I have a primary z-way server using a razberry pi 5th generation card, running the latest version of z-way.
Last night I ran reorganization and when it had completed, I realized it had deleted from the network several devices which were functioning. One of the switches is associated to a switch that was not deleted and it can still toggle the other switch.
This is not the first time I have seen this behavior. The devices that end up being deleted this time were all mains powered. Some where older GE switches, and others were wave-plus. Not all of devices were switches. All three Stelpro thermostats were removed.
If I go into expert->network->control, and select start_inclusion? If I press a switch, it will be re-added to the network, with whatever Node ID is was previously had. Z-way though will have lost the name of device and any automations that used the devices are broken.
First: Reorganization should not silently delete devices. This breaks automations silently and does not provide an opportunity to replace a failed node. If z-way believes that a node needs to be deleted? It should add the node to the list that "Removed Failed Node" uses.
If I look at what the Reorganization output is under expert is for a device that was deleted?
00:10:11 Starting neighbours update 221
00:41:07 Neighbours update done 221
The information from the log file is confusing as well:
[2022-01-09 01:25:49.563] [D] [zway] SETDATA devices.211.data.neighbours = byte[22]
[2022-01-09 01:25:49.563] [D] [zway] ( 04 06 07 27 2A 32 49 4A 4C 4F 50 51 7F 82 84 87 A6 AE AF DD E4 E5 )
[2022-01-09 01:25:49.563] [zway] Job 0x80 (Get routing table line to node 211): List of neighbours for node 211: [ 04 06 07 27 2a 32 49 4a 4c 4f 50 51 7f 82 84 87 a6 ae af dd e4 e5 ]
[2022-01-09 01:25:49.564] [D] [zway] Job 0x80 (Get routing table line to node 211): success
[2022-01-09 01:25:49.564] [zway] Removing job: Get routing table line to node 211
[2022-01-09 01:25:49.565] [D] [zway] SENDING: ( 01 06 00 80 DD 00 00 A4 )
[2022-01-09 01:25:49.566] [D] [zway] RECEIVED ACK
[2022-01-09 01:25:49.571] [D] [zway] RECEIVED: ( 01 20 01 80 6C C1 89 04 C3 7A 3A FA 24 41 C9 83 39 01 21 44 5B 02 C1 00 00 00 00 00 00 C0 04 00 18 31 )
[2022-01-09 01:25:49.571] [D] [zway] SENT ACK
[2022-01-09 01:25:49.571] [D] [zway] SETDATA devices.221.data.neighbours = byte[64]
[2022-01-09 01:25:49.571] [D] [zway] ( 03 04 06 07 09 0F 10 11 14 18 1B 21 22 27 28 2A 2C 2D 2E 2F 32 34 35 36 3A 3C 3D 3E 3F 40 43 46 49 4F 51 54 57 58 59 5A 60 61 64 65 66 69 71 76 7B 7F 81 82 84 85 87 8A 91 97 98 CF D0 D3 E4 E5 )
[2022-01-09 01:25:49.571] [zway] Job 0x80 (Get routing table line to node 221): List of neighbours for node 221: [ 03 04 06 07 09 0f 10 11 14 18 1b 21 22 27 28 2a 2c 2d 2e 2f 32 34 35 36 3a 3c 3d 3e 3f 40 43 46 49 4f 51 54 57 58 59 5a 60 61 64 65 66 69 71 76 7b 7f 81 82 84 85 87 8a 91 97 98 cf d0 d3 e4 e5 ]
[2022-01-09 01:25:49.571] [D] [zway] Job 0x80 (Get routing table line to node 221): success
[2022-01-09 01:25:49.571] [zway] Removing job: Get routing table line to node 221
[2022-01-09 01:25:49.573] [D] [zway] SENDING: ( 01 06 00 80 E1 00 00 98 )
[2022-01-09 01:25:49.574] [D] [zway] RECEIVED ACK
[2022-01-09 01:25:49.579] [D] [zway] RECEIVED: ( 01 20 01 80 7C 81 09 00 82 50 4A F8 34 42 C9 83 39 01 21 44 5B 02 C1 00 00 00 00 00 00 00 00 00 18 2B )
[2022-01-09 01:25:49.579] [D] [zway] SENT ACK
[2022-01-09 01:25:51.917] [zway] Node 221 was removed
[2022-01-09 01:25:51.926] [core] Deleting device switchBinary ZWayVDev_zway_221-0-37
Reorganization is deleting working devices
Re: Reorganization is deleting working devices
Please show the few lines before
It is known that in some cases 5th gen SiLabs (Sigma Designs) SDK freaked out and reported nodes deletion to the upper (Z-Way) level. This should be solved by firmware upgrade via Z-Way. This is not normal of course, it is a bug.
seattleneil
This doesn't solve the problem, but it's a quick and easy way to help recover from "surprises".
Add a daily cron job that takes creates a tar file of Z-Way's config data:
59 23 * * * /bin/tar cf /opt/z-way-server_`/bin/date +%a`.tar /opt/z-way-server/config/zddx /opt/z-way-server/automation/storage
The cron job should provide a 7-day rolling backup. If the backups are written to a removable USB drive, then recovering from an SD card failure can be relatively straightforward.
Are you saying the RaZberry-500 should be upgraded, or are you saying that the devices which Z-way deleted should have their firmware upgraded?PoltoS wrote: ↑10 Jan 2022 02:26Please show the few lines before
The Razberry is running 5.39 ( SDK 6.82.01 ) and Z-way v3.2.2.
I can't look at the logs because they have already rolled over. I have seen this happen before, so I am sure it will happen again.
If it will, please provide logs
