Increase UART Rx buffer
splitfile
Post by splitfile »
Hi!
I'm reading power meter data from my power meter (RJ12 P1 port). The meter sends data every 10 seconds.
I however think that I lose packets (dropped packets). Data is received at baud rate 115200. I have a feeling that Z-Uno are unable to keep up reading data from the Rx-buffer before it is overwritten..
Every burst of data is approximately 500-1000 bytes. Is there any way to increase the UART Rx buffer?
This is my code.
#define DEBUG       1 // 1=On, 0=Off
char incomingByte = 0;   // for incoming serial data
int numberOfByte = 0;   // count number of bytes received
char buffer[500];
void setup()
#ifdef DEBUG
  Serial.begin();
  Serial.println("Inside setup");
#endif
Serial1.begin(115200);
void loop()
  //delay(100); //sleep 1s
  while (Serial1.available() > 0)
    // read the incoming byte:
    incomingByte = (char)Serial1.read();
    buffer[numberOfByte] = incomingByte & 127;
    numberOfByte++;
  if (numberOfByte > 0)
    Serial.println("");
    Serial.print(numberOfByte, DEC);
    Serial.println(":RECEIVE:");
    for (int i=0; i<numberOfByte; i++)
      //Serial.print(buffer);
      Serial.print(buffer[i]);
    numberOfByte = 0; //reset
    //Serial1.flush();
Re: Increase UART Rx buffer
Z-Uno uses DMA for UAR, but the memory is pretty limited. There is no 1000 bytes of SRAM for that ;(
splitfile
Post by splitfile »
Thanks for answering!
Is it possible to increase the buffer a little bit?
Is my code looking ok? Do you see any areas of improvement?
I mean, shouldn't Z-uno be able to read fast enough from UART Rx without getting dropped packages? It is more likely that I am doing something wrong :-)
This is an example message that comes every 10 seconds:
/ELL5\253833635_A
0-0:1.0.0(201020085222W)
1-0:1.8.0(00001605.055*kWh)
1-0:2.8.0(00000000.131*kWh)
1-0:3.8.0(00000003.642*kvarh)
1-0:4.8.0(00000185.707*kvarh)
1-0:1.7.0(0006.000*kW)
1-0:2.7.0(0000.000*kW)
1-0:3.7.0(0000.200*kvar)
1-0:4.7.0(0000.470*kvar)
1-0:21.7.0(0003.172*kW)
1-0:41.7.0(0000.441*kW)
1-0:61.7.0(0002.386*kW)
1-0:22.7.0(0000.000*kW)
1-0:42.7.0(0000.000*kW)
1-0:62.7.0(0000.000*kW)
1-0:23.7.0(0000.000*kvar)
1-0:43.7.0(0000.200*kvar)
1-0:63.7.0(0000.000*kvar)
1-0:24.7.0(0000.222*kvar)
1-0:44.7.0(0000.000*kvar)
1-0:64.7.0(0000.247*kvar)
1-0:32.7.0(234.4*V)
1-0:52.7.0(233.3*V)
1-0:72.7.0(235.1*V)
1-0:31.7.0(013.6*A)
1-0:51.7.0(002.0*A)
1-0:71.7.0(010.2*A)
!80FF
Thanks!
MagistrDEV
Post by MagistrDEV »
you can use the following UART settings
Serial.begin(speed, RX_pin, TX_pin, *buffer, len) // to set your buffer
Note that the buffer must be larger than the received packet.
In addition, for guaranteed reception, packets of 1024 bytes should not arrive faster than 350ms.
your code will look like this:
char uart_buffer[1024]; // buffer for UART DMA
char buffer[1024];
void setup()
  #ifdef DEBUG
    Serial.begin();
  #endif
  Serial1.begin(115200, RX1, TX1, &uart_buffer, sizeof(uart_buffer));//set our buffer
  bzero(buffer,sizeof(buffer));
void loop()
   int ff = 0;
    buffer[numberOfByte] = ((char)Serial1.read() & 127);
    numberOfByte++;
  buffer[numberOfByte] = 0;
    Serial.println("");
    Serial.println(buffer);
