Cannot connect to webserver after upgrade
jteg
Post by jteg »
today I upgraded from 4.1.0 to 4.1.4. After the upgrade it is not possible to connect to the webserver, lynx/firefox or telnet, all are refused. In /var/log/z-way-server there are no stansas from any activity after the upgrade, just lines about starting the different parts. The last line is about starting the webserver and handlers, then nothing.
I have reinstalled with clean /opt folder but it does not help.
Running debian sid on a raspberry 2.
service z-way-server status shows it as running
No changes to the router have been done.
ssh to the raspberry works
Any ideas on where to look?
Thanks,
Jörgen
Eastpark
Re: Cannot connect to webserver after upgrade
Post by Eastpark »
1) explicit check IP-adress, after my upgrade including OS I got two new ip's one for LAN and a different one for WiFi it confused me!
2) check firewalls and your security settings in your gateways.
jteg
Post by jteg »
Thanks.
I did use the correct IP address, trying to connect both from the local host as well as IP and name. There was a reply on port 8084 for something else related to z-wayserver, so it is responding.
All connections are from inside the firewall, even local to the raspberry pi.
Correction from original post: The OS is not debian sid, but raspbian.
/Jörgen
enbemokel
Post by enbemokel »
Did you do a complete new start?
Or try netstat to see which ports are open?
As you wrote from port 8084, just to make sure, you connect to "IPaddress:8083"
jteg
Post by jteg »
Yes, restarted
I'll check with netstat, thanks
/Jörgen
micky1500
Post by micky1500 »
Something has got corrupt.
Not worth the time trying to fix it
don't bother with /opt folder.
go for a new build with 4.1.4
then restore you settings from the backup.
Easy peasy.
