Wakeup not working
kina500
Wakeup not working
Post by kina500 »
Hi
I am trying to get a sketch to work like this one:
https://z-uno.z-wave.me/projects/sensor ... olo-glass/
When the Z-Uno module goes to sleep, it do not wakeup on Int1 through the diodes.
Do I have to setup or enable the interrupt?
The sketches all over Z-Uno page with sleep and wakeup examples, do not show I have to setup interrupt separately, but that INT1 should always wake a sleeping Z-Uno.
kina500
Re: Wakeup not working
Post by kina500 »
I used the blinds channel in above sketch.
Can you not put a battery operated blind into sleep mode?
kina500
Post by kina500 »
No, you cannot use the the blind zwave setup, if you want to sleep your device!
why not?
kina500
Post by kina500 »
Don't know.
If I chose Zuno blinds in Zwave setup, it is not possible to run sleep mode and wakeup.
Found this in the referencer ZUNO_BLINDS:
This type is allowed only in ZUNO_SLEEPING_MODE_ALWAYS_AWAKE power mode (see ZUNO_SETUP_SLEEPING_MODE).
