Cannot start Z-Wave binding: Error: Bad data - communication failed
piet66
Post by piet66 »
Since this morning, my Zway system suddenly doesn't work anymore.
I'm getting these messages:
[zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[core] Error: Bad data - communication failed
[core] Tried 5 times without success. Stopping tries.
[core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
I have searched the forum but have not found anything that would have helped me.
Also an upgrade to zway 4.0.2 and reboot didn't help.
Any ideas?
RaZberry by Z-Wave.Me(327) ZW0700 7.21.00 07.42/1766938484 1025/257
piet66
Re: Cannot start Z-Wave binding: Error: Bad data - communication failed
Post by piet66 »
Some more info to the problem:
after 23:00 last day, the log was flooded with the messages:
[2023-02-21 23:02:08.777] [zway] Adding job: Get background noise level
[2023-02-21 23:02:08.984] [zway] Job 0x3b (Get background noise level): No ACK received before timeout
[2023-02-21 23:02:09.189] [zway] Job 0x3b (Get background noise level): No ACK received before timeout
[2023-02-21 23:02:09.395] [zway] Job 0x3b (Get background noise level): No ACK received before timeout
[2023-02-21 23:02:09.395] [W] [zway] Job 0x3b (Get background noise level) dropped: too many resends
[2023-02-21 23:02:09.396] [zway] Removing job: Get background noise level
After restart of z-way-server no ZWayVDev_zway_ device was created, instead the messages were printed:
[2023-02-22 08:27:37.838] [zway] Adding job: Get controller info and supported function classes
[2023-02-22 08:27:38.047] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2023-02-22 08:27:38.249] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2023-02-22 08:27:38.451] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2023-02-22 08:27:38.451] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2023-02-22 08:27:38.452] [C] [zway] Get Serial API Capabilities returned zero.
[2023-02-22 08:27:38.452] [zway] Removing job: Get controller info and supported function classes
[2023-02-22 08:27:38.468] [I] [core] Terminating Z-Wave binding
[2023-02-22 08:27:38.482] [I] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2023-02-22 08:27:38.516] [I] [core] Trying to restart Z-Wave binding (zway) in 10 seconds
[2023-02-22 08:27:38.527] [I] [core] Error: Bad data - communication failed
[2023-02-22 08:27:38.528] [I] [core] Trying to restart Z-Wave binding (zway) in 10 seconds
[2023-02-22 08:28:13.806] [I] [core] Error: Bad data - communication failed
[2023-02-22 08:28:13.816] [I] [core] Tried 5 times without success. Stopping tries.
[2023-02-22 08:28:13.818] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
piet66
Post by piet66 »
I have reinstalled my old Razberry board. Z-Way now seems to work properly again.
If nobody knows better, I will say that the board is defective. I will send it back under warranty.
The new Razberry7 Pro board worked perfectly for only 6 weeks.
Is RaZ 2 working in the same place RaZ 7 is not ? Looks like a hardware fault. We can replace it for you once they are back in stock.
piet66
Post by piet66 »
Yes, Raz7 was put on the same Raspberry on the same place as the Raz2.
That's great if you would replace it.
lanbrown
Post by lanbrown »
PoltoS wrote:
22 Feb 2023 19:51
Any idea when that would be? The Pro variant that is.
Hopefully in March
melvinarda
Post by melvinarda »
Hopefully in March youtube apk
any update about this?
Still waiting for the delivery. Sorry, hope in April
piet66
Post by piet66 »
Amazon.de offers only the Razberry 7 Pro with US frequency.
When will the version with EU frequency be available?
