Issue removing sensor
cyb0rg42
Post by cyb0rg42 »
I added a First Alert ZCOMBO (CO and Smoke sensor). The interview was not done quite right (Security S2). I want to add the sensor again, but in standard ui the sensor is not visible but in expert ui it is. How can I remove the sensor completely so I can redo the inclusion?
Re: Issue removing sensor
Go to Add and on top press Remove button first.
naveen555
Post by naveen555 »
Hi
Can you please tell me the steps you used and the setups to have First Alert show up in the z-way devices view? I can't seem to figure it out.
Thanks for your help
Naveen
zwaFisher
Post by zwaFisher »
Search here somewhere. There was a topic describing how to remove dead devices.
Shortly, from an Expert view you need to interview them. It fails. Then you can force removal.
JuniEdith
Post by JuniEdith »
Please help, i am also having the problem of removing the sensor. Let me try to solve the issue with the above recommendations.
