Change from PI3 with Razberry Modul to PI4 with UZB Stick
donquixote0906
Post by donquixote0906 »
Hello at all,
i want to change my PI3 with the Razberry Modul to a PI4 with a UZB Stick.
Is this still possible or are there technical limitations?
Is the way under Z-Wave Expert UI -> control -> start controller change the right way or
are there technical problems cause of the different hardware modules?
An other idea was to make a backup from the module (under Z-Wave Expert UI -> control ->)
and restore the data to the UZB Stick. Is it a valid solution?
Have anybody experience with such a process or are there other suggestions?
Thanks to all
Volker
Re: Change from PI3 with Razberry Modul to PI4 with UZB Stick
Better to do it thru backup & restore
BlakeBernadette
Post by BlakeBernadette »
Yep, only backup is the best way!!
