I connected a RaZberry to raspberry pi zero, I have tried everything but is not working.
I made sure to set up the port on dev/ttyAMA0.
I am attaching the logs but basically is not able to read the controller. I would appreciate some help, please.
Cannot start Z-Wave binding: Error: Bad data - communication failed
- log.zip
- (14.33 KiB) Downloaded 431 times
Re: Cannot start Z-Wave binding: Error: Bad data - communication failed
Please make sure the console is set up correctly. Please check https://forums.raspberrypi.com/viewtopic.php?t=150524
I also have the same problem. I have followed the instructions given, but that didn't solve it.
I even downloaded the version with the zway image: https://razberry.z-wave.me/z-way-server ... ry.img.zip, and still produces the same error
Please contact support on help.z-wave.me. It might be a device fault or a misconfigured software
