Home Assistant Integration - not able to control dimmers
lanbrown
Post by lanbrown »
Home Assistant 2023.6.2
Supervisor 2023.06.2
Operating System 10.2
Frontend 20230608.0 - latest
So Home Assistant is not able to control dimmers via the Z-Wave.me integration. I first noticed it with Aeotec Nano Dimmers and now Inovelli dimmers. I'm replacing the Aeotec with Inovelli.
If I make a lighting change in the Z-Way GUI the light works and the information is updated in Home Assistant. Any changes on that device in Home Assistant are not shown in the Z-Way GUI.
Above is the HA information. Z-Way I have tried with both 4.02 and 4.10.
Re: Home Assistant Integration - not able to control dimmers
We will check it and report you back.
RandomTask
Post by RandomTask »
Hello, I confirm the problem. Apparently, there have been some changes in version 2023.6.2 that break the switchMultilevel controls. We will solve this problem as soon as possible, but for now I can recommend rolling back to the version using this command in the home assistant terminal:
ha core update --version=2023.6.1
This command must be executed either in the homeassistant container or via SSH addon
lanbrown
Post by lanbrown »
The issue appears to be resolved by the following version:
Home Assistant 2023.6.3
Operating System 10.3
