ExpertUI doesn't require login
http://IP:8083/expert doesn't require a login, http://IP:8083/smarthome does.
Raspbian GNU/Linux 10 (buster)
RaZberry by Z-Wave.Me ZW0500 6.82.01 05.39/35498 1024/2
Z-Way version v3.1.2 from 2020-12-31
Re: ExpertUI doesn't require login
Make sure to uncheck Public API in Z-Wave Binding in Smart Home UI
Sorry, I don't understand. What is 'Public API in Z-Wave Binding' and where can I find it?
Go in SH UI -> Apps -> Active -> Z-Wave Binding -> Public API checkbox. If it is on, then no password is required. This is good for trusted environment and old third party controllers not supporting HTTP API authentication.
OK, I found it in Z-Wave Network Access: Allow public access to Z-Wave API .
Thank you.
Thank you.
