Which library must be included for the use of ZUNO_DYNAMIC_CHANNELS
KGBEl
Post by KGBEl »
I copied this code from github for my Z-Uno 2 and recived a lot of errors during verification in Arduino IDE.
The first error was:
"sketch_feb25b.ino:17:22: error: expected constructor, destructor, or type conversion before '(' token
byte number_of_sensors; // Number of sensors found"
Where line 17 is ZUNO_DYNAMIC_CHANNELS(MAX_SENSORS);
My guess is that I don't included the right library but...?
// Multiple temperature sensors DS18B20
#include "ZUNO_DS18B20.h"
#define DS18B20_BUS_PIN 11 // Pin to which 1-Wire bus is connected
#define MAX_SENSORS 1 // Number of DS18B20 sensors supported (equals to maximum number of channels for Z-Uno)
OneWire ow(DS18B20_BUS_PIN); // Software 1-Wire BUS
DS18B20Sensor ds18b20(&ow); // connect DS18B20 class to it
#define ADDR_SIZE 8 // Size of address of devices on 1-wire bus
byte addresses[ADDR_SIZE * MAX_SENSORS]; // Here we store all the scanned addresses
#define ADDR(i) (&addresses[i * ADDR_SIZE]) // Macro to simplify our life
ZUNO_ENABLE(WITH_CC_SENSOR_MULTILEVEL);
void setup() {
// Scanning sensors on the bus every time we starting a sketch
delay(1000);
number_of_sensors = ds18b20.findAllSensors(addresses);
if (number_of_sensors > MAX_SENSORS)
number_of_sensors = MAX_SENSORS;
// Setting up Z-Uno channels dynamically
// You have to exclude/include your Z-Uno to this take effect on the controller side
ZUNO_START_CONFIG();
for (byte i = 0; i < number_of_sensors; i++) {
if (i == 0) {
ZUNO_SET_ZWCHANNEL(0x81);
} else {
ZUNO_SET_ZWCHANNEL(i+1);
// Each channel is temperature sensor
ZUNO_ADD_CHANNEL(
ZUNO_SENSOR_MULTILEVEL_CHANNEL_NUMBER,
ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
SENSOR_MULTILEVEL_PROPERTIES_COMBINER(
SENSOR_MULTILEVEL_SCALE_CELSIUS,
SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS
// Commit configuration that we made...
ZUNO_COMMIT_CONFIG();
void loop(){
// Read temperature
g_channels_data.wParam = ds18b20.getTempC100(ADDR(i));
// Send report
zunoSendReport(i + 1); // Channels start from 1
// We have to wait 30 seconds. It's a requirement of the Z-Wave protocol
delay(30000);
amatilda
Re: Which library must be included for the use of ZUNO_DYNAMIC_CHANNELS
Post by amatilda »
KGBEl wrote: ↑
27 Feb 2023 16:39
Hello.
This method of dynamic channel creation is not supported in Z-Uno 2. Use this:
https://z-uno.z-wave.me/Reference/zunoS ... iguration/
KGBEl
Post by KGBEl »
Thank you amatilda, makes my life a better life!
