as now long range is possible in EU and because now I have some devices with long range support, I wanted to enable LR for me, but I didn't succeed.
I have Z-Way 4.1.2, Razberry 7 firmware 7.42
the Controller Info tells Z-Wave Long Range = hook
but the
Expert UI Control/ Device Management says
Topology Mode: Long Range is not supported or not enabled in your hardware
In https://z-wave.me/hardware-capabilities I entered my UUID, but nothing happens., only a page with the Hardware features opened (hook at Long Range Support).
Updated to Z-Way 4.1.4, no help.
A reboot did not help either.
What have I to do to enable?
How to enable Long Range Support in EU ?
seattleneil
Re: How to enable Long Range Support in EU ?
You will need to update to a new version of Z-Way. Since Z-Way has transitioned from Z-Wave.Me to Trident IoT, upgrading to the Trident IoT version cannot be be done from the web user interface.
Run the following commands:
The Trident IoT Z-Way version supports EU Long Range which can be enabled in the expert UI. Note that devices included as LR devices are not mesh-capable. As a result, routing for your non-LR devices can be affected. The expert UI will show you if routing is healthy. If you see routing problems, you can do a Network->Reorganization.
cd /tmp
wget https://github.com/tridentiot/z-way-builds/releases/download/v5.0.2/z-way-debian-bookworm-armhf-5.0.2.bookworm-1_armhf.deb
sudo dpkg -i /tmp/z-way-debian-bookworm-armhf-5.0.2.bookworm-1_armhf.deb
According to the changelog, version 4.1.4 supports EU LR.
I am still hesitant to install the Trident version. Besides this, I'm still on buster.
Still hoping, that anybody knows how to enable it in the ZME version.
Thank you for the additional information. That's very helpful.
seattleneil
If you want/need new Z-Way features, please consider buying a new SD card and installing bookworm and Z-Way on the new SD card. Buster was deprecated over a year ago and is no longer receiving security updates. You can then copy the /opt/z-way-server directory from your old SD card to the new SD card (along with any other files that you want). With this approach, you can revert back to buster, by swapping the SD card.
