Device suddenly has a lot of associations with "Device _255"
intveltr
Post by intveltr »
One device (a Fibaro wall plug) suddenly reported "Removed associated devices".
When I check the associations, I see 8 entries each under Lifeline, On/Off (Button) and On/Off (Power), for devices #255, #255.1 through #255.7
They are crossed out and I cannot delete these entries.
Any ideas?
Re: Device suddenly has a lot of associations with "Device _255"
Please use the Expert Commands tab to remove them manually.
Where has it reported "Removed associated devices"?
intveltr
Post by intveltr »
It reports that in the home screen in Expert mode, under Network Health.
I cannot remove the associated devices, trying to remove them in the UI does nothing.
I ended up removing and re-including the device.
It might be a device issue. Z-Way tries to remove the association, but the device does nothing and still reports the association to be present. We have seen this for a few devices. If you will manage to repeat it, you can contact the manufacturer's support
