10-19 14:32:38.435 Info, contrlr,     Manufacturer ID:      0x0086
2020-10-19 14:32:38.435 Info, contrlr,     Product Type:         0x0101
2020-10-19 14:32:38.435 Info, contrlr,     Product ID:           0x005a
2020-10-19 14:32:38.436 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-10-19 14:32:38.436 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-10-19 14:32:38.436 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-10-19 14:32:38.436 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x08, 0x00, 0x03, 0x01, 0x02, 0x01, 0x01, 0x5e, 0xa9
2020-10-19 14:32:38.437 Detail, contrlr,   Expected reply was received
2020-10-19 14:32:38.437 Detail, contrlr,   Message transaction complete
2020-10-19 14:32:38.437 Detail, contrlr, Removing current message
2020-10-19 14:32:38.437 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-10-19 14:32:38.437 Info, contrlr, Encrypted Flag is 0
2020-10-19 14:32:38.494 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x19, 0xba, 0x3b, 0xdf, 0x0f, 0x98, 0x0d, 0x8c, 0x1e, 0x36, 0x1a, 0x81, 0xd8, 0x38, 0x2c, 0x94, 0xb1, 0xb2, 0xd3, 0x93, 0x6c, 0xad, 0x83, 0x26, 0xdd, 0x93, 0x4e, 0xbc, 0x69, 0x87, 0xad, 0x60, 0xe4
2020-10-19 14:32:38.494 Info, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2020-10-19 14:32:38.495 Detail, contrlr,   Expected reply was received
2020-10-19 14:32:38.495 Detail, contrlr,   Message transaction complete
2020-10-19 14:32:38.495 Detail, contrlr, Removing current message
2020-10-19 14:32:38.495 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-10-19 14:32:38.496 Info, contrlr, Encrypted Flag is 0
2020-10-19 14:32:38.598 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc5
2020-10-19 14:32:38.599 Detail,
2020-10-19 14:32:38.609 Info, mgr,     Driver with Home ID of 0xd6cbdfe1 is now ready.
2020-10-19 14:32:38.625 Info, Node001, (32 - COMMAND_CLASS_BASIC) - Compatibility Flags:
2020-10-19 14:32:38.625 Info, Node001, (32 - COMMAND_CLASS_BASIC) - State Flags:
2020-10-19 14:32:38.626 Info, Node001, 	 AfterMark: true
2020-10-19 14:32:38.626 Warning, Localization::ReadXMLVIDHelp: Error in ozwcache_0xd6cbdfe1.xml at line 36 - No Help Entry for CommandClass 32, ValueID: 1 (-1):  (null) (Lang: )
2020-10-19 14:32:38.627 Warning, Localization::ReadXMLVIDHelp: Error in ozwcache_0xd6cbdfe1.xml at line 39 - No Help Entry for CommandClass 32, ValueID: 2 (-1):  (null) (Lang: )
2020-10-19 14:32:38.627 Info, Node001, (112 - COMMAND_CLASS_CONFIGURATION) - Compatibility Flags:
2020-10-19 14:32:38.627 Info, Node001, (112 - COMMAND_CLASS_CONFIGURATION) - State Flags:
2020-10-19 14:32:38.628 Info, Node001, (114 - COMMAND_CLASS_MANUFACTURER_SPECIFIC) - Compatibility Flags:
2020-10-19 14:32:38.628 Info, Node001, (114 - COMMAND_CLASS_MANUFACTURER_SPECIFIC) - State Flags:
2020-10-19 14:32:38.628 Info, Node001, 	 StaticRequests: 2
2020-10-19 14:32:38.629 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2020-10-19 14:32:38.629 Info, contrlr,     Node 001 - Known
2020-10-19 14:32:38.629 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-10-19 14:32:38.629 Detail, Node001, QueryStage_CacheLoad
2020-10-19 14:32:38.629 Info, Node001, Loading Cache for node 1: Manufacturer=AEON Labs, Product=ZW090 Z-Stick Gen5 US
2020-10-19 14:32:38.630 Info, Node001, Node Identity Codes: 0086:0101:005a
2020-10-19 14:32:38.630 Detail, Node001, QueryStage_Associations
2020-10-19 14:32:38.630 Detail, Node001, QueryStage_Neighbors
2020-10-19 14:32:38.630 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2020-10-19 14:32:38.630 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-10-19 14:32:38.631 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2020-10-19 14:32:38.631 Detail, contrlr,   Expected reply was received
2020-10-19 14:32:38.631 Detail, contrlr,   Message transaction complete
2020-10-19 14:32:38.632 Detail, contrlr, Removing current message
2020-10-19 14:32:38.632 Detail, Node001, Notification: DriverReady
Driver ready with HomeID: 0xd6cbdfe1
Controller does not have extended TxStatus.
2020-10-19 14:32:38.632 Detail, Node001, Notification: NodeAdded
2020-10-19 14:32:38.633 Detail, Node001, Notification: NodeProtocolInfo
2020-10-19 14:32:38.633 Detail, Node001, Notification: EssentialNodeQueriesComplete
2020-10-19 14:32:38.633 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_BASIC Instance: 1 Index: 0
2020-10-19 14:32:38.633 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_BASIC Instance: 1 Index: 1
2020-10-19 14:32:38.633 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_BASIC Instance: 1 Index: 2
2020-10-19 14:32:38.634 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 81
2020-10-19 14:32:38.634 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 220
2020-10-19 14:32:38.634 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 242
2020-10-19 14:32:38.634 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 243
2020-10-19 14:32:38.635 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 252
2020-10-19 14:32:38.635 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 255
2020-10-19 14:32:38.635 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_MANUFACTURER_SPECIFIC Instance: 1 Index: 0
2020-10-19 14:32:38.635 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_MANUFACTURER_SPECIFIC Instance: 1 Index: 1
2020-10-19 14:32:38.635 Detail, Node001, Notification: ValueAdded CC: COMMAND_CLASS_MANUFACTURER_SPECIFIC Instance: 1 Index: 2
2020-10-19 14:32:38.636 Detail, Node001, Notification: NodeNaming
2020-10-19 14:32:38.636 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-10-19 14:32:38.636 Info, contrlr, Encrypted Flag is 0
2020-10-19 14:32:38.639 Detail, contrlr,   Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2020-10-19 14:32:38.639 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2020-10-19 14:32:38.639 Detail, contrlr,   Expected reply was received
2020-10-19 14:32:38.639 Detail, contrlr,   Message transaction complete
2020-10-19 14:32:38.640 Detail,
2020-10-19 14:32:38.640 Detail, contrlr, Removing current message
2020-10-19 14:32:38.640 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x08, 0x00, 0x03, 0x01, 0x02, 0x01, 0x01, 0x5e, 0xa9
2020-10-19 14:32:38.640 Info, contrlr, Encrypted Flag is 0
2020-10-19 14:32:38.643 Detail, contrlr, Removing current message
2020-10-19 14:32:38.643 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-10-19 14:32:38.643 Info, Node001, Encrypted Flag is 0
2020-10-19 14:32:38.654 Detail, Node001,   Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2020-10-19 14:32:38.655 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-10-19 14:32:38.655 Info, Node001,     Neighbors of this node are:
2020-10-19 14:32:38.655 Info, Node001,  (none reported)
2020-10-19 14:32:38.655 Detail, Node001,   Expected reply was received
2020-10-19 14:32:38.655 Detail, Node001,   Message transaction complete
2020-10-19 14:32:38.656 Detail, Node001, Removing current message
2020-10-19 14:32:38.656 Detail, Node001, Query Stage Complete (Neighbors)
2020-10-19 14:32:38.656 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2020-10-19 14:32:38.656 Detail, Node001, QueryStage_Session
2020-10-19 14:32:38.656 Detail, Node001, QueryStage_Dynamic
2020-10-19 14:32:38.657 Detail, Node001, QueryStage_Configuration
2020-10-19 14:32:38.657 Detail, Node001, QueryStage_Complete
2020-10-19 14:32:38.657 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-10-19 14:32:38.657 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2020-10-19 14:32:38.657 Info,          Node query processing complete.
2020-10-19 14:32:38.658 Info, Saving Cache
2020-10-19 14:32:38.658 Info, Node001, Cache Save for Node 1 as its QueryStage_CacheLoad
2020-10-19 14:32:38.662 Detail, Node001, Notification: NodeQueriesComplete
2020-10-19 14:32:38.663 Detail, contrlr, Notification: AllNodesQueried
NodeID: 1
 	 NodeName:
 	 ManufacturerName: AEON Labs
 	 NodeProductName: ZW090 Z-Stick Gen5 US
 Values announced by the nodes without polling:
	 ValueLabel: Basic
		 ValueType: byte (1)
		 ValueHelp: Basic status of the node
		 ValueUnits:
		 ValueMin: 0
		 ValueMax: 255
		 ValueGenre: basic (0)
SOF: 9 ACK Waiting: 0 Read Aborts: 0 Bad Checksums: 0
Reads: 9 Writes: 10 CAN: 0 NAK: 0 ACK: 10 Out of Frame: 0
Dropped: 0 Retries: 0
2020-10-19 14:32:38.663 Info, mgr,     Driver for controller /dev/ttyACM0 pending removal
2020-10-19 14:32:38.663 Detail, Notification: DriverRemoved
2020-10-19 14:32:38.663 Always, ***************************************************************************
2020-10-19 14:32:38.663 Always, *********************  Cumulative Network Statistics  *********************
2020-10-19 14:32:38.663 Always, *** General
2020-10-19 14:32:38.663 Always, Driver run time: . .  . 0 days, 0 hours, 0 minutes
2020-10-19 14:32:38.663 Always, Frames processed: . . . . . . . . . . . . . . . . . . . . 9
2020-10-19 14:32:38.664 Always, Total messages successfully received: . . . . . . . . . . 9
2020-10-19 14:32:38.664 Always, Total Messages successfully sent: . . . . . . . . . . . . 10
2020-10-19 14:32:38.664 Always, ACKs received from controller:  . . . . . . . . . . . . . 10
2020-10-19 14:32:38.664 Always, *** Errors
2020-10-19 14:32:38.664 Always, Unsolicited messages received while waiting for ACK:  . . 0
2020-10-19 14:32:38.664 Always, Reads aborted due to timeouts:  . . . . . . . . . . . . . 0
2020-10-19 14:32:38.664 Always, Bad checksum errors:  . . . . . . . . . . . . . . . . . . 0
2020-10-19 14:32:38.664 Always, CANs received from controller:  . . . . . . . . . . . . . 0
2020-10-19 14:32:38.664 Always, NAKs received from controller:  . . . . . . . . . . . . . 0
2020-10-19 14:32:38.664 Always, Out of frame data flow errors:  . . . . . . . . . . . . . 0
2020-10-19 14:32:38.664 Always, Messages retransmitted: . . . . . . . . . . . . . . . . . 0
2020-10-19 14:32:38.664 Always, Messages dropped and not delivered: . . . . . . . . . . . 0
2020-10-19 14:32:38.664 Always, ***************************************************************************
2020-10-19 14:32:38.664 Info, Saving Cache
2020-10-19 14:32:38.665 Info, Node001, Cache Save for Node 1 as its QueryStage_CacheLoad
2020-10-19 14:32:38.671 Info, Stopping DNSThread
2020-10-19 14:32:40.676 Info, mgr,     Driver for controller /dev/ttyACM0 removed
- "Expert View" is not present under "My settings" so I cant enable it.
- I am unsure how to add my device. It is a "Danfoss Eco 2 Thermostat"
Re: An unexpected error occurred during loading data. Try to reload the page.
Expert UI is accessible via IP:8083/expert/
