Problem with configuration? - all devices are failed
jarek
Post by jarek »
For no reason Controller thinks that all devices are failed - the last ok status is equal to the start of service. I tried to restart the system but it does not help :(
I cannot control any device. How to fix it?
In expert inteface there is a lot of failed jobs with message:
Could not be delivered to Z-Wave stack
Version info:
http://192.168.0.111:8083/expert/#/network/controller :
Role in Network
Node Id:	1
Home Id:	0xf8a5481c
Primary Role:	Yes
Primary Capability:	Yes
SUC/SIS in network:	1 (SIS)
Hardware
Vendor:	RaZberry by Z-Wave.Me
Vendors Product ID:	1024 / 2
Z-Wave Chip:	ZW0500
Firmware
Library Type:	Static Controller
SDK Version:	6.51.06
Serial API Version:	05.04
Capabillities:
UUID:	00000000000000000000000000000000
Subvendor:	0x0000
Nodes limit:	00
Controller Static API
Allow max RF power
Backup/Restore
Battery save on sleeping
Advanced network diagnostics
Z-Wave Long Range
Fast communications
Change vendor ID
Promiscuous mode (Zniffer)
Full Zniffer
RF jamming detection
Capabillities:	slm
Software Information
Version number:	v3.2.2
Compile-ID:	101045968be0f00797fdc4d1a70e2955271fe4e7
Compile-Date:	2021-11-29 15:40:21 +0300
UI
UI version	v1.5.7
Built date	26-11-2021 01:37:55
micky1500
Re: Problem with configuration? - all devices are failed
Post by micky1500 »
Have you taken backups ?
Take some now !
Both types. Backup & Restore and Expert UI Backup.
Do a power cycle. not just a restart !
Good Luck.
seattleneil
Post by seattleneil »
Adding on to the suggestions by @micky1500...
If shutting down and then power-cycling your Pi doesn't fix the problem, the contents of the z-way-server log file (by default, file /var/log/z-way-server.log) should show the cause of the problem.
When I encountered a similar issue, it was caused by a process trying to use the same serial port (/dev/ttyAMA0) that the controller card uses. The following command will show if there are any processes conflicting with Z-Way's use of the serial port: sudo lsof -n | grep AMA0
If the command returns a process that's not a z-way-server process, you have a configuration error on your Pi (most likely in /boot/cmdline.txt or /boot/config.txt due to a conflict related to the console or bluetooth).
Another possibility is a corrupt Z-Way configuration. Hopefully, you've downloaded backups (files ending in .zbk and .zab).
