How to integrate a Zigbee Dongle?
LasPro
Post by LasPro »
I try to use the Zigbee App with a Sonoff Zigbee dongle. My Razberry firmware has been upgraded to v4.1.2-wb1.
Is there a tutorial or similar available?
- Which Zigbee dongles work?
- Is it necessary to upgrade the dongle firmware?
- Are there any modification in the configuration necessary?
I always get the error message: Cannot start Zigbee binding: Error: Invalid port
The stick is connected to USB port 4. Which entry is required in the serial port field of the zigbee app?
/dev/ttyUSB4
or using the result of ls /dev/serial/by-id/:
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230508104044-if00
lanbrown
Re: How to integrate a Zigbee Dongle?
Post by lanbrown »
Check under supported hardware:
https://z-wave.me/z-way/#slide-4
Currently, only SiLabs-based sticks are supported. Soon it will be Z-Wave.Me only. Sonoff is not supported, sorry
