contact Z-Wave.Me support in error log x 100
micky1500
Post by micky1500 »
Hi Sergey.
Sorry in advance.
Months ago it was said that my issues were fixed !
Maybe with 4.0.0 ?
Months later I'm still struggling.
Is Beta version 4.0.0-154-gb997afc2 a stable version ?
Tonight. Randomly lights are turning on. Same happens on a weekly basis.
A Send-all command gets sent.. I have removed every device from the Send-all group.
Maybe my devices are old, they worked before, I expect them to work now, I don't expect to have to update every 3 years.
There are some Logs following. (you do like log files)
It says I need to contact you. Unhandledd Command. Contact Z-Wave.Me support hundreds of times.
Today it's device 104, other devices have issues previously !
[2022-10-29 00:30:00.611] [zway] Waiting for job reply: SwitchBinary Get from node 110
[2022-10-29 00:30:00.727] [D] [zway] RECEIVED: ( 01 0C 00 04 00 6E 03 25 03 00 B2 00 00 0E )
[2022-10-29 00:30:00.727] [D] [zway] SENT ACK
[2022-10-29 00:30:00.727] [D] [zway] SETDATA devices.110.data.lastReceived = 0 (0x00000000)
[2022-10-29 00:30:00.728] [D] [zway] Received reply on job (SwitchBinary Get to node 110)
[2022-10-29 00:30:00.728] [D] [zway] SETDATA devices.110.instances.0.commandClasses.37.data.level = False
[2022-10-29 00:30:00.809] [D] [zway] RECEIVED: ( 01 10 00 04 00 27 07 60 0D 02 02 20 03 00 C1 00 00 44 )
[2022-10-29 00:30:00.809] [D] [zway] SENT ACK
[2022-10-29 00:30:00.809] [D] [zway] SETDATA devices.39.data.lastReceived = 0 (0x00000000)
[2022-10-29 00:30:00.809] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
[2022-10-29 00:30:00.809] [W] [zway] Got unsecure packet from device 39, but Command Class 0x20 Basic is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-10-29 00:30:00.809] [E] [zway] Error returned from (returnStatus = _zway_cc_call_handler(zway, cmd, node_id, data[3], length - 4, &data[4])): Function class not supported by the hardware (-4)
[2022-10-29 00:30:00.836] [D] [zway] RECEIVED: ( 01 10 00 04 00 27 07 60 0D 02 02 20 03 00 C0 00 00 45 )
[2022-10-29 00:30:00.837] [D] [zway] SENT ACK
[2022-10-29 00:30:00.837] [W] [zway] Discarding duplicate packet from node 39
[2022-10-29 00:30:02.044] [D] [zway] RECEIVED: ( 01 17 00 04 00 6E 0E 32 02 21 34 00 00 00 00 00 00 00 00 00 00 B1 00 00 18 )
[2022-10-29 00:30:02.044] [D] [zway] SENT ACK
[2022-10-29 00:30:02.044] [D] [zway] SETDATA devices.110.data.lastReceived = 0 (0x00000000)
[2022-10-29 00:30:02.044] [D] [zway] SETDATA devices.110.instances.0.commandClasses.50.data.2.val = 0.000000
[2022-10-29 00:30:02.044] [D] [zway] SETDATA devices.110.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2022-10-29 00:30:02.044] [D] [zway] SETDATA devices.110.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2022-10-29 00:30:02.044] [D] [zway] SETDATA devices.110.instances.0.commandClasses.50.data.2 = Empty
[2022-10-29 00:30:02.204] [D] [zway] RECEIVED: ( 01 0C 00 04 00 6E 03 25 03 00 B1 00 00 0D )
[2022-10-29 00:30:02.204] [D] [zway] SENT ACK
[2022-10-29 00:30:02.204] [D] [zway] SETDATA devices.110.data.lastReceived = 0 (0x00000000)
[2022-10-29 00:30:02.204] [D] [zway] SETDATA devices.110.instances.0.commandClasses.37.data.level = False
[2022-10-29 00:30:02.581] [D] [zway] Job 0x13: deleted from queue
[2022-10-29 00:30:02.733] [D] [zway] Job 0x13: deleted from queue
[2022-10-29 00:30:02.962] [D] [zway] RECEIVED: ( 01 1B 00 04 00 7C 12 60 0D 01 00 32 02 21 74 00 05 04 9E 00 00 00 00 00 00 A5 00 00 BD )
[2022-10-29 00:30:02.962] [D] [zway] SENT ACK
[2022-10-29 00:30:02.963] [D] [zway] SETDATA devices.124.data.lastReceived = 0 (0x00000000)
[2022-10-29 00:30:02.963] [D] [zway] SETDATA devices.124.instances.1.commandClasses.50.data.2.val = 328.862000
[2022-10-29 00:30:02.963] [D] [zway] SETDATA devices.124.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2022-10-29 00:30:02.963] [D] [zway] SETDATA devices.124.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2022-10-29 00:30:02.963] [D] [zway] SETDATA devices.124.instances.1.commandClasses.50.data.2 = Empty
[2022-10-29 00:30:03.040] [core] [BaseModule-9] Set lastLevel to 328.8620032 for ZWayVDev_zway_124-1-50-2 (was 352.1619968)
[2022-10-29 00:30:09.940] [D] [zway] Job 0x3b: deleted from queue
[2022-10-29 00:30:19.632] [zway] Adding job: Get background noise level
[2022-10-29 00:30:19.637] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-10-29 00:30:19.639] [D] [zway] RECEIVED ACK
[2022-10-29 00:30:19.640] [D] [zway] RECEIVED: ( 01 07 01 3B 9A 97 97 7F 27 )
[2022-10-29 00:30:19.640] [D] [zway] SENT ACK
[2022-10-29 00:30:19.640] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 154 (0x0000009a)
[2022-10-29 00:30:19.640] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 151 (0x00000097)
[2022-10-29 00:30:19.640] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 151 (0x00000097)
[2022-10-29 00:30:19.640] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -102 dBm, Ch#2: -105 dBm, Ch#3: -105 dBm
[2022-10-29 00:30:19.640] [D] [zway] Job 0x3b (Get background noise level): success
[2022-10-29 00:30:19.640] [zway] Removing job: Get background noise level
[2022-10-29 00:30:20.588] [D] [zway] Job 0x13: deleted from queue
[2022-10-29 00:30:20.720] [D] [zway] Job 0x13: deleted from queue
[2022-10-29 00:30:39.941] [D] [zway] Job 0x3b: deleted from queue
[2022-10-29 00:30:48.490] [D] [zway] RECEIVED: ( 01 0C 00 04 00 85 03 30 03 00 B9 00 00 FB )
[2022-10-29 00:30:48.490] [D] [zway] SENT ACK
[2022-10-29 00:30:48.491] [D] [zway] SETDATA devices.133.data.lastReceived = 0 (0x00000000)
[2022-10-29 00:30:48.491] [D] [zway] SETDATA devices.133.instances.0.commandClasses.48.data.1.level = False
[2022-10-29 00:30:48.491] [D] [zway] SETDATA devices.133.instances.0.commandClasses.48.data.1 = Empty
[2022-10-29 00:30:48.512] [core] Notification: device-info (device-OnOff): {"dev":"PIR Lounge","l":"off","location":10}
[2022-10-29 00:30:48.573] [core] [BaseModule-9] Set lastLevel to off for ZWayVDev_zway_133-0-48-1 (was on)
[2022-10-29 00:30:49.625] [zway] Adding job: Get background noise level
[2022-10-29 00:30:49.627] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-10-29 00:30:49.629] [D] [zway] RECEIVED ACK
[2022-10-29 00:30:49.630] [D] [zway] RECEIVED: ( 01 07 01 3B 9A 97 97 7F 27 )
[2022-10-29 00:30:49.630] [D] [zway] SENT ACK
Line 343548: [2022-10-30 16:05:10.426] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 01
Line 343583: [2022-10-30 16:05:39.605] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 343637: [2022-10-30 16:05:54.458] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 343759: [2022-10-30 16:06:21.749] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 01
Line 343878: [2022-10-30 16:06:45.066] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 343887: [2022-10-30 16:06:48.269] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 343899: [2022-10-30 16:06:56.799] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 344170: [2022-10-30 16:09:20.065] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 344230: [2022-10-30 16:09:38.574] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8b 01
Line 344269: [2022-10-30 16:09:41.875] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8b 01
Line 344288: [2022-10-30 16:09:42.308] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8b 01
Line 344371: [2022-10-30 16:10:23.076] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 01
Line 344392: [2022-10-30 16:10:32.032] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 01
Line 344714: [2022-10-30 16:11:46.111] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 aa
Line 344726: [2022-10-30 16:11:56.405] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 aa
Line 344947: [2022-10-30 16:12:37.078] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 75 01
Line 344982: [2022-10-30 16:12:40.300] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 75 01
Line 345020: [2022-10-30 16:12:55.330] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 345490: [2022-10-30 16:15:15.079] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 345499: [2022-10-30 16:15:18.195] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 346015: [2022-10-30 16:17:20.015] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 01
Line 346038: [2022-10-30 16:17:24.126] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 01
Line 346073: [2022-10-30 16:17:24.952] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 01
Line 346087: [2022-10-30 16:17:25.025] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 01
Line 346813: [2022-10-30 16:21:21.922] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 09
Line 346901: [2022-10-30 16:22:28.097] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 01
Line 346927: [2022-10-30 16:22:43.631] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 01
Line 347277: [2022-10-30 16:24:02.913] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 349473: [2022-10-30 16:35:41.912] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 4c 01
Line 349482: [2022-10-30 16:35:44.526] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 4c 01
Line 349815: [2022-10-30 16:37:16.194] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 63 01
Line 349879: [2022-10-30 16:37:27.641] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 63 01
Line 350511: [2022-10-30 16:42:51.524] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 351108: [2022-10-30 16:46:23.337] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 85 01
Line 351184: [2022-10-30 16:47:04.212] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c 01
Line 351402: [2022-10-30 16:49:22.256] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 01
Line 352592: [2022-10-30 16:56:01.037] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 352605: [2022-10-30 16:56:01.770] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 352630: [2022-10-30 16:56:06.566] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 352724: [2022-10-30 16:56:33.380] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8b 01
Line 352774: [2022-10-30 16:57:18.697] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 352783: [2022-10-30 16:57:22.233] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 352861: [2022-10-30 16:57:54.951] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 353523: [2022-10-30 17:03:47.386] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 09
Line 353569: [2022-10-30 17:04:03.568] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 09
Line 353625: [2022-10-30 17:04:13.251] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 01
Line 354107: [2022-10-30 17:06:45.765] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e a7
Line 354259: [2022-10-30 17:08:26.019] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 01
Line 355331: [2022-10-30 17:14:55.377] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 73 01
Line 355344: [2022-10-30 17:15:04.682] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 73 01
Line 357105: [2022-10-30 17:22:39.302] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 357114: [2022-10-30 17:22:42.330] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 357943: [2022-10-30 17:26:30.475] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c 01
Line 358008: [2022-10-30 17:26:47.170] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8b 01
Line 359201: [2022-10-30 17:32:11.322] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 09
Line 359295: [2022-10-30 17:33:07.320] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 359307: [2022-10-30 17:33:18.084] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 359679: [2022-10-30 17:36:25.324] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 73 01
Line 359700: [2022-10-30 17:36:27.607] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 73 01
Line 359706: [2022-10-30 17:36:35.486] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 73 01
Line 359723: [2022-10-30 17:36:39.405] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 73 01
Line 361303: [2022-10-30 17:46:14.540] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 361324: [2022-10-30 17:46:15.060] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 361334: [2022-10-30 17:46:19.522] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 361344: [2022-10-30 17:46:20.737] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 361512: [2022-10-30 17:47:59.312] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 70 01
Line 361535: [2022-10-30 17:48:09.187] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 70 01
Line 361883: [2022-10-30 17:49:34.302] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 361980: [2022-10-30 17:49:40.318] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 362360: [2022-10-30 17:52:24.310] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 44 01
Line 362373: [2022-10-30 17:52:34.190] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 44 01
Line 362464: [2022-10-30 17:53:42.312] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 362651: [2022-10-30 17:54:10.312] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c 01
Line 362729: [2022-10-30 17:54:28.311] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c 01
Line 362923: [2022-10-30 17:55:19.734] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c 01
Line 363598: [2022-10-30 18:00:58.728] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 09
Line 363709: [2022-10-30 18:02:25.453] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 01
Line 363755: [2022-10-30 18:02:41.430] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 01
Line 364199: [2022-10-30 18:05:09.451] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 364205: [2022-10-30 18:05:14.924] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 364483: [2022-10-30 18:06:41.531] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 364742: [2022-10-30 18:08:44.391] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 364923: [2022-10-30 18:09:13.615] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 365087: [2022-10-30 18:09:58.990] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 20 03
Line 366575: [2022-10-30 18:19:16.033] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c 01
Line 366587: [2022-10-30 18:19:25.060] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c 01
Line 366627: [2022-10-30 18:19:32.180] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 366708: [2022-10-30 18:19:42.214] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 367728: [2022-10-30 18:27:56.413] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 367797: [2022-10-30 18:28:29.858] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 367803: [2022-10-30 18:28:32.211] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 367859: [2022-10-30 18:28:43.981] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 368038: [2022-10-30 18:29:52.364] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c 01
Line 368279: [2022-10-30 18:32:54.376] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 368288: [2022-10-30 18:32:57.185] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 368383: [2022-10-30 18:33:13.707] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8b 01
Line 368392: [2022-10-30 18:33:17.834] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8b 01
Line 368562: [2022-10-30 18:34:02.381] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 33 01
Line 368571: [2022-10-30 18:34:05.188] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 33 01
Line 370006: [2022-10-30 18:43:44.417] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e 01
Line 370139: [2022-10-30 18:44:20.510] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 370145: [2022-10-30 18:44:22.685] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 370539: [2022-10-30 18:48:05.430] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 370548: [2022-10-30 18:48:05.511] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 370571: [2022-10-30 18:48:07.916] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 370615: [2022-10-30 18:48:15.903] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 370631: [2022-10-30 18:48:20.261] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 370707: [2022-10-30 18:48:54.351] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 370736: [2022-10-30 18:49:00.275] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 370749: [2022-10-30 18:49:00.367] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 370764: [2022-10-30 18:49:00.922] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 370776: [2022-10-30 18:49:01.295] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 372755: [2022-10-30 19:01:01.468] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 66 01
Line 372775: [2022-10-30 19:01:04.018] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 66 01
Line 372947: [2022-10-30 19:02:18.581] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8a 01
Line 373969: [2022-10-30 19:09:26.505] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c ca
Line 373981: [2022-10-30 19:09:35.216] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c ca
Line 374000: [2022-10-30 19:09:39.810] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c ca
Line 375512: [2022-10-30 19:24:27.504] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e a9
Line 375542: [2022-10-30 19:24:37.690] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 8e a9
Line 375598: [2022-10-30 19:25:11.704] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e e5
Line 377075: [2022-10-30 19:40:05.515] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 a9
Line 377097: [2022-10-30 19:40:07.191] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 a9
Line 379485: [2022-10-30 19:57:02.515] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 94 a9
Line 379507: [2022-10-30 19:57:16.894] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 94 a9
Line 379910: [2022-10-30 20:00:00.262] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e a9
Line 380042: [2022-10-30 20:00:12.202] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e a9
Line 381604: [2022-10-30 20:05:11.095] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 31 01
Line 381613: [2022-10-30 20:05:20.897] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 31 01
Line 381621: [2022-10-30 20:05:25.571] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 31 01
Line 382480: [2022-10-30 20:08:58.785] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 3d 01
Line 382573: [2022-10-30 20:10:03.560] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 388746: [2022-10-30 20:43:03.347] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 85 01
Line 391141: [2022-10-30 20:54:57.305] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 62 01
Line 391646: [2022-10-30 20:59:05.818] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 391655: [2022-10-30 20:59:08.331] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 394278: [2022-10-30 21:15:12.918] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 394294: [2022-10-30 21:15:14.586] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 394343: [2022-10-30 21:15:26.625] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 63 01
Line 394546: [2022-10-30 21:16:15.868] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 3d 01
Line 394555: [2022-10-30 21:16:18.072] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 3d 01
Line 394563: [2022-10-30 21:16:25.410] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 3d 01
Line 396423: [2022-10-30 21:26:59.662] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2c 01
Line 396434: [2022-10-30 21:26:59.758] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2c 01
Line 396445: [2022-10-30 21:26:59.812] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2c 01
Line 396456: [2022-10-30 21:27:00.098] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2c 01
Line 396467: [2022-10-30 21:27:00.422] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2c 01
Line 396506: [2022-10-30 21:27:16.309] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 32 01
Line 397145: [2022-10-30 21:31:14.469] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 27 01
Line 397405: [2022-10-30 21:32:17.952] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 397414: [2022-10-30 21:32:20.471] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 397421: [2022-10-30 21:32:32.090] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 398185: [2022-10-30 21:37:21.963] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 44 01
Line 398333: [2022-10-30 21:38:03.578] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2d 01
Line 399380: [2022-10-30 21:45:22.353] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9c 01
Line 399728: [2022-10-30 21:48:16.000] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 09
Line 399739: [2022-10-30 21:48:24.670] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 09
Line 399769: [2022-10-30 21:48:30.570] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 84 09
Line 400494: [2022-10-30 21:53:08.595] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 400520: [2022-10-30 21:53:11.557] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 400563: [2022-10-30 21:54:03.028] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 77 01
Line 400654: [2022-10-30 21:54:19.855] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 77 01
Line 400770: [2022-10-30 21:54:57.291] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 30 01
Line 400780: [2022-10-30 21:55:02.002] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 30 01
Line 401586: [2022-10-30 21:59:20.885] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 59 01
Line 401613: [2022-10-30 21:59:27.723] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 59 01
Line 401718: [2022-10-30 21:59:35.348] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 42 01
Line 401805: [2022-10-30 21:59:44.020] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2d 01
Line 402192: [2022-10-30 22:01:11.089] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 4e 01
Line 402205: [2022-10-30 22:01:25.471] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 3d 01
Line 402229: [2022-10-30 22:01:29.089] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 79 01
Line 402858: [2022-10-30 22:05:34.178] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 44 01
Line 402864: [2022-10-30 22:05:37.518] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 44 01
Line 402877: [2022-10-30 22:05:38.179] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 44 01
Line 402890: [2022-10-30 22:05:38.327] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 44 01
Line 403054: [2022-10-30 22:06:42.117] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 403106: [2022-10-30 22:07:16.834] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 86 01
Line 403155: [2022-10-30 22:08:04.929] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 403178: [2022-10-30 22:08:09.335] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 403213: [2022-10-30 22:08:10.914] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 403224: [2022-10-30 22:08:11.277] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 403496: [2022-10-30 22:10:25.147] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2c 01
Line 403511: [2022-10-30 22:10:28.210] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2c 01
Line 403519: [2022-10-30 22:10:34.721] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 2c 01
Line 403551: [2022-10-30 22:10:41.452] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 46 01
Line 403563: [2022-10-30 22:10:50.530] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 46 01
Line 403590: [2022-10-30 22:10:56.567] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 4c 01
Line 403613: [2022-10-30 22:10:59.974] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 4c 01
Line 403818: [2022-10-30 22:11:39.942] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 75 01
Line 403887: [2022-10-30 22:12:15.889] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 403937: [2022-10-30 22:12:56.160] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 33 01
Line 404006: [2022-10-30 22:13:12.460] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 66 01
Line 404015: [2022-10-30 22:13:16.397] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 66 01
Line 404209: [2022-10-30 22:14:31.414] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 30 01
Line 404226: [2022-10-30 22:14:41.990] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 30 01
Line 404273: [2022-10-30 22:15:38.375] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 31 01
Line 405254: [2022-10-30 22:17:19.528] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 63 01
Line 405260: [2022-10-30 22:17:25.187] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 73 01
Line 405510: [2022-10-30 22:18:55.967] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 405517: [2022-10-30 22:18:59.196] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 66 01
Line 405608: [2022-10-30 22:19:42.928] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 405634: [2022-10-30 22:19:43.467] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 405651: [2022-10-30 22:19:43.876] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 405906: [2022-10-30 22:20:25.817] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 46 01
Line 405936: [2022-10-30 22:20:28.846] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 46 01
Line 406021: [2022-10-30 22:20:54.203] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 66 01
Line 406030: [2022-10-30 22:20:57.833] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 66 01
Line 406037: [2022-10-30 22:21:05.752] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 66 01
Line 406056: [2022-10-30 22:21:12.168] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 59 09
Line 406215: [2022-10-30 22:21:53.214] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 26 09
Line 406315: [2022-10-30 22:22:28.219] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 77 01
Line 407642: [2022-10-30 22:29:38.262] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 62 01
Line 407677: [2022-10-30 22:29:40.718] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 62 01
Line 407683: [2022-10-30 22:29:48.716] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 62 01
Line 407719: [2022-10-30 22:30:20.262] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 44 01
Line 407932: [2022-10-30 22:32:25.122] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 62 01
Line 408325: [2022-10-30 22:34:26.268] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 409687: [2022-10-30 22:43:40.308] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 409705: [2022-10-30 22:43:42.693] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 409721: [2022-10-30 22:43:42.771] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 409814: [2022-10-30 22:44:28.315] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 409830: [2022-10-30 22:44:37.201] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 409963: [2022-10-30 22:45:38.573] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 409980: [2022-10-30 22:45:42.384] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 71 01
Line 410196: [2022-10-30 22:47:35.774] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 62 01
Line 410389: [2022-10-30 22:49:02.331] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 01
Line 413882: [2022-10-30 22:54:18.895] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 88 01
Line 413986: [2022-10-30 22:55:06.378] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 30 01
Line 414072: [2022-10-30 22:55:12.147] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 30 01
Line 414796: [2022-10-30 22:56:04.400] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 40 01
Line 415791: [2022-10-30 22:58:29.334] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 4c 01
Line 416306: [2022-10-30 23:00:56.464] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 416333: [2022-10-30 23:00:57.971] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 9e 01
Line 416835: [2022-10-30 23:03:04.392] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 85 01
Line 416844: [2022-10-30 23:03:07.051] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 85 01
Line 416886: [2022-10-30 23:03:24.400] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 59 01
Line 417039: [2022-10-30 23:05:01.386] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 417056: [2022-10-30 23:05:07.108] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 417072: [2022-10-30 23:05:07.594] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
Line 417433: [2022-10-30 23:05:21.005] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 87 01
[2022-10-30 22:52:30.841] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:30.845] [D] [zway] RECEIVED: ( 01 1D 00 13 16 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E5 )
[2022-10-30 22:52:30.845] [D] [zway] SENT ACK
[2022-10-30 22:52:30.845] [zway] Job 0x13 (SwitchAll Set to node 104): Not delivered to recipient
[2022-10-30 22:52:30.847] [D] [zway] SENDING (cb 0x17): ( 01 0A 00 13 68 03 27 01 00 25 17 99 )
[2022-10-30 22:52:30.850] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:30.851] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:30.852] [D] [zway] SENT ACK
[2022-10-30 22:52:30.852] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:30.855] [D] [zway] RECEIVED: ( 01 1D 00 13 17 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E4 )
[2022-10-30 22:52:30.856] [D] [zway] SENT ACK
[2022-10-30 22:52:30.856] [I] [zway] Job 0x13 (SwitchAll Set to node 104): Not delivered to recipient
[2022-10-30 22:52:30.858] [I] [zway] Job 0x13 (SwitchAll Set to node 104): Removing job due to too much retransmitions
[2022-10-30 22:52:30.858] [I] [zway] Adding job: Check if node is failed to node 104
[2022-10-30 22:52:30.859] [D] [zway] Job 0x13 (SwitchAll Set to node 104): fail
[2022-10-30 22:52:30.859] [I] [zway] Removing job: SwitchAll Set to node 104
[2022-10-30 22:52:30.860] [D] [zway] SENDING: ( 01 04 00 62 68 F1 )
[2022-10-30 22:52:30.862] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:30.863] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2022-10-30 22:52:30.863] [D] [zway] SENT ACK
[2022-10-30 22:52:30.863] [D] [zway] SETDATA devices.104.data.isFailed = False
[2022-10-30 22:52:30.864] [I] [zway] Job 0x62 (Check if node is failed to node 104): Node 104 is operating
[2022-10-30 22:52:30.864] [D] [zway] Job 0x62 (Check if node is failed to node 104): success
[2022-10-30 22:52:30.865] [D] [zway] SETDATA devices.104.data.failureCount = 0 (0x00000000)
[2022-10-30 22:52:30.865] [D] [zway] SETDATA devices.104.data.lastSendInternal = **********
[2022-10-30 22:52:30.865] [I] [zway] Removing job: Check if node is failed to node 104
[2022-10-30 22:52:30.869] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0 = Empty
[2022-10-30 22:52:30.869] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0.sensorType = Empty
[2022-10-30 22:52:30.870] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0.sensorTypeString = Empty
[2022-10-30 22:52:30.870] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0.val = Empty
[2022-10-30 22:52:30.871] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0.scale = Empty
[2022-10-30 22:52:30.871] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0.scaleString = Empty
[2022-10-30 22:52:30.871] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0.ratetype = Empty
[2022-10-30 22:52:30.872] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0.delta = Empty
[2022-10-30 22:52:30.872] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0.previous = Empty
[2022-10-30 22:52:30.872] [D] [zway] SETDATA devices.104.instances.0.commandClasses.50.data.0.scale = 0 (0x00000000)
[2022-10-30 22:52:30.873] [I] [zway] Adding job: Meter Get (v1) to node 104
[2022-10-30 22:52:30.907] [D] [zway] SENDING (cb 0x18): ( 01 09 00 13 68 02 27 02 25 18 97 )
[2022-10-30 22:52:30.909] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:30.910] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:30.911] [D] [zway] SENT ACK
[2022-10-30 22:52:30.911] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:30.914] [D] [zway] RECEIVED: ( 01 1D 00 13 18 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EB )
[2022-10-30 22:52:30.915] [D] [zway] SENT ACK
[2022-10-30 22:52:30.915] [I] [zway] Job 0x13 (SwitchAll Get to node 104): Not delivered to recipient
[2022-10-30 22:52:30.917] [D] [zway] SENDING (cb 0x19): ( 01 09 00 13 68 02 27 02 25 19 96 )
[2022-10-30 22:52:30.919] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:30.920] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:30.920] [D] [zway] SENT ACK
[2022-10-30 22:52:30.920] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:30.924] [D] [zway] RECEIVED: ( 01 1D 00 13 19 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EA )
[2022-10-30 22:52:30.924] [D] [zway] SENT ACK
[2022-10-30 22:52:30.925] [I] [zway] Job 0x13 (SwitchAll Get to node 104): Not delivered to recipient
[2022-10-30 22:52:30.926] [D] [zway] SENDING (cb 0x1a): ( 01 09 00 13 68 02 27 02 25 1A 95 )
[2022-10-30 22:52:30.929] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:30.929] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:30.930] [D] [zway] SENT ACK
[2022-10-30 22:52:30.930] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:30.934] [D] [zway] RECEIVED: ( 01 1D 00 13 1A 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E9 )
[2022-10-30 22:52:30.934] [D] [zway] SENT ACK
[2022-10-30 22:52:30.934] [I] [zway] Job 0x13 (SwitchAll Get to node 104): Not delivered to recipient
[2022-10-30 22:52:30.935] [I] [zway] Job 0x13 (SwitchAll Get to node 104): Removing job due to too much retransmitions
[2022-10-30 22:52:30.936] [I] [zway] Adding job: Check if node is failed to node 104
[2022-10-30 22:52:30.936] [D] [zway] Job 0x13 (SwitchAll Get to node 104): fail
[2022-10-30 22:52:30.936] [I] [zway] Removing job: SwitchAll Get to node 104
[2022-10-30 22:52:30.937] [D] [zway] SENDING: ( 01 04 00 62 68 F1 )
[2022-10-30 22:52:30.939] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:30.940] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2022-10-30 22:52:30.940] [D] [zway] SENT ACK
[2022-10-30 22:52:30.940] [D] [zway] SETDATA devices.104.data.isFailed = False
[2022-10-30 22:52:30.940] [I] [zway] Job 0x62 (Check if node is failed to node 104): Node 104 is operating
[2022-10-30 22:52:30.941] [D] [zway] Job 0x62 (Check if node is failed to node 104): success
[2022-10-30 22:52:30.941] [D] [zway] SETDATA devices.104.data.failureCount = 0 (0x00000000)
[2022-10-30 22:52:30.941] [D] [zway] SETDATA devices.104.data.lastSendInternal = **********
[2022-10-30 22:52:30.942] [I] [zway] Removing job: Check if node is failed to node 104
[2022-10-30 22:52:30.983] [D] [zway] SENDING (cb 0x1b): ( 01 09 00 13 68 02 32 01 25 1B 82 )
[2022-10-30 22:52:30.985] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:30.986] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:30.987] [D] [zway] SENT ACK
[2022-10-30 22:52:30.987] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:30.990] [D] [zway] RECEIVED: ( 01 1D 00 13 1B 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E8 )
[2022-10-30 22:52:30.991] [D] [zway] SENT ACK
[2022-10-30 22:52:30.991] [I] [zway] Job 0x13 (Meter Get (v1) to node 104): Not delivered to recipient
[2022-10-30 22:52:30.993] [D] [zway] SENDING (cb 0x1c): ( 01 09 00 13 68 02 32 01 25 1C 85 )
[2022-10-30 22:52:30.996] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:30.997] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:30.997] [D] [zway] SENT ACK
[2022-10-30 22:52:30.998] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:31.001] [D] [zway] RECEIVED: ( 01 1D 00 13 1C 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EF )
[2022-10-30 22:52:31.001] [D] [zway] SENT ACK
[2022-10-30 22:52:31.002] [I] [zway] Job 0x13 (Meter Get (v1) to node 104): Not delivered to recipient
[2022-10-30 22:52:31.004] [D] [zway] SENDING (cb 0x1d): ( 01 09 00 13 68 02 32 01 25 1D 84 )
[2022-10-30 22:52:31.006] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:31.007] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:31.007] [D] [zway] SENT ACK
[2022-10-30 22:52:31.007] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:31.011] [D] [zway] RECEIVED: ( 01 1D 00 13 1D 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EE )
[2022-10-30 22:52:31.011] [D] [zway] SENT ACK
[2022-10-30 22:52:31.012] [I] [zway] Job 0x13 (Meter Get (v1) to node 104): Not delivered to recipient
[2022-10-30 22:52:31.013] [I] [zway] Job 0x13 (Meter Get (v1) to node 104): Removing job due to too much retransmitions
[2022-10-30 22:52:31.014] [I] [zway] Adding job: Check if node is failed to node 104
[2022-10-30 22:52:31.014] [D] [zway] Job 0x13 (Meter Get (v1) to node 104): fail
[2022-10-30 22:52:31.015] [I] [zway] Removing job: Meter Get (v1) to node 104
[2022-10-30 22:52:31.015] [D] [zway] SENDING: ( 01 04 00 62 68 F1 )
[2022-10-30 22:52:31.018] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:31.018] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2022-10-30 22:52:31.019] [D] [zway] SENT ACK
[2022-10-30 22:52:31.019] [D] [zway] SETDATA devices.104.data.isFailed = False
[2022-10-30 22:52:31.019] [I] [zway] Job 0x62 (Check if node is failed to node 104): Node 104 is operating
[2022-10-30 22:52:31.020] [D] [zway] Job 0x62 (Check if node is failed to node 104): success
[2022-10-30 22:52:31.020] [D] [zway] SETDATA devices.104.data.failureCount = 0 (0x00000000)
[2022-10-30 22:52:31.021] [D] [zway] SETDATA devices.104.data.lastSendInternal = **********
[2022-10-30 22:52:31.021] [I] [zway] Removing job: Check if node is failed to node 104
[2022-10-30 22:52:31.472] [D] [zway] SETDATA devices.104.instances.0.commandClasses.112.data.preferBulk = False
[2022-10-30 22:52:31.473] [D] [zway] SETDATA devices.104.instances.0.commandClasses.112.data.noBulkSupport = True
[2022-10-30 22:52:31.473] [D] [zway] SETDATA devices.104.instances.0.commandClasses.112.data.interviewDone = True
[2022-10-30 22:52:31.474] [I] [zway] Node 104:0 CC Configuration Interview done
[2022-10-30 22:52:31.918] [I] [zway] Adding job: ManufacturerSpecific Get to node 104
[2022-10-30 22:52:31.920] [D] [zway] SENDING (cb 0x1e): ( 01 09 00 13 68 02 72 04 25 1E C2 )
[2022-10-30 22:52:31.922] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:31.923] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:31.923] [D] [zway] SENT ACK
[2022-10-30 22:52:31.923] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:31.927] [D] [zway] RECEIVED: ( 01 1D 00 13 1E 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ED )
[2022-10-30 22:52:31.927] [D] [zway] SENT ACK
[2022-10-30 22:52:31.927] [I] [zway] Job 0x13 (ManufacturerSpecific Get to node 104): Not delivered to recipient
[2022-10-30 22:52:31.928] [D] [zway] SENDING (cb 0x1f): ( 01 09 00 13 68 02 72 04 25 1F C3 )
[2022-10-30 22:52:31.930] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:31.932] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:31.932] [D] [zway] SENT ACK
[2022-10-30 22:52:31.933] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:31.936] [D] [zway] RECEIVED: ( 01 1D 00 13 1F 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EC )
[2022-10-30 22:52:31.936] [D] [zway] SENT ACK
[2022-10-30 22:52:31.937] [I] [zway] Job 0x13 (ManufacturerSpecific Get to node 104): Not delivered to recipient
[2022-10-30 22:52:31.938] [D] [zway] SENDING (cb 0x20): ( 01 09 00 13 68 02 72 04 25 20 FC )
[2022-10-30 22:52:31.940] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:31.941] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:31.941] [D] [zway] SENT ACK
[2022-10-30 22:52:31.941] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:31.944] [D] [zway] RECEIVED: ( 01 1D 00 13 20 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D3 )
[2022-10-30 22:52:31.944] [D] [zway] SENT ACK
[2022-10-30 22:52:31.945] [I] [zway] Job 0x13 (ManufacturerSpecific Get to node 104): Not delivered to recipient
[2022-10-30 22:52:31.946] [I] [zway] Job 0x13 (ManufacturerSpecific Get to node 104): Removing job due to too much retransmitions
[2022-10-30 22:52:31.946] [I] [zway] Adding job: Check if node is failed to node 104
[2022-10-30 22:52:31.946] [D] [zway] Job 0x13 (ManufacturerSpecific Get to node 104): fail
[2022-10-30 22:52:31.947] [I] [zway] Removing job: ManufacturerSpecific Get to node 104
[2022-10-30 22:52:31.947] [D] [zway] SENDING: ( 01 04 00 62 68 F1 )
[2022-10-30 22:52:31.949] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:31.950] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2022-10-30 22:52:31.950] [D] [zway] SENT ACK
[2022-10-30 22:52:31.950] [D] [zway] SETDATA devices.104.data.isFailed = False
[2022-10-30 22:52:31.950] [I] [zway] Job 0x62 (Check if node is failed to node 104): Node 104 is operating
[2022-10-30 22:52:31.950] [D] [zway] Job 0x62 (Check if node is failed to node 104): success
[2022-10-30 22:52:31.951] [D] [zway] SETDATA devices.104.data.failureCount = 0 (0x00000000)
[2022-10-30 22:52:31.951] [D] [zway] SETDATA devices.104.data.lastSendInternal = **********
[2022-10-30 22:52:31.951] [I] [zway] Removing job: Check if node is failed to node 104
[2022-10-30 22:52:32.433] [I] [zway] Adding job: Association Groupings Get to node 104
[2022-10-30 22:52:32.443] [D] [zway] SENDING (cb 0x21): ( 01 09 00 13 68 02 85 05 25 21 0B )
[2022-10-30 22:52:32.444] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:32.445] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:32.446] [D] [zway] SENT ACK
[2022-10-30 22:52:32.446] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:32.449] [D] [zway] RECEIVED: ( 01 1D 00 13 21 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D2 )
[2022-10-30 22:52:32.449] [D] [zway] SENT ACK
[2022-10-30 22:52:32.450] [I] [zway] Job 0x13 (Association Groupings Get to node 104): Not delivered to recipient
[2022-10-30 22:52:32.452] [D] [zway] SENDING (cb 0x22): ( 01 09 00 13 68 02 85 05 25 22 08 )
[2022-10-30 22:52:32.454] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:32.455] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:32.455] [D] [zway] SENT ACK
[2022-10-30 22:52:32.456] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:32.459] [D] [zway] RECEIVED: ( 01 1D 00 13 22 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 )
[2022-10-30 22:52:32.459] [D] [zway] SENT ACK
[2022-10-30 22:52:32.460] [I] [zway] Job 0x13 (Association Groupings Get to node 104): Not delivered to recipient
[2022-10-30 22:52:32.464] [D] [zway] SENDING (cb 0x23): ( 01 09 00 13 68 02 85 05 25 23 09 )
[2022-10-30 22:52:32.466] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:32.467] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:32.467] [D] [zway] SENT ACK
[2022-10-30 22:52:32.467] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:32.471] [D] [zway] RECEIVED: ( 01 1D 00 13 23 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 )
[2022-10-30 22:52:32.471] [D] [zway] SENT ACK
[2022-10-30 22:52:32.471] [I] [zway] Job 0x13 (Association Groupings Get to node 104): Not delivered to recipient
[2022-10-30 22:52:32.472] [I] [zway] Job 0x13 (Association Groupings Get to node 104): Removing job due to too much retransmitions
[2022-10-30 22:52:32.473] [I] [zway] Adding job: Check if node is failed to node 104
[2022-10-30 22:52:32.473] [D] [zway] Job 0x13 (Association Groupings Get to node 104): fail
[2022-10-30 22:52:32.473] [I] [zway] Removing job: Association Groupings Get to node 104
[2022-10-30 22:52:32.473] [D] [zway] SENDING: ( 01 04 00 62 68 F1 )
[2022-10-30 22:52:32.475] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:32.476] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2022-10-30 22:52:32.476] [D] [zway] SENT ACK
[2022-10-30 22:52:32.476] [D] [zway] SETDATA devices.104.data.isFailed = False
[2022-10-30 22:52:32.477] [I] [zway] Job 0x62 (Check if node is failed to node 104): Node 104 is operating
[2022-10-30 22:52:32.477] [D] [zway] Job 0x62 (Check if node is failed to node 104): success
[2022-10-30 22:52:32.477] [D] [zway] SETDATA devices.104.data.failureCount = 0 (0x00000000)
[2022-10-30 22:52:32.477] [D] [zway] SETDATA devices.104.data.lastSendInternal = **********
[2022-10-30 22:52:32.477] [I] [zway] Removing job: Check if node is failed to node 104
[2022-10-30 22:52:34.507] [D] [zway] RECEIVED: ( 01 17 00 04 00 68 0E B4 01 75 5E 09 57 49 17 85 03 38 96 7C 07 AB 00 00 EC )
[2022-10-30 22:52:34.508] [D] [zway] SENT ACK
[2022-10-30 22:52:34.508] [W] [zway] Got frame from device 104 to controller, but command class 0xb4 is not implemented
[2022-10-30 22:52:34.509] [D] [zway] SETDATA devices.104.data.lastReceived = 0 (0x00000000)
[2022-10-30 22:52:35.260] [D] [zway] RECEIVED: ( 01 17 00 04 00 68 0E B4 01 75 5E 09 57 49 17 85 03 38 96 7C 07 A8 00 00 EF )
[2022-10-30 22:52:35.260] [D] [zway] SENT ACK
[2022-10-30 22:52:35.260] [W] [zway] Discarding duplicate packet from node 104
[2022-10-30 22:52:35.381] [D] [zway] RECEIVED: ( 01 17 00 04 00 68 0E B4 01 75 5E 09 57 49 17 85 03 38 96 7C 07 A8 00 00 EF )
[2022-10-30 22:52:35.381] [D] [zway] SENT ACK
[2022-10-30 22:52:35.382] [W] [zway] Discarding duplicate packet from node 104
[2022-10-30 22:52:35.496] [I] [zway] Adding job: Association Groupings Get to node 104
[2022-10-30 22:52:35.505] [D] [zway] SENDING (cb 0x24): ( 01 09 00 13 68 02 85 05 25 24 0E )
[2022-10-30 22:52:35.507] [W] [zway] Received SOF, while awaiting ACK
[2022-10-30 22:52:35.508] [D] [zway] RECEIVED: ( 01 17 00 04 00 68 0E B4 01 75 5E 09 57 49 17 85 03 38 96 7C 07 A8 00 00 EF )
[2022-10-30 22:52:35.509] [D] [zway] SENT ACK
[2022-10-30 22:52:35.509] [W] [zway] Discarding duplicate packet from node 104
[2022-10-30 22:52:35.510] [D] [zway] RECEIVED CAN
[2022-10-30 22:52:35.521] [D] [zway] SENDING (cb 0x25): ( 01 09 00 13 68 02 85 05 25 25 0F )
[2022-10-30 22:52:35.523] [D] [zway] RECEIVED ACK
[2022-10-30 22:52:35.524] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-10-30 22:52:35.524] [D] [zway] SENT ACK
[2022-10-30 22:52:35.525] [D] [zway] Delivered to Z-Wave stack
[2022-10-30 22:52:39.395] [I] [zway] Adding job: Get background noise level
[2022-10-30 22:52:48.467] [I] [zway] Adding job: Basic Get to node 104
[2022-10-30 22:52:49.431] [I] [zway] Adding job: SwitchBinary Get to node 104
[2022-10-30 22:52:50.114] [I] [zway] Adding job: SwitchAll Get to node 104
[2022-10-30 22:52:50.114] [I] [zway] Adding job: SwitchAll Set to node 104
[2022-10-30 22:52:50.115] [D] [zway] Job 0x13 (SwitchAll Get): removing duplicate
[2022-10-30 22:52:50.115] [I] [zway] Node 104:0 CC SwitchAll: Auto Configuration done
[2022-10-30 22:52:50.387] [D] [zway] Job 0x60: deleted from queue
[2022-10-30 22:52:50.398] [D] [zway] Job 0x62: deleted from queue
[2022-10-30 22:52:50.408] [D] [zway] Job 0x3b: deleted from queue
[2022-10-30 22:52:50.479] [D] [zway] Job 0x13: deleted from queue
[2022-10-30 22:52:50.479] [D] [zway] Job 0x62: deleted from queue
[2022-10-30 22:52:50.541] [D] [zway] Job 0x13: deleted from queue
[2022-10-30 22:52:50.541] [D] [zway] Job 0x62: deleted from queue
[2022-10-30 22:52:50.602] [D] [zway] Job 0x13: deleted from queue
[2022-10-30 22:52:50.602] [D] [zway] Job 0x62: deleted from queue
[2022-10-30 22:52:50.640] [D] [zway] RECEIVED: ( 01 1B 00 04 00 7C 12 60 0D 01 00 32 02 21 64 00 04 3A 15 00 F0 00 04 39 FA A5 00 00 2E )
[2022-10-30 22:52:50.640] [D] [zway] SENT ACK
[2022-10-30 22:52:50.640] [D] [zway] SETDATA devices.124.data.lastReceived = 0 (0x00000000)
[2022-10-30 22:52:50.640] [D] [zway] SETDATA devices.124.instances.1.commandClasses.50.data.0.val = 277.013000
[2022-10-30 22:52:50.640] [D] [zway] SETDATA devices.124.instances.1.commandClasses.50.data.0.delta = 240 (0x000000f0)
[2022-10-30 22:52:50.641] [D] [zway] SETDATA devices.124.instances.1.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2022-10-30 22:52:50.641] [D] [zway] SETDATA devices.124.instances.1.commandClasses.50.data.0.previous = 276.985992
[2022-10-30 22:52:50.641] [D] [zway] SETDATA devices.124.instances.1.commandClasses.50.data.0 = Empty
[2022-10-30 22:52:50.672] [D] [zway] Job 0x13: deleted from queue
[2022-10-30 22:52:50.672] [D] [zway] Job 0x62: deleted from queue
[2022-10-30 22:52:50.712] [I] [zway] Adding job: Meter Get (v1) to node 104
[2022-10-30 22:52:50.731] [I] [core] [BaseModule-9] Set lastLevel to 277.012992 for ZWayVDev_zway_124-1-50-0 (was 276.985984)
[2022-10-30 22:52:50.733] [D] [zway] RECEIVED: ( 01 1B 00 04 00 7C 12 60 0D 01 00 32 02 21 64 00 04 3A 15 00 F0 00 04 39 FA A5 00 00 2E )
[2022-10-30 22:52:50.734] [D] [zway] SENT ACK
Re: contact Z-Wave.Me support in error log x 100
Hello!
Let's separate your post into three parts:
1) Random turn-on. In your log there are no On commands. It is
- either some device sending on command (Zniffer can help here), or
- the device turns on itself, or
- Get command due to RF noise becomes a Set and passes the CRC check on the device site. Again, Zniffer would allow you to see it if turning on coincides with some command that looks similar with only one-two bits difference.
2) "Unhandled command in policy - contact Z-Wave.Me support: XX YY" line. This is not harmful and was indeed fixed in v4.0.0. This is about incoming/outgoing policy.
3) It is now in testing release. You can install it from our site: https://storage.z-wave.me/z-way-server/ It will become part of the official repository in a few days
lanbrown
Post by lanbrown »
I have web server stability issues with build 154.
micky1500
Post by micky1500 »
None of the Beta versions I tried worked. Some were Fatal errors.
Lets hope 154 isn't the final release.
I have upgraded to 4.0.0 today.
Thanks to everyone involved.
Previous fixes seem to work well in 4.0.0.
Interviews seem to work at lightning speed.
Still got an Aeotec Multisensor 6 (Only 1 I tried) that worked before, now fails Interview at AssociationGroupInformation, after 50+ attempts.
No errors appear in the log.
My conclusion.
Get the upgrade.
Don't forget to get both backups before. just in-case.
And the GUI upgrade normally follows a few days later. I did it via Telnet.
